Home » Newcomers » Newcomers » Are separate plugin directories possible ?
Are separate plugin directories possible ? [message #107785] Thu, 06 October 2005 11:47 Go to next message
Originally posted by: brian.compston.xxx.xxx
I would like to keep 'extra' plugins in a separate directory from the
plugins shipped with Eclipse. Is this possible ? and if it is what do I
need to do to achieve it ?
I'm sure I came across a reference somewhere on how to do this, I just
can't find it again !!
Brian Compston
Re: Are separate plugin directories possible ? [message #107985 is a reply to message #107785] Fri, 07 October 2005 13:58 Go to previous messageGo to next message
Yes, it is possible.
The easiest way is to do Help > Software Updates > Manage Configuration
and from that dialog create a new "Extension Location" into which you
can install plugins (when using the Update Manager to install plugins
one of the steps allows you to choose the location - make sure to select
your new Extension Location instead of the default base Eclipse install
directory).
It is possible to do manually but I don't remember the details.
HTH,
Eric
Re: Are separate plugin directories possible ? [message #108067 is a reply to message #107985] Fri, 07 October 2005 15:35 Go to previous message
Originally posted by: brian.compston.goodrich.com
Thanks for the info Eric, that's just what I needed to here !
Brian
Previous Topic:How to see J2EE API documentation when hovering mouse over a class or method?
Next Topic:java view tabs
Current Time: Wed Sep 17 07:54:19 EDT 2025
Powered by FUDForum. Page generated in 0.07910 seconds
