Home » Archived » Test and Performance Tools Platform (TPTP) » Can't run JUnit test with TPTP
Can't run JUnit test with TPTP [message #107111] |
Thu, 02 August 2007 00:24  |
I have JUnit tests which extends my own base class which extends TestCase.
I imported them in TPTP and that created a .testsuite file. However, I
can't run any of these, it "deploys" but never finishes. CPU goes 100% and
stay there.
Any idea why this occurs? Anything I need to setup?
Re: Can't run JUnit test with TPTP [message #107806 is a reply to message #107751] |
Wed, 08 August 2007 07:09   |
Hi Etienne,
The Integrated Agent Controller (IAC) is an embedded Agent Controller in
Eclipse. The user does not need to install, configure, start, and stop the
IAC. Profiling, log importing, monitoring, and test execution all use the
IAC/Agent Controller.
I believe your problem is with using Java 1.6 since TPTP 4.4 only
supports Java 1.4.x and 1.5.x (see
http://www.eclipse.org/tptp/home/project_info/releaseinfo/4. 4/support.html).
Can you try Java 1.5? If this is in fact the problem, we will still need to
open a defect to ensure this use case is supported in TPTP 4.5.
Paul
"Etienne Lacombe" <etiennel@scientology.net> wrote in message
news:926a53239f45ac911df1b917554c49cb$1@www.eclipse.org...
> Using Sun JVM 1.6
> on Win XP Pro
> I guess I'm using IAC, I don't do anything special, just run the
> test. So I guess it is using the integrated one (that's what IAC is
> rigth?).
> So even just to run a test without profiling it uses the agent
> controller?
> Thanks for your help.
> Etienne
> Paul Slauenwhite wrote:
>> Hi Etienne,
>> Let me see if I can replicate your environment. What JRE
>> version/vendor? What OS? Are you using the IAC or Agent Controller?
>> Paul
>> "Paul Slauenwhite" <paules@ca.ibm.com> wrote in message
>> news:f8samm$sq5$1@build.eclipse.org...
>>> Hi Etienne,
>>> What version of TPTP are you using? Can you run a 'regular' JUnit
>>> (e.g. does not extend your own base class)? Attach your test suite and
>>> I will debug further.
>>> Paul
>>> news:89a2a534104311b06a654163a4a3f807$1@www.eclipse.org...
>>>>TestCase. I imported them in TPTP and that created a .testsuite file.
>>>>However, I can't run any of these, it "deploys" but never finishes. CPU
>>>>goes 100% and stay there.
Re: Can't run JUnit test with TPTP [message #107838 is a reply to message #107777] |
Wed, 08 August 2007 07:24   |
Hi Etienne,
As noted in
http://www.eclipse.org/tptp/home/archives/hyades/execution_e nvironment/Launch_A_Test_On_A_Specified_Node.html,
the test harness is deploying the test assets (test suite, etc.) and their
dependencies to the System Under Test (SUT) - local in this case (see
http://help.eclipse.org/help32/topic/org.eclipse.hyades.test .doc.user/ref/rdeploymentGroundRules.htm).
The test runner (running in the Agent Controller on the SUT), executes the
test and sends the execution results back to the launching workbench. Given
the percentage of the hang, I would assume it is hanging at the deployment
stage.
As I mentioned in the previous post, using Java 1.5 should remedy the
problem since I can reproduce the problem with the IBM JRE 1.6.
Paul
news:00140237d497a9725693bdf0988a56ea$1@www.eclipse.org...
> Paul, if you could explain me what it does / try to do when I run the
> test, then maybe I can track down what the problem is. As I said earlier,
> it jam always at the same % in the progress indicator...
> Etienne
Re: Can't run JUnit test with TPTP [message #107852 is a reply to message #107806] |
Wed, 08 August 2007 07:29   |
Hi Etienne,
I can reproduce the problem with the IBM JRE 1.6. I have opened defect
https://bugs.eclipse.org/bugs/show_bug.cgi?id=199237 to address this in TPTP
4.5.
Paul
news:f9c88r$ppe$1@build.eclipse.org...
> Hi Etienne,
> in Eclipse. The user does not need to install, configure, start, and stop
> the IAC. Profiling, log importing, monitoring, and test execution all use
> the IAC/Agent Controller.
> to open a defect to ensure this use case is supported in TPTP 4.5.
> Paul
>> Using Sun JVM 1.6
>> on Win XP Pro
>> rigth?).
>> controller?
>> Etienne
>>> Hi Etienne,
>>> Paul
>>>> Hi Etienne,
>>>> Paul
Re: Can't run JUnit test with TPTP [message #108129 is a reply to message #107969] |
Thu, 09 August 2007 06:43  |
Hi Etienne,
If you are using 1.6 API, unfortunately you cannot compile and run with
different Java versions. When the test is executed, the Eclipse JRE is used
by the IAC to execute the JUnit test class.
Although Java 1.6 is not yet supported, we will attempt to investigate
this defect in 4.4.1 since this is a core use case.
Paul
news:7312b421e283163bcf68e10c22d2e1a5$1@www.eclipse.org...
> Thanks helping me on this. Unfortunately, I don't know how I can use Java
> 1.5 since the code is expected to be 1.6. --- unless you just mean running
> Eclipse against 1.5 and that I can assign 1.6 to my project?
Current Time: Wed Jul 23 06:47:19 EDT 2025
Powered by FUDForum. Page generated in 0.04278 seconds
