Home » Eclipse Projects » Equinox » same osgi application in differnt tomcat contexts
same osgi application in differnt tomcat contexts [message #107769] Wed, 09 April 2008 04:24 Go to next message
Originally posted by: christian.wiedemann.key-tec.de
i want to use the same osgi equinox application in the same tomcat in
differnt tomcat context. Each customer should get his own application with
differnt configuration.
So the question is. is there allways the same osgi framework in the
background or for each tomcat context an own osgi framework? Or how to deal
with this point?
thanks
Christian
Re: same osgi application in differnt tomcat contexts [message #107811 is a reply to message #107769] Wed, 09 April 2008 11:36 Go to previous messageGo to next message
Hi Christian,
If you're using the servletbridge then each webapp gets its own "private"
instance of Equinox so there is no sharing across frameworks.
There is early talk at the OSGi association about providing something along
the lines of application level scoping however nothing concrete yet.
For now, I'd suggest working with a framework instance per customer/context.
HTH
-Simon
"Christian Wiedemann" <christian.wiedemann@key-tec.de> wrote in message
news:fthug4$nj6$1@build.eclipse.org...
> deal with this point?
> thanks
> Christian
Re: same osgi application in differnt tomcat contexts [message #107823 is a reply to message #107811] Wed, 09 April 2008 12:31 Go to previous messageGo to next message
thanks fort he answer. Yes i use the servlet bridge. how can i access each
equinox framework from console (or somehow else).
"ss" lists all bundles once. an bundle with the same version is just shown
once. So how can i control(start/stop) an bundle in an framework?
thanks a lot
Christian
"Simon Kaegi" <simon_kaegi@ca.ibm.com> schrieb im Newsbeitrag
news:ftinqe$ko7$1@build.eclipse.org...
> Hi Christian,
> along the lines of application level scoping however nothing concrete yet.
> customer/context.
> HTH
> -Simon
>> Hi,
>> with differnt configuration.
>> thanks
>> Christian
Re: same osgi application in differnt tomcat contexts [message #107834 is a reply to message #107823] Wed, 09 April 2008 14:26 Go to previous message
The consoles are also independent. By default the console work of
stdin/stdout.
If you want to use the console with more than one instance of Equinox
started use a different port eg. "-console 777" for each instance.
-Simon
news:ftir20$nh2$1@build.eclipse.org...
> thanks a lot
> Christian
>> Hi Christian,
>> yet.
>> customer/context.
>> HTH
>> -Simon
>>> Hi,
>>> thanks
>>> Christian
Previous Topic:Equinox base Application/Applet
Next Topic:Deploying Bridge.war on Tomcat
Current Time: Sun Nov 09 05:53:58 EST 2025
Powered by FUDForum. Page generated in 0.04796 seconds
