[QVTR]First Implementation [message #107403] |
Mon, 29 June 2009 13:55  |
I downloaded the QVT example which transforms Uml to Rdbms. This example
contains four folders, as bin, metamodel, model and source. In the bin
folder there exist two files as .qvtrelation and .qvtr, in adition of two
text files for types which are uml and rdbms.
Two metamodels are inside metamodel folder and in the form of .ecore. I
want to ask how is it possible to have ecore with out having the exact
implementation of metamodel? and where should I write the exact
metamodel. also I just found the implementation for Rdbms in
documantation and I could not find anything regarding to uml meta model.
Then in the model folder we have the source model in .xmi format and by
executing the whole program we will have the target model. In this
example I could not see ant qvt core.
This what I undrestand after spending a week on QVT.
I read some parts of documantation again and try to run this example but
still can not do that.I know I should have two metamodel,one model and
one qvt core and one relational code . but I can not see all of them in
this example
I confused every thing now
can you please help me to run this example.
Many thanks,
Shekoufeh
Re: [QVTR]First Implementation [message #108045 is a reply to message #107403] |
Wed, 08 July 2009 12:51  |
Originally posted by: glineur.montages.com
Hi Shekoufeh,
Comments below,
> example contains four folders, as bin, metamodel, model and source. In
> the bin folder there exist two files as .qvtrelation and .qvtr, in
> adition of two text files for types which are uml and rdbms.
The .qvtr files are the textual definition of the transformation.
The .qvtrelation files are the model of the transformation (conforming
to the metamodel defined in the abstract syntax part of the
specification) This structure is obtained by parsing the text.
What do you mean by exact implementation of the exact implementation?
Actually I understand that ecore IS the exact implementation.
Which documentation are you talking about?
Currently we are in the specification phase to use qvt core. As the
specification lacks some details about it, we have to carefully fill the
gap.
> but still can not do that.I know I should have two metamodel,one model
> and one qvt core and one relational code . but I can not see all of
> them in this example
You just need:
the input model, its metamodel and the output metamodel.
(the compilation is currently done in another format than qvt core)
> Many thanks,
> Shekoufeh
Quentin
FUDForum. Page generated in 0.04621 seconds
