Home » Eclipse Projects » Vex » How to get attributes?(Getting attributes when vex is implemented as a dialog.)
How to get attributes? [message #1077874] Fri, 02 August 2013 04:55 Go to next message
I implement vex in a dialog.
I wonder if there is a way of getting a properties window with the attributes (or any other way to access attributes).
It's easy to access elements via the
org.eclipse.vex.ui.internal.handlers.AddElementHandler
but couldn't figure a way to access the attributes.
Many thanks
Shay.
Re: How to get attributes? [message #1078657 is a reply to message #1077874] Sat, 03 August 2013 06:19 Go to previous messageGo to next message
attributes are currently only editable in the properties view. There is nothing like the content assist for elements.
You may want to take a look at org.eclipse.vex.ui.internal.property.ElementPropertySource which gets the attributes for an element in the properties view.
The main points here are
final List<AttributeDefinition> attributeDefinitions = validator.getAttributeDefinitions(element);
to get all possible attributes for a given element and
element.getAttribute(attributeDefinition.getName()
which returns the value for an attribute.
Hope this helps to get you started, regards
Carsten
Re: How to get attributes? [message #1080650 is a reply to message #1078657] Tue, 06 August 2013 04:02 Go to previous message
Hi Carsten. This is GREAT help Smile
Many thanks.
Previous Topic:Why is Editor Read-Only?
Next Topic:Plugin creation
Current Time: Mon Jul 21 00:00:55 EDT 2025
Powered by FUDForum. Page generated in 0.04796 seconds
