Home » Modeling » TMF (Xtext) » [Xbase] Change keywords of XSwitchExpression
[Xbase] Change keywords of XSwitchExpression [message #1079935] Mon, 05 August 2013 04:55 Go to next message
I would like to change the keywords for the XSwitchExpression in Xbase. I would like to transform this:
    switch e {
    case e1 : er1
    case en : ern
    default : er
to that:
    case of e {
    case e1 : er1
    case en : ern
    otherwise : er
I managed the "case of" and "otherwise" bits but now the parser complains if I try to write "case" statements, because it expects "case of" and not "case" even so I did not change anything in the XCasePart rule. I guess I have to use syntactic predicates but I could not make it work.
Is this possible somehow?
Jan
[Updated on: Mon, 05 August 2013 04:56] by Moderator
Re: [Xbase] Change keywords of XSwitchExpression [message #1081398 is a reply to message #1079935] Wed, 07 August 2013 03:22 Go to previous message
Am 05.08.13 10:55, schrieb Jan Rosczak:
> switch e {
> case e1 : er1
> case en : ern
> default : er
> to that:
> case of e {
> case e1 : er1
> case en : ern
> otherwise : er
> work.
> Thanks
> Jan
Hi Jan,
make sure that you use 'case' 'of' rather than 'case of', e.g. the space
should not be part of the keyword.
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Previous Topic:Xtext 2.4.2 generating generic <T>
Next Topic:No EObjectDescription could be found in Scope Web.sitePermission for
Current Time: Sun Jul 20 21:07:34 EDT 2025
Powered by FUDForum. Page generated in 0.26049 seconds
