Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » XCORE and XTEXT Grammar(XCORE and XTEXT Grammar)
icon5.gif  XCORE and XTEXT Grammar [message #1078570] Sat, 03 August 2013 03:07 Go to next message
I am using .xcore file as meta model for my grammar, which looks something like this,
class Sample{
Integer bit
And my grammar:
Sample:
'Sample'....
('BIT' | 'BYTE') bit=INT
This "bit=INT" I am referring from my xcore model.
MY PROBLEM IS THAT I WANT TO EITHER TYPE "BIT AND THEN BIT VALUE" OR "BYTE AND THEN BYTE VALUE" IN MY LANGUAGE.
BUT WHEN I WRITE "BYTE AND BYTE VALUE" , I AM CONVERTING BITS INTO BYTES AND THEN STORING IT IN SAME METAMODEL FIELD "bit".
SO LATER WHEN I READ THE "RESOURCE" I WILL GET THE BIT VALUE BUT I AM UNAWARE WHETHER IT IS "BIT OR BYTE"...
"I DON'T WANT TO STORE ONE MORE VARIABLE FOR BYTE IN XCORE".
CAN ANYONE HELP ME OUT WITH THIS PROBLEM ? OR ANY BETTER SUGGESTIONS FOR THIS ??
Thanks in advance ! Smile
Re: XCORE and XTEXT Grammar [message #1078612 is a reply to message #1078570] Sat, 03 August 2013 04:35 Go to previous messageGo to next message
Arshad,
Comments below.
On 03/08/2013 9:04 AM, Arshad Adavani wrote:
> class Sample{
> Integer bit
> And my grammar:
> Sample:
> 'Sample'....
> FOR THIS ??
If I understand correctly, your model has no way to record or to know
whether you've represented the value in the grammar as bit or byte. So,
given just an instance of a Sample with a field of type Integer (why not
use int?) you'd have no way to know how that should be serialized
according to your grammar as either a BIT or a BYTE. You need something
else in your model to record such information, e.g., a boolean field or
an enum field for recording the BIT verses BYTE keyword.
Thanks in advance !
Re: XCORE and XTEXT Grammar [message #1078640 is a reply to message #1078612] Sat, 03 August 2013 05:42 Go to previous messageGo to next message
First of all thanks for your reply. Yes I can use a boolean field in my xcore and use it. But when i type in my xtext editor i will have to type that boolean value also, HOW DO I AVOID IT?
And, when i type either 'bit 8' or 'byte 1' in my dsl file, HOW DO I MAKE SURE THAT THE VALUE OF BOOLEAN IS SET PROPERLY IN THE BACKGROUND ??
Re: XCORE and XTEXT Grammar [message #1078647 is a reply to message #1078640] Sat, 03 August 2013 05:59 Go to previous messageGo to next message
what about
('BIT' bit=INT | 'BYTE' bit=BYTE ) ;
BYTE: INT;
and a custom ivalueconverter for BYTE
Re: XCORE and XTEXT Grammar [message #1078658 is a reply to message #1078647] Sat, 03 August 2013 06:20 Go to previous messageGo to next message
Hi Christian,
Thanks a lot for your reply:)
Actually I am new to xtext so exploring the things now.
I will definitely try with your suggestion.Smile
Re: XCORE and XTEXT Grammar [message #1079821 is a reply to message #1078647] Mon, 05 August 2013 01:51 Go to previous messageGo to next message
Hello Christian,
I tried with this:
BYTE: INT;
But it gives me:
"Cannot find compatible feature bit in sealed EClass Sample from imported package http://somepath: The existing feature 'bit' has an incompatible type 'EIntegerObject' [java.lang.Integer]. The expected type is 'Byte'."
Any suggestions from anyone?
Thanks in advance! Smile
Re: XCORE and XTEXT Grammar [message #1079860 is a reply to message #1079821] Mon, 05 August 2013 03:03 Go to previous messageGo to next message
Arshad,
These are Xtext questions best asked on the Xtext forum.
On 05/08/2013 7:51 AM, Arshad Adavani wrote:
> Hello Christian,
> I tried with this:
> BYTE: INT;
> But it gives me: "Cannot find compatible feature bit in sealed EClass
> Thanks in advance! :)
Re: XCORE and XTEXT Grammar [message #1146514 is a reply to message #1079860] Sun, 20 October 2013 03:36 Go to previous messageGo to next message
Dear All,
I need your favor or suggestion regarding migrate the xtext version from 1.0.1 to 2.3.0 in custom application.
I followed all following process for migrate the xtext version.
1. Delete the old plug-ins and update the latest plug-ins in target platform.
2. Update the Plug-in Dependencies and Import Statements.
3. Introduction of the Qualified Name.
4. Changes in the index and in find references.
5. Rewritten Node Model.
6. AutoEditStrategy.
7. Other Noteworthy API Changes
To consider the above steps, I started the work with Eclipse-4.2, Which has a xtext-2.3.0 dependency. Successfully I completed the all above steps and removed the compilation error.
Problem: After that I start the testing and getting below error Messages:
[XtextLinkingDiagnostic: null:6 Couldn't resolve reference to Material 'MPS_RECUR'.,
XtextLinkingDiagnostic: null:9 Couldn't resolve reference to Cstic 'NUM_OF_ALLOC'.,
XtextLinkingDiagnostic: null:15 Couldn't resolve reference to Cstic 'INSTANCE_NUM'.,
XtextLinkingDiagnostic: null:14 Couldn't resolve reference to Class 'ALLOC'.]
Re: XCORE and XTEXT Grammar [message #1146916 is a reply to message #1146514] Sun, 20 October 2013 09:55 Go to previous message
Did you mean to post this on Xtext's eclipse.tmf forum?
On 20/10/2013 9:36 AM, Hirdesh Agrawal wrote:
> Dear All,
> platform.
> 'MPS_RECUR'., XtextLinkingDiagnostic: null:9 Couldn't resolve
> reference to Cstic 'NUM_OF_ALLOC'., XtextLinkingDiagnostic: null:15
> 'ALLOC'.]
Previous Topic:[texo] [teneo]? Support for opposites
Next Topic:Undo throws 'no duplicates' constraint in eclipse juno
Current Time: Sat Jul 26 20:45:48 EDT 2025
Powered by FUDForum. Page generated in 0.06591 seconds
