Home » Modeling » EMF » Refactor URI to separate bundle?
Refactor URI to separate bundle? [message #1077286] Thu, 01 August 2013 09:43 Go to next message
Hi Ed,
What do you think about the possibility of refactoring URI into it's own bundle? The features of URI are so nice that I'd like to use it in projects that do not depend on EMF. I know that I can just use the emf.common bundle without the rest of EMF, but it drags in the runtime bundle which in turn drags in lots of other unnecessary stuff.
I might be willing to do the work if you think this is even possible. I had two initial thoughts on this: a split package which I know is not the best, or turning the existing URI code into a facade on top of the real implementation in another bundle.
Bryan
Re: Refactor URI to separate bundle? [message #1077293 is a reply to message #1077286] Thu, 01 August 2013 09:53 Go to previous messageGo to next message
Bryan,
Comments below.
On 01/08/2013 3:43 PM, Bryan Hunt wrote:
> Hi Ed,
You're wanting to use this outside of an Eclipse environment? In that
case, the org.eclipse.core.runtime isn't needed for it to work stand
alone and the 350K jar size is irrelevant except perhaps for micro
devices. If not, org.eclipse.core.runtime seems like a minimal
dependency already...
In the 2.9 release, there are a number of other dependencies, e.g., the
data structures used for interning the instances and interning the
strings used by the instances...
Both sound kind of horrible!
> Bryan
Re: Refactor URI to separate bundle? [message #1077297 is a reply to message #1077293] Thu, 01 August 2013 09:59 Go to previous messageGo to next message
Ed Merks wrote on Thu, 01 August 2013 08:53
I want to use it in an OSGi environment, so the dependency on runtime is a big deal especially if you are working on an embedded device such as a RaspberryPI or are working with another runtime such as Felix.
Another thought I had is to move all of the things that depend on runtime to a fragment.
Re: Refactor URI to separate bundle? [message #1077305 is a reply to message #1077297] Thu, 01 August 2013 10:10 Go to previous messageGo to next message
Bryan Hunt wrote on Thu, 01 August 2013 08:59
I had another look at the code and see that CommonPlugin$Implementation extends EclipsePlugin which ties the activator to the runtime bundle. Fragments don't have an activator, so that Idea won't work. I guess I'll just stick with doing things the hard way.
Re: Refactor URI to separate bundle? [message #1077309 is a reply to message #1077297] Thu, 01 August 2013 10:12 Go to previous messageGo to next message
Bryan,
So another approach is to rebundle the jar itself so that it's treated
as a non-OSGi jar such that any Equinox dependencies are irrelevant.
Then it just comes down to the 350K jar size. So is that in and of
itself a concern? If so, even the .class files themselves could be
selectively extracted and rejarred...
>> that case, the org.eclipse.core.runtime isn't needed for it to work
>> stand alone and the 350K jar size is irrelevant except perhaps for
>> micro devices. If not, org.eclipse.core.runtime seems like a minimal
Re: Refactor URI to separate bundle? [message #1077314 is a reply to message #1077309] Thu, 01 August 2013 10:21 Go to previous messageGo to next message
Ed Merks wrote on Thu, 01 August 2013 09:12
The jar size is not currently a concern. The concern is strictly:
Require-Bundle: org.eclipse.core.runtime
Bundle-Activator: org.eclipse.emf.common.CommonPlugin$Implementation
Repackaging the .class file into it's own OSGi bundle would work until you wanted to use it with EMF. You could possibly get away with changing the package version on the new bundle, but I think there's still a risk of a runtime linkage error.
Re: Refactor URI to separate bundle? [message #1077336 is a reply to message #1077314] Thu, 01 August 2013 10:55 Go to previous message
Bryan,
Comments below.
>> treated as a non-OSGi jar such that any Equinox dependencies are
>> irrelevant. Then it just comes down to the 350K jar size. So is
>> that in and of itself a concern? If so, even the .class files
>> themselves could be selectively extracted and rejarred...
So repacking helps with that.
Yes, and depending on which parts of EMF you use, you really start to
need things like the plugin.xml registrations, and access to resources
via the activator...
Yes.
Previous Topic:[CDO - MySQL] java.util.concurrent.TimeoutException
Next Topic:Strange behavior with substitution groups
Current Time: Wed Jul 23 11:40:42 EDT 2025
Powered by FUDForum. Page generated in 0.32323 seconds
