Home » Eclipse Projects » Eclipse Platform » How to display a MessageDialog on startup ?
How to display a MessageDialog on startup ? [message #107735] Wed, 06 August 2003 22:40 Go to next message
Originally posted by: bhavin_r.rediffmail.com
I am trying to display a Hello World Dialog Box (something like
tip-of-the-day) on eclipse startup...how can I do that ?
I have attempted to write a plugin implementing IStartup, when I run it in
Workbench I can find it in Preferences > Workbench > Startup. But if I
write
MessageDialog.openInformation( ..) function inside the interface
implemented method earlyStartup()..it gives either NullPointerException or
some Invalid Thread Access SWT related error. I think it is because of the
first argument of openInformation -> Shell (parent) I am not able to
define properly.
How can I get the Shell within earlyStartup method...am I on the right way
or something is missing ..?
Thanks in advance.
Bhavin Raichura
Re: How to display a MessageDialog on startup ? [message #107831 is a reply to message #107735] Thu, 07 August 2003 04:30 Go to previous messageGo to next message
Originally posted by: boylaboy.hotmail.com
Hi:
You can do that like this:
MessageDialog.openInformation(window.getShell(),"Hello","tip-of-the-day ");
It should be in the Run method.
"Bhavin Raichura" <bhavin_r@rediffmail.com>
??????:bgse7c$hoh$1@eclipse.org...
> write
> define properly.
> Thanks in advance.
> Bhavin Raichura
Re: How to display a MessageDialog on startup ? [message #107975 is a reply to message #107735] Thu, 07 August 2003 10:04 Go to previous message
Bhavin Raichura wrote:
> write
> define properly.
The docs for IStartup.earlyStartup() state that is will be called in a
background thread. If you want to do anything UI-related, you will need
to run that code on the UI thread. See Display.syncExec() and
Display.asyncExec().
Jeff
Previous Topic:ant script not executed
Next Topic:Version #'s
Current Time: Tue Sep 16 01:11:12 EDT 2025
Powered by FUDForum. Page generated in 0.03492 seconds
