Home » Newcomers » Newcomers » java.lang.NullPointerException(java.lang.NullPointerException when launching)
java.lang.NullPointerException [message #1078062] Fri, 02 August 2013 09:40 Go to next message
I am getting the following error when I launch in eclipse. I am using java 1.6, eclipse juno. Any suggestions??
osgi> java.lang.NullPointerException
at com.qvc.distribution.app.preprocessor.ui.handlers.InteractiveSplashHandler.init(InteractiveSplashHandler.java:138)
at org.eclipse.ui.internal.Workbench$6.run(Workbench.java:606)
at org.eclipse.ui.internal.Workbench.createSplashWrapper(Workbench.java:622)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2250)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
at com.qvc.distribution.app.preprocessor.ui.Application.start(Application.java:35)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
Re: java.lang.NullPointerException [message #1078110 is a reply to message #1078062] Fri, 02 August 2013 10:55 Go to previous messageGo to next message
You are actually launching a custom application built on the Eclipse Platform. You should contact whomever owns the com.qvc.distribution.app* packages.
Re: java.lang.NullPointerException [message #1078121 is a reply to message #1078110] Fri, 02 August 2013 11:10 Go to previous message
Thanks for the reply.
Previous Topic:JGIT Pull NoHeadException
Next Topic:How to sequence timerexecs in display swt
Current Time: Fri Oct 31 00:06:54 EDT 2025
Powered by FUDForum. Page generated in 0.07886 seconds
