Refactor URI to separate bundle? [message #1077286] |
Thu, 01 August 2013 09:43  |
Hi Ed,
What do you think about the possibility of refactoring URI into it's own bundle? The features of URI are so nice that I'd like to use it in projects that do not depend on EMF. I know that I can just use the emf.common bundle without the rest of EMF, but it drags in the runtime bundle which in turn drags in lots of other unnecessary stuff.
I might be willing to do the work if you think this is even possible. I had two initial thoughts on this: a split package which I know is not the best, or turning the existing URI code into a facade on top of the real implementation in another bundle.
Bryan
Re: Refactor URI to separate bundle? [message #1077293 is a reply to message #1077286] |
Thu, 01 August 2013 09:53   |
Bryan,
Comments below.
On 01/08/2013 3:43 PM, Bryan Hunt wrote:
> Hi Ed,
You're wanting to use this outside of an Eclipse environment? In that
case, the org.eclipse.core.runtime isn't needed for it to work stand
alone and the 350K jar size is irrelevant except perhaps for micro
devices. If not, org.eclipse.core.runtime seems like a minimal
dependency already...
In the 2.9 release, there are a number of other dependencies, e.g., the
data structures used for interning the instances and interning the
strings used by the instances...
Both sound kind of horrible!
> Bryan
Re: Refactor URI to separate bundle? [message #1077336 is a reply to message #1077314] |
Thu, 01 August 2013 10:55  |
Bryan,
Comments below.
On 01/08/2013 4:21 PM, Bryan Hunt wrote:
> Ed Merks wrote on Thu, 01 August 2013 09:12
>> So another approach is to rebundle the jar itself so that it's
>> treated as a non-OSGi jar such that any Equinox dependencies are
>> irrelevant. Then it just comes down to the 350K jar size. So is
>> that in and of itself a concern? If so, even the .class files
>> themselves could be selectively extracted and rejarred...
> The jar size is not currently a concern. The concern is strictly:
> Require-Bundle: org.eclipse.core.runtime
> Bundle-Activator: org.eclipse.emf.common.CommonPlugin$Implementation
So repacking helps with that.
> Repackaging the .class file into it's own OSGi bundle would work until
> you wanted to use it with EMF.
Yes, and depending on which parts of EMF you use, you really start to
need things like the plugin.xml registrations, and access to resources
via the activator...
> You could possibly get away with changing the package version on the
> new bundle, but I think there's still a risk of a runtime linkage error.
Yes.
FUDForum. Page generated in 0.09270 seconds
