@Inject EMenuService ends in Nullpointer - Why? [message #1080738] |
Tue, 06 August 2013 06:28  |
i'm building a PopupMenuBuilder for a SWT Component (NatTable), which shall be extendable via menu id's. i had it working in E3, now moving the code to e4.
when i try:
public class EclipsePopupMenuBuilder {
@Inject
EMenuService menuService; // e4
public EclipsePopupMenuBuilder(NatTable natTable, String menuId) {
// weder nattable noch menuId sind null!
e4popupMenu = menuService.registerContextMenu(natTable, menuId);
the stacktrace is the following:
!ENTRY org.eclipse.e4.ui.workbench 4 0 2013-08-06 12:24:39.418
!MESSAGE
!STACK 0
org.eclipse.e4.core.di.InjectionException: java.lang.NullPointerException
at org.eclipse.e4.core.internal.di.ConstructorRequestor.execute(ConstructorRequestor.java:53)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:331)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:254)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
at org.eclipse.e4.tools.compat.internal.PartHelper.createComponent(PartHelper.java:76)
at org.eclipse.e4.tools.compat.parts.DIViewPart.createPartControl(DIViewPart.java:45)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPartControl(CompatibilityPart.java:142)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityView.createPartControl(CompatibilityView.java:174)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:323)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:877)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:857)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:119)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:333)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:102)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:71)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:53)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:129)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:949)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:633)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$6.run(PartRenderingEngine.java:526)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:511)
at org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer.createWidget(ElementReferenceRenderer.java:61)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:735)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:706)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:700)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:685)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1096)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:97)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:649)
at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:61)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:645)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer.processContents(PerspectiveRenderer.java:59)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:103)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.postProcess(PerspectiveStackRenderer.java:77)
at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:676)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1042)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:138)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:610)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
at lumo.widgets.table.EclipsePopupMenuBuilder.<init>(EclipsePopupMenuBuilder.java:42)
at lumo.widgets.table.BodyMenuConfiguration.<init>(BodyMenuConfiguration.java:27)
at lumo.widgets.table.LumoTable.addTableBodyMenu(LumoTable.java:712)
at lumo.widgets.table.LumoTable.configure(LumoTable.java:246)
at lumo.widgets.table.LumoTableViewPartViewer.setInput(LumoTableViewPartViewer.java:65)
at lumo.widgets.table.LumoTableViewPartViewer.<init>(LumoTableViewPartViewer.java:26)
at lumo.views.internal.e4.E4TableViewPartTemplate.createPartControl(E4TableViewPartTemplate.java:196)
at lumo.views.internal.e4.E4AbstractDetailViewPart.<init>(E4AbstractDetailViewPart.java:82)
at lumo.views.internal.e4.E4AbstractViewPart.<init>(E4AbstractViewPart.java:14)
at lumo.views.internal.e4.E4AbstractTableViewPart.<init>(E4AbstractTableViewPart.java:26)
at lumo.views.internal.e4.E4TableViewPartTemplate.<init>(E4TableViewPartTemplate.java:48)
at at.biooffice.views.site.pojo.PojoListView.<init>(PojoListView.java:31)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at org.eclipse.e4.core.internal.di.ConstructorRequestor.execute(ConstructorRequestor.java:44)
... 119 more
Re: @Inject EMenuService ends in Nullpointer - Why? [message #1081453 is a reply to message #1081434] |
Wed, 07 August 2013 04:46  |
Quote:it was not clear to me that injection is not allowed in constructors.
That's wrong! Of course injection is allowed in constructors! You just need to consider the injection order! First the constructor is called and the parameters that are necessary will be injected. Then the fields get injected. And at last the method injection happens. This is important!
This means you can not access fields that should be injected within the constructor, because the fields are not yet injected.
But that wasn't your issue. Your issue was that you didn't enabled your class for injection, so neither the constructor nor the fields would be injected, because you create your instance yourself using the new operator. But to enable injection in your custom classes, they need to be created using the dependency injection container!
Re: @Inject EMenuService ends in Nullpointer - Why? [message #1081454 is a reply to message #1081434] |
Wed, 07 August 2013 04:45  |
On 07.08.13 10:16, Ludwig Moser wrote:
> okay,
> i changed my code to inject the EMenuService in my Pojo View. then pass
> the service to my gui component (lumoTable, which is nothing more than a
> config class, which creates a custom natTable and applies changes made
> in my api)
> now no more exceptions get raised.
This is not correct you can inject values in the constructor - as part
of the argument list to the constructor call. What you can not do is
accessing field injections but if you think a bit on how object
initialization works this should NOT be suprising!
Tom
> thanks for your help.
FUDForum. Page generated in 0.06831 seconds
