Home » Eclipse Projects » Eclipse 4 » @Inject EMenuService ends in Nullpointer - Why?
@Inject EMenuService ends in Nullpointer - Why? [message #1080738] Tue, 06 August 2013 06:28 Go to next message
i'm building a PopupMenuBuilder for a SWT Component (NatTable), which shall be extendable via menu id's. i had it working in E3, now moving the code to e4.
when i try:
public class EclipsePopupMenuBuilder {
	@Inject
	EMenuService menuService; 	// e4
	public EclipsePopupMenuBuilder(NatTable natTable, String menuId) {
	// weder nattable noch menuId sind null!
	e4popupMenu = menuService.registerContextMenu(natTable, menuId);
the stacktrace is the following:
!ENTRY org.eclipse.e4.ui.workbench 4 0 2013-08-06 12:24:39.418
!MESSAGE
!STACK 0
org.eclipse.e4.core.di.InjectionException: java.lang.NullPointerException
	at org.eclipse.e4.core.internal.di.ConstructorRequestor.execute(ConstructorRequestor.java:53)
	at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:331)
	at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:254)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
	at org.eclipse.e4.tools.compat.internal.PartHelper.createComponent(PartHelper.java:76)
	at org.eclipse.e4.tools.compat.parts.DIViewPart.createPartControl(DIViewPart.java:45)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPartControl(CompatibilityPart.java:142)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityView.createPartControl(CompatibilityView.java:174)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:323)
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:877)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:857)
	at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:119)
	at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:333)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:102)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:71)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:53)
	at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:129)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:949)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:633)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$6.run(PartRenderingEngine.java:526)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:511)
	at org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer.createWidget(ElementReferenceRenderer.java:61)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:735)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:706)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:700)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:685)
	at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1096)
	at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:97)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:649)
	at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:61)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:645)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer.processContents(PerspectiveRenderer.java:59)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:103)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.postProcess(PerspectiveStackRenderer.java:77)
	at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:676)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1042)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:138)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:610)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
	at lumo.widgets.table.EclipsePopupMenuBuilder.<init>(EclipsePopupMenuBuilder.java:42)
	at lumo.widgets.table.BodyMenuConfiguration.<init>(BodyMenuConfiguration.java:27)
	at lumo.widgets.table.LumoTable.addTableBodyMenu(LumoTable.java:712)
	at lumo.widgets.table.LumoTable.configure(LumoTable.java:246)
	at lumo.widgets.table.LumoTableViewPartViewer.setInput(LumoTableViewPartViewer.java:65)
	at lumo.widgets.table.LumoTableViewPartViewer.<init>(LumoTableViewPartViewer.java:26)
	at lumo.views.internal.e4.E4TableViewPartTemplate.createPartControl(E4TableViewPartTemplate.java:196)
	at lumo.views.internal.e4.E4AbstractDetailViewPart.<init>(E4AbstractDetailViewPart.java:82)
	at lumo.views.internal.e4.E4AbstractViewPart.<init>(E4AbstractViewPart.java:14)
	at lumo.views.internal.e4.E4AbstractTableViewPart.<init>(E4AbstractTableViewPart.java:26)
	at lumo.views.internal.e4.E4TableViewPartTemplate.<init>(E4TableViewPartTemplate.java:48)
	at at.biooffice.views.site.pojo.PojoListView.<init>(PojoListView.java:31)
	at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
	at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
	at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
	at java.lang.reflect.Constructor.newInstance(Unknown Source)
	at org.eclipse.e4.core.internal.di.ConstructorRequestor.execute(ConstructorRequestor.java:44)
	... 119 more
Re: @Inject EMenuService ends in Nullpointer - Why? [message #1080761 is a reply to message #1080738] Tue, 06 August 2013 06:55 Go to previous messageGo to next message
Well, who is creating your instance of EclipsePopupMenuBuilder? Do you create it yourself using the new operator or do you use the ContextInjectionFactory?
If you want to use dependency injection in your custom objects, you need to have them created by the ContextInjectionFactory or inject necesssary values afterwards. Otherwise those values are not injected.
Re: @Inject EMenuService ends in Nullpointer - Why? [message #1080776 is a reply to message #1080738] Tue, 06 August 2013 07:12 Go to previous messageGo to next message
You are access an injected value in the constructor how should that work?
It has to be null by definition and can be set only after the constuctor
has been finished and the instance returned to the caller.
Tom
On 06.08.13 12:28, Ludwig Moser wrote:
> Hello,
> the code to e4.
> when i try:
> @Inject
> !MESSAGE !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at
> at
> at
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150)
> at
> org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:124)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Method)
> Source)
> Source)
> at
> ... 119 more
Re: @Inject EMenuService ends in Nullpointer - Why? [message #1080779 is a reply to message #1080761] Tue, 06 August 2013 07:18 Go to previous messageGo to next message
Dirk Fauth wrote on Tue, 06 August 2013 06:55
i do create it using the new operator.
how can i inject the values when i need it?
Re: @Inject EMenuService ends in Nullpointer - Why? [message #1080859 is a reply to message #1080779] Tue, 06 August 2013 09:10 Go to previous messageGo to next message
First of all, as addition to Tom's answer, you need to consider the injection order: http://wiki.eclipse.org/Eclipse4/RCP/Dependency_Injection#Injection_Order
Second, when using the new operator, there is no injection performed. You need to use the functions of the DI container, otherwise, who should do the injection?
You can do this by using @Creatable or ContextInjectionFactory.make() dependent on your use cases. Lars Vogel described it briefly here:
http://www.vogella.com/articles/EclipseRCP/article.html#ownobjects
Re: @Inject EMenuService ends in Nullpointer - Why? [message #1081434 is a reply to message #1080859] Wed, 07 August 2013 04:16 Go to previous messageGo to next message
okay,
i changed my code to inject the EMenuService in my Pojo View. then pass the service to my gui component (lumoTable, which is nothing more than a config class, which creates a custom natTable and applies changes made in my api)
now no more exceptions get raised.
it was not clear to me that injection is not allowed in constructors.
thanks for your help.
Re: @Inject EMenuService ends in Nullpointer - Why? [message #1081453 is a reply to message #1081434] Wed, 07 August 2013 04:46 Go to previous message
That's wrong! Of course injection is allowed in constructors! You just need to consider the injection order! First the constructor is called and the parameters that are necessary will be injected. Then the fields get injected. And at last the method injection happens. This is important!
This means you can not access fields that should be injected within the constructor, because the fields are not yet injected.
But that wasn't your issue. Your issue was that you didn't enabled your class for injection, so neither the constructor nor the fields would be injected, because you create your instance yourself using the new operator. But to enable injection in your custom classes, they need to be created using the dependency injection container!
Re: @Inject EMenuService ends in Nullpointer - Why? [message #1081454 is a reply to message #1081434] Wed, 07 August 2013 04:45 Go to previous message
On 07.08.13 10:16, Ludwig Moser wrote:
> okay,
> in my api)
This is not correct you can inject values in the constructor - as part
of the argument list to the constructor call. What you can not do is
accessing field injections but if you think a bit on how object
initialization works this should NOT be suprising!
Tom
Previous Topic:Interactive splashscreen (e4)
Next Topic:application doesn't start anymore
Current Time: Sat Jul 26 11:49:49 EDT 2025
Powered by FUDForum. Page generated in 0.25775 seconds
