Home » Modeling » ATL » EMFTVM - p2 repository
EMFTVM - p2 repository [message #1078691] Sat, 03 August 2013 07:29 Go to next message
We are using Tycho to build our Eclipse feature. One of the dependencies is EMFTVM. Unfortunatelly Tycho does not handle old-style Eclipse update sites and EMFTVM does not publish p2 repository.
What approach would you suggest as a workaround?
Michal
Re: EMFTVM - p2 repository [message #1079450 is a reply to message #1078691] Sun, 04 August 2013 12:07 Go to previous messageGo to next message
I suppose you can try the Hudson integration build update site:
https://hudson.eclipse.org/hudson/job/m2m-atl-master/lastSuccessfulBuild/artifact/releng/org.eclipse.m2m.atl.update/target/repository/
Re: EMFTVM - p2 repository [message #1079453 is a reply to message #1079450] Sun, 04 August 2013 12:14 Go to previous messageGo to next message
As another way to go: does http://wiki.eclipse.org/Tycho/Reference_Card#Update_Site work?
Re: EMFTVM - p2 repository [message #1092957 is a reply to message #1079450] Fri, 23 August 2013 07:22 Go to previous messageGo to next message
Dennis Wagelaar wrote on Sun, 04 August 2013 12:07
But I am confused with feature names. This repo contains org.eclipse.m2m.atl.emftvm feature. So if I add this dependency and this repo my build works OK. But this feature is not available from Eclipse update sites. "be.ac.vub.emftvm.feature.feature.group" is available instead - so installation of my (dependent) feature fails with unresolved dependency.
Michal
Re: EMFTVM - p2 repository [message #1092958 is a reply to message #1079450] Fri, 23 August 2013 07:22 Go to previous messageGo to next message
Michal
Re: EMFTVM - p2 repository [message #1092959 is a reply to message #1079450] Fri, 23 August 2013 07:23 Go to previous messageGo to next message
Michal
Re: EMFTVM - p2 repository [message #1092960 is a reply to message #1079453] Fri, 23 August 2013 07:23 Go to previous messageGo to next message
Michal
Re: EMFTVM - p2 repository [message #1092961 is a reply to message #1079453] Fri, 23 August 2013 07:25 Go to previous messageGo to next message
Michal
Re: EMFTVM - p2 repository [message #1092962 is a reply to message #1079453] Fri, 23 August 2013 07:25 Go to previous messageGo to next message
Michal
Re: EMFTVM - p2 repository [message #1093118 is a reply to message #1092962] Fri, 23 August 2013 11:53 Go to previous messageGo to next message
Sorry for multiple posts but the forum didn't show my message and I didn't know if it was actually sent.
Michal
Re: EMFTVM - p2 repository [message #1093131 is a reply to message #1093118] Fri, 23 August 2013 12:15 Go to previous messageGo to next message
No problem. It's an irritating bug in the newsgroup/forum synchronization.
Ed Willink
> Michal
Re: EMFTVM - p2 repository [message #1094842 is a reply to message #1092957] Mon, 26 August 2013 05:09 Go to previous message
Michal Kleczek wrote on Fri, 23 August 2013 07:22
Michal
Dependencies work at plug-in level, not feature level. The plug-in IDs should be the same. If the different feature ID is causing problems, you should know that the "org.eclipse.*" feature IDs are the official ones. The "be.ac.vub.emftvm.feature.feature.group" will be discontinued in the future, as I'm no longer working at the VUB.
The official release update site is:
http://download.eclipse.org/mmt/atl/updates/releases/3.4/
The integration build update site (with latest bugfixes) is the one listed at the top.
Your feature can list "see also" update site URLs. Perhaps you can use this to point Eclipse to the ATL/EMFTVM update site?
Previous Topic:Error when using getValue(stereotype, String) wrong number of parameters
Next Topic:Not a valid classifier
Current Time: Sat Jul 26 23:37:20 EDT 2025
Powered by FUDForum. Page generated in 0.06839 seconds
