Home » Modeling » TMF (Xtext) » Xtext-enabled TextArea(Xtext Editor inside a TextArea )
Xtext-enabled TextArea [message #1080744] Tue, 06 August 2013 06:31 Go to next message
Hi All,
I have a usecase where I will be providing my dsl in a textarea(SWT Text control) embedded into an Editor in my eclipse plug-in. I want to use Xtext's feature of Syntax Highlighting, validation, code completion etc.
Is there a way to do this ?
Priya
Re: Xtext-enabled TextArea [message #1080759 is a reply to message #1080744] Tue, 06 August 2013 06:51 Go to previous messageGo to next message
yes searching for EmbeddedEditorFactory will help.
Re: Xtext-enabled TextArea [message #1080796 is a reply to message #1080759] Tue, 06 August 2013 07:38 Go to previous messageGo to next message
Hi Christian,
I did search for EmbeddedEditorFactory, but could not proceed!
Would you please share some more information to start with ? Any document an post will be helpful.
Priya
Re: Xtext-enabled TextArea [message #1080800 is a reply to message #1080796] Tue, 06 August 2013 07:45 Go to previous messageGo to next message
sorry i dont know any specific document.
you may dive into https://github.com/cdietrich/mql (but you have to look what you can use yourself)
Re: Xtext-enabled TextArea [message #1080808 is a reply to message #1080796] Tue, 06 August 2013 07:47 Go to previous messageGo to next message
So you couldn't find
http://download.eclipse.org/modeling/tmf/xtext/javadoc/2.4/org/eclipse/xtext/ui/editor/embedded/EmbeddedEditorFactory.html
On 06/08/2013 1:38 PM, Priya Sabut wrote:
> Hi Christian,
> Regards,
> Priya
Re: Xtext-enabled TextArea [message #1080811 is a reply to message #1080808] Tue, 06 August 2013 07:53 Go to previous messageGo to next message
Hi Ed,
I found the link you mentioned but how to do with it! I am very new to this. I am wondering from where will I start ? How and where will I use this class ? I am completely blank Sad
Thanks & Regards,
Priya
Re: Xtext-enabled TextArea [message #1081650 is a reply to message #1080811] Wed, 07 August 2013 10:00 Go to previous messageGo to next message
Any help please ?
Priya
Re: Xtext-enabled TextArea [message #1081653 is a reply to message #1081650] Wed, 07 August 2013 10:02 Go to previous messageGo to next message
Did you have a look at my code?
Re: Xtext-enabled TextArea [message #1081814 is a reply to message #1081653] Wed, 07 August 2013 14:30 Go to previous messageGo to next message
Hi Christian,
I got the code pointed by you. There were some errors, when I tried to 'Generate Xtext Artifacts', the import rule was conflicting with some other rule. Then I changes the multiplicity of import from * to + , then it compiled fine.
Now I wonder, what the code is doing. I saw the example project, it has three dsl files. Can you please explain a little what the behavior is ? How should I know what the project is providing ?
When I open the .mql dsl, it has some methods and all, but my requirement is how can I make an swt textarea to be xtext-enabled ? I mean instead of using editor provided by xtext, I will enter my language into the textarea and the textare should provide me all the editor functionality(like syntax checking, code completion etc...). Is your project doing this ? If yes, could you please tell me the steps- how to test/use the functionality written into the plug-in ?
Priya
Re: Xtext-enabled TextArea [message #1081834 is a reply to message #1081814] Wed, 07 August 2013 15:05 Go to previous messageGo to next message
hi there is a view called modelquerylanguageview that has 2 editors embedded
Re: Xtext-enabled TextArea [message #1082130 is a reply to message #1081834] Thu, 08 August 2013 01:52 Go to previous messageGo to next message
Thanks a lot Christian Smile
I am too much excited to see this. I hope this will surely help me. I am looking into the code right now Rolling Eyes . I will update you for any help. Thanks
Priya
Re: Xtext-enabled TextArea [message #1086483 is a reply to message #1080744] Wed, 14 August 2013 05:04 Go to previous messageGo to next message
Hi Christian,
I am able to create my own view(xtext-enabled) the same way it was done in your code.
Inside my grammar I am using FullJvmFormalParameter and JvmTypeReference types for my function argument and return types resp. For below method definition(language), the editor is not showing any error
function getXC(String xc): String {
return xc;
function getName(String a, java.util.ArrayList s)
: String {
if(a.equals('A')){
return a
else return "";
But I am getting error markers when I write the function inside my view "Couldn't resolve reference to JvmType 'String'.". Attaching the screen shoot for your reference.
Could you please tell, what am I missing here ?
[Updated on: Wed, 14 August 2013 05:07] by Moderator
Re: Xtext-enabled TextArea [message #1086486 is a reply to message #1086483] Wed, 14 August 2013 05:06 Go to previous messageGo to next message
The question is: did you do the changes i do in the uimodule?
if not you need a physical java project you let the resource you edit point to respectively come from
Re: Xtext-enabled TextArea [message #1086487 is a reply to message #1086486] Wed, 14 August 2013 05:09 Go to previous messageGo to next message
For view, whatever is needed I did that. I am not sure what am I missing Sad
Sorry, I did not understand the second sentence!!
Re: Xtext-enabled TextArea [message #1086490 is a reply to message #1086487] Wed, 14 August 2013 05:11 Go to previous messageGo to next message
if the resource you edit physically comes from a java project and the resource you create is tied to this java project it should work out of the box (IResourceSetProvider)
Re: Xtext-enabled TextArea [message #1086496 is a reply to message #1086490] Wed, 14 August 2013 05:18 Go to previous messageGo to next message
For editor I have the resource tied to java project and it is working fine.
But how can I tie a view to java project ? The problem I am facing is in the view
Re: Xtext-enabled TextArea [message #1086498 is a reply to message #1086496] Wed, 14 August 2013 05:20 Go to previous messageGo to next message
using a different version of org.eclipse.xtext.ui.editor.embedded.IEditedResourceProvider
e.g.
public class ModelQueryLanguageEditedResourceProvider implements IEditedResourceProvider {
	@Inject
	IResourceSetProvider rsp;
	private IProject project;
	public IProject getProject() {
		return project;
	public void setProject(IProject project) {
		this.project = project;
	public XtextResource createResource() {
		return (XtextResource) rsp.get(project).createResource(URI.createURI("platform./resource/"+project.getname()+"/test.mql"));
[Updated on: Wed, 14 August 2013 05:20] by Moderator
Re: Xtext-enabled TextArea [message #1086502 is a reply to message #1086498] Wed, 14 August 2013 05:21 Go to previous messageGo to next message
P.S: sorry further digging you have to do yourself
Re: Xtext-enabled TextArea [message #1086505 is a reply to message #1086502] Wed, 14 August 2013 05:29 Go to previous messageGo to next message
any link or any doc talking about it ?
Re: Xtext-enabled TextArea [message #1086508 is a reply to message #1086505] Wed, 14 August 2013 05:33 Go to previous messageGo to next message
nope i fear you have to google
Re: Xtext-enabled TextArea [message #1086519 is a reply to message #1086508] Wed, 14 August 2013 05:48 Go to previous message
P.S: are you sure it dosent work with
	@Inject
		return project;
		return (XtextResource) rsp.get(project).createResource(URI.createURI("test.mql"));
simply call setProject on the ModelQueryLanguageEditedResourceProvider
you pass to the embeddedEditorFactory
Previous Topic:M2M transformation and file comments
Next Topic:Word wrap on ConfigurableCompletionProposal tooltips - how?
Current Time: Tue Oct 28 18:33:57 EDT 2025
Powered by FUDForum. Page generated in 0.10439 seconds
