Home » Archived » Jubula » Object Mapping not working for an SWT application
Object Mapping not working for an SWT application [message #1078100] Fri, 02 August 2013 10:36 Go to next message
I am attempting to produce tests cases for a standalone SWT app (not an eclipse plugin).
I am starting the AUT with a shell script and I manage to start it with out any problems.
Here is the content of the script I use to run the application:
#!/bin/bash
java -XstartOnFirstThread -jar target/user-agent-multiplatform-S31-SNAPSHOT.jar
But when I start the Object Mapping Mode to create the object map I don't see the supposed green highlight arround buttons or textfields when moving around with the mouse.
I am using Mac OS on the most recent release of Jubula.
Perhaps I am missing something?
EDIT: Also I can't capture elements.
[Updated on: Fri, 02 August 2013 11:40] by Moderator
Re: Object Mapping not working for an SWT application [message #1078575 is a reply to message #1078100] Sat, 03 August 2013 03:16 Go to previous messageGo to next message
Sorry, but SWT is not supported on MacOS. The problem is the startOnFirstThread which makes it impossible to prepare the AUT (which happens on a thread) before starting up.
Achim
Re: Object Mapping not working for an SWT application [message #1080120 is a reply to message #1078100] Mon, 05 August 2013 09:44 Go to previous message
Thank you,
I guess I missed that in the documentation.
Thanks again.
Previous Topic:Eclipse Testing Day 2013
Next Topic:Select multiple entry in a tree
Current Time: Mon Jul 28 17:48:22 EDT 2025
Powered by FUDForum. Page generated in 1.04777 seconds
