Home » Modeling » TMF (Xtext) » Error when running mwe2 on xcore-based xtext project(ERROR ipse.xtext.generator.LanguageConfig - Error loading 'platform:/resource/com.telcordia.granite.sdk.validation.gevl/model/Gevl.xcore': [XtextLinkingDiagnostic: null:1 Couldn't resolve reference t)
Error when running mwe2 on xcore-based xtext project [message #1077509] Thu, 01 August 2013 16:32 Go to next message
In trying to use an Xcore model for an Xtext project, I'm getting the following error message when attempting to run the mwe2 workflow:
[XtextLinkingDiagnostic: null:1 Couldn't resolve reference to XAnnotationDirective 'Ecore'.,
 XtextLinkingDiagnostic: null:2 Couldn't resolve reference to XAnnotationDirective 'GenModel'.]
The Xcore editor works fine, and generation from Xcore works fine - it's just the mwe2 step that fails. The relevant bits of the mwe2 read:
Workflow {
    bean = StandaloneSetup {
		scanClassPath  = true
		platformUri = "${runtimeProject}/.."
    component = Generator {
		language = auto-inject {
			loadedResource = "platform:/resource/com.telcordia.granite.sdk.validation.gevl/model/Gevl.xcore"
This is using the Kepler release.
The dependencies read:
Require-Bundle: org.eclipse.xtext;visibility:=reexport,
 org.eclipse.xtext.xbase;resolution:=optional;visibility:=reexport,
 org.eclipse.xtext.generator;resolution:=optional,
 org.apache.commons.logging;bundle-version="1.0.4";resolution:=optional,
 org.eclipse.emf.codegen.ecore;resolution:=optional,
 org.eclipse.emf.mwe.utils;resolution:=optional,
 org.eclipse.emf.mwe2.launch;resolution:=optional,
 org.eclipse.xtext.util,
 org.antlr.runtime,
 org.eclipse.xtext.common.types,
 com.telcordia.granite.sdk.tools;bundle-version="1.0.0",
 org.eclipse.core.runtime,
 org.eclipse.emf.ecore;visibility:=reexport,
 org.eclipse.emf.ecore.xcore.lib,
 org.eclipse.emf.ecore.xcore,
 org.eclipse.xtext.xbase.lib;visibility:=reexport
Any idea of what might be wrong?
[Updated on: Thu, 01 August 2013 16:44] by Moderator
Re: Error when running mwe2 on xcore-based xtext project [message #1077552 is a reply to message #1077509] Thu, 01 August 2013 17:48 Go to previous messageGo to next message
here is my working manifest
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: org.xtext.example.mydsl
Bundle-Vendor: My Company
Bundle-Version: 1.0.0.qualifier
Bundle-SymbolicName: org.xtext.example.mydsl; singleton:=true
Bundle-ActivationPolicy: lazy
 test.xcore;bundle-version="0.1.0",
 org.eclipse.emf.ecore,
 org.eclipse.emf.common,
 org.antlr.runtime,
 org.eclipse.emf.codegen.ecore.xtext;bundle-version="1.0.0",
 org.eclipse.emf.ecore.xcore;bundle-version="1.1.0",
 org.eclipse.xtext.ecore;bundle-version="2.4.2"
Import-Package: org.apache.log4j,
Bundle-RequiredExecutionEnvironment: J2SE-1.5
Export-Package: org.xtext.example.mydsl,
 org.xtext.example.mydsl.services,
 org.xtext.example.mydsl.serializer,
 org.xtext.example.mydsl.parser.antlr,
 org.xtext.example.mydsl.parser.antlr.internal,
 org.xtext.example.mydsl.validation,
 org.xtext.example.mydsl.scoping,
 org.xtext.example.mydsl.generator,
 org.xtext.example.mydsl.formatting
Re: Error when running mwe2 on xcore-based xtext project [message #1077555 is a reply to message #1077552] Thu, 01 August 2013 17:52 Go to previous messageGo to next message
and here the part of the workflow
loadedResource = "platform:/resource/org.eclipse.emf.ecore.xcore.lib/model/XcoreLang.xcore"
    		loadedResource = "platform:/resource/test.xcore/model/test.xcore"
Re: Error when running mwe2 on xcore-based xtext project [message #1077807 is a reply to message #1077555] Fri, 02 August 2013 03:00 Go to previous messageGo to next message
Christian,
Yes, the problem sounds like one of not being able to locate
XcoreLang.xcore which contains the built-in annotations definitions:
package xcore.lang
annotation "http://www.eclipse.org/emf/2002/Ecore" as Ecore
annotation "http:///org/eclipse/emf/ecore/util/ExtendedMetaData" as
ExtendedMetaData
annotation "http://www.eclipse.org/emf/2002/GenModel" as GenModel
> loadedResource =
> loadedResource =
Re: Error when running mwe2 on xcore-based xtext project [message #1078135 is a reply to message #1077807] Fri, 02 August 2013 11:28 Go to previous messageGo to next message
Confirmed - adding the extra loadedResource did the trick. Thanks much.
Should I bugzilla this, or do you (Ed?) want to, or is it working as designed?
I thought XcoreLang.xcore was supposed to be included by default - but you'd know better.
Re: Error when running mwe2 on xcore-based xtext project [message #1078539 is a reply to message #1078135] Sat, 03 August 2013 01:59 Go to previous messageGo to next message
Ed,
I'm not sure it's supposed to be included by default. I'm not even sure
if workflows have defaults or where/how such a thing would need to be
specified to be a default. The Xtext team is in the best position to
comment on that...
> designed?
> you'd know better.
Re: Error when running mwe2 on xcore-based xtext project [message #1272624 is a reply to message #1078539] Tue, 18 March 2014 07:02 Go to previous messageGo to next message
I am experimenting the same problem. Could you please tell me how and where can I add your solution?
Simone
Re: Error when running mwe2 on xcore-based xtext project [message #1273808 is a reply to message #1272624] Thu, 20 March 2014 11:16 Go to previous message
On 18/03/2014 12:02, Simone Di Cola wrote:
I experienced some problems too, especially due to my DSL using also
Xbase; if you're interested, mwe2 now works for me, you may have a look
here:
https://github.com/LorenzoBettini/xsemantics/tree/master/plugins/it.xsemantics.dsl
I'm planning to write a blog post on a smaller example, but I don't have
time right now :)
hope this helps
Lorenzo
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
Previous Topic:Xtext artifact generation from Ecore model fails when Ecore model refers to another model.
Next Topic:mwe2 fragment documentation
Current Time: Fri Jul 25 09:56:44 EDT 2025
Powered by FUDForum. Page generated in 1.09755 seconds
