org.osgi.framework.BundleException: Bundle org.eclipse.persistence.jpa cannot be resolved [message #1079180] |
Sun, 04 August 2013 02:02  |
Hi I'm compiling eclipselink source code, I've followed the instructions from the wiki but when I run the build using ant the build stops when this message appears. Anyone knows what could be wrong? Thanks.
[java] [ERROR] Internal error: java.lang.RuntimeException: org.osgi.framework.BundleException: Bundle org.eclipse.persistence.jpa cannot be resolved
[java] [ERROR] Resolution errors:
[java] [ERROR] Bundle org.eclipse.persistence.jpa - Missing Constraint: Import-Package: javax.persistence; version="[1.1.0,2.2.0)"
[java] [ERROR] Bundle org.eclipse.persistence.jpa - Missing Constraint: Import-Package: javax.persistence.criteria; version="[1.1.0,2.2.0)"
[java] [ERROR] Bundle org.eclipse.persistence.jpa - Missing Constraint: Import-Package: javax.persistence.metamodel; version="[1.1.0,2.2.0)"
[java] [ERROR] Bundle org.eclipse.persistence.jpa - Missing Constraint: Import-Package: javax.persistence.spi; version="[1.1.0,2.2.0)"
[java] [ERROR] -> [Help 1]
[java] org.apache.maven.InternalErrorException: Internal error: java.lang.RuntimeException: org.osgi.framework.BundleException: Bundle org.eclipse.persistence.jpa cannot be resolved
[java] Resolution errors:
[java] Bundle org.eclipse.persistence.jpa - Missing Constraint: Import-Package: javax.persistence; version="[1.1.0,2.2.0)"
[java] Bundle org.eclipse.persistence.jpa - Missing Constraint: Import-Package: javax.persistence.criteria; version="[1.1.0,2.2.0)"
[java] Bundle org.eclipse.persistence.jpa - Missing Constraint: Import-Package: javax.persistence.metamodel; version="[1.1.0,2.2.0)"
[java] Bundle org.eclipse.persistence.jpa - Missing Constraint: Import-Package: javax.persistence.spi; version="[1.1.0,2.2.0)"
[java] at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:168)
[java] at org.apache.maven.cli.MavenCli.execute(MavenCli.java:537)
[java] at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:196)
[java] at org.apache.maven.cli.MavenCli.main(MavenCli.java:141)
[java] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
[java] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
[java] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
[java] at java.lang.reflect.Method.invoke(Method.java:601)
[java] at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:290)
[java] at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:230)
[java] at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:409)
[java] at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:352)
[java] Caused by: java.lang.RuntimeException: org.osgi.framework.BundleException: Bundle org.eclipse.persistence.jpa cannot be resolved
[java] at org.eclipse.tycho.core.osgitools.OsgiBundleProject.getResolverState(OsgiBundleProject.java:252)
[java] at org.eclipse.tycho.core.osgitools.OsgiBundleProject.resolveClassPath(OsgiBundleProject.java:158)
[java] at org.eclipse.tycho.core.resolver.DefaultTychoDependencyResolver.resolveProject(DefaultTychoDependencyResolver.java:111)
[java] at org.eclipse.tycho.core.maven.TychoMavenLifecycleParticipant.afterProjectsRead(TychoMavenLifecycleParticipant.java:64)
[java] at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:274)
[java] at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:156)
[java] ... 11 more
[java] Caused by: org.osgi.framework.BundleException: Bundle org.eclipse.persistence.jpa cannot be resolved
[java] at org.eclipse.tycho.core.osgitools.EquinoxResolver.assertResolved(EquinoxResolver.java:291)
[java] at org.eclipse.tycho.core.osgitools.EquinoxResolver.newResolvedState(EquinoxResolver.java:71)
[java] at org.eclipse.tycho.core.osgitools.OsgiBundleProject.getResolverState(OsgiBundleProject.java:250)
[java] ... 16 more
[java] [ERROR]
[java] [ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[java] [ERROR] Re-run Maven using the -X switch to enable full debug logging.
[java] [ERROR]
[java] [ERROR] For more information about the errors and possible solutions, please read the following articles:
BUILD FAILED
D:\workspace\eclipselink\antbuild.xml:343: Java returned: 1
Total time: 28 seconds
Re: org.osgi.framework.BundleException: Bundle org.eclipse.persistence.jpa cannot be resolved [message #1082404 is a reply to message #1079180] |
Thu, 08 August 2013 10:23  |
Looks like it cannot find the follow packages,
Are these available in your maven repository?
FUDForum. Page generated in 0.39749 seconds
