Home » Modeling » EMF » [CDO - MySQL] java.util.concurrent.TimeoutException(Connectivity issue with MySQL adapter for CDO)
[CDO - MySQL] java.util.concurrent.TimeoutException [message #1075378] Mon, 29 July 2013 06:23 Go to next message
To whom it may concern,
I am trying to configure CDO-MySQL to a new installation of Kepler (With Eclipse Modeling Tools).
I am able to run the client + server as per the tutorial (http://wiki.eclipse.org/CDO/User_Contributed_Documentation - An Introduction to CDO 4.0 (by Vincenzo Caselli, RCPVision)) but when I try to commit a transaction (even one with only a single model element in it, either using the CDO session UI, or programmatically) I get:
org.eclipse.emf.cdo.common.util.TransportException: java.util.concurrent.TimeoutException
	at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtocol.send(CDOClientProtocol.java:526)
	at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtocol.commitTransaction(CDOClientProtocol.java:393)
	at org.eclipse.emf.internal.cdo.session.DelegatingSessionProtocol.commitTransaction(DelegatingSessionProtocol.java:292)
	at org.eclipse.emf.internal.cdo.transaction.CDOSingleTransactionStrategyImpl.commit(CDOSingleTransactionStrategyImpl.java:72)
	at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.commit(CDOTransactionImpl.java:1191)
	at org.eclipse.emf.cdo.internal.ui.editor.CDOEditor$22.run(CDOEditor.java:1845)
	at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
Caused by: java.util.concurrent.TimeoutException
	at org.eclipse.net4j.util.io.IOTimeoutException.createTimeoutException(IOTimeoutException.java:46)
	at org.eclipse.net4j.signal.Signal.runSync(Signal.java:257)
	at org.eclipse.net4j.signal.SignalProtocol.startSignal(SignalProtocol.java:442)
	at org.eclipse.net4j.signal.RequestWithConfirmation.doSend(RequestWithConfirmation.java:89)
	at org.eclipse.net4j.signal.RequestWithConfirmation.send(RequestWithConfirmation.java:75)
	at org.eclipse.net4j.signal.RequestWithMonitoring.send(RequestWithMonitoring.java:110)
	at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtocol.send(CDOClientProtocol.java:518)
	... 6 more
Caused by: org.eclipse.net4j.util.io.IOTimeoutException
	at org.eclipse.net4j.buffer.BufferInputStream.computeTimeout(BufferInputStream.java:216)
	at org.eclipse.net4j.buffer.BufferInputStream.ensureBuffer(BufferInputStream.java:189)
	at org.eclipse.net4j.buffer.BufferInputStream.read(BufferInputStream.java:116)
	at java.io.DataInputStream.readBoolean(Unknown Source)
	at org.eclipse.net4j.util.io.ExtendedDataInput$Delegating.readBoolean(ExtendedDataInput.java:60)
	at org.eclipse.emf.cdo.internal.net4j.protocol.CommitTransactionRequest.confirmingCheckError(CommitTransactionRequest.java:304)
	at org.eclipse.emf.cdo.internal.net4j.protocol.CommitTransactionRequest.confirming(CommitTransactionRequest.java:290)
	at org.eclipse.emf.cdo.internal.net4j.protocol.CommitTransactionRequest.confirming(CommitTransactionRequest.java:1)
	at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientRequestWithMonitoring.confirming(CDOClientRequestWithMonitoring.java:117)
	at org.eclipse.net4j.signal.RequestWithMonitoring.confirming(RequestWithMonitoring.java:171)
	at org.eclipse.net4j.signal.RequestWithConfirmation.doExtendedInput(RequestWithConfirmation.java:125)
	at org.eclipse.net4j.signal.Signal.doInput(Signal.java:328)
	at org.eclipse.net4j.signal.RequestWithConfirmation.doExecute(RequestWithConfirmation.java:105)
	at org.eclipse.net4j.signal.RequestWithMonitoring.doExecute(RequestWithMonitoring.java:235)
	at org.eclipse.net4j.signal.SignalActor.execute(SignalActor.java:53)
	at org.eclipse.net4j.signal.Signal.runSync(Signal.java:253)
	... 11 more
In case it is of use, the server initializes normally with:
[INFO] CDO server starting
!SESSION 2013-07-29 10:59:44.943 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_25
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_GB
Framework arguments:  -product org.eclipse.emf.cdo.server.product.tcp_h2
Command-line arguments:  -product org.eclipse.emf.cdo.server.product.tcp_h2 -data D:\workspace-cdo/../runtime-CDO-Server.product -dev file:D:/workspace-cdo/.metadata/.plugins/org.eclipse.pde.core/CDO-Server.product/dev.properties -os win32 -ws win32 -arch x86_64 -consoleLog
!ENTRY org.eclipse.emf.cdo.server 1 0 2013-07-29 10:59:45.565
!MESSAGE CDO server starting
[WARN] Detected crash of repository demo
!ENTRY org.eclipse.emf.cdo.server.db 2 0 2013-07-29 10:59:46.087
!MESSAGE Detected crash of repository demo
[INFO] Repaired crash of repository demo: lastObjectID=OID2, nextLocalObjectID=OID9223372036854775807, lastBranchID=0, lastCommitTime=1,374,766,710,269, lastNonLocalCommitTime=1,374,766,710,269
!ENTRY org.eclipse.emf.cdo.server.db 1 0 2013-07-29 10:59:46.101
!MESSAGE Repaired crash of repository demo: lastObjectID=OID2, nextLocalObjectID=OID9223372036854775807, lastBranchID=0, lastCommitTime=1,374,766,710,269, lastNonLocalCommitTime=1,374,766,710,269
[INFO] Net4j extension starting
!ENTRY org.eclipse.emf.cdo.server.net4j 1 0 2013-07-29 10:59:46.288
!MESSAGE Net4j extension starting
[INFO] Net4j extension started
!ENTRY org.eclipse.emf.cdo.server.net4j 1 0 2013-07-29 10:59:46.318
!MESSAGE Net4j extension started
[INFO] CDO server started
!ENTRY org.eclipse.emf.cdo.server 1 0 2013-07-29 10:59:46.319
!MESSAGE CDO server started
Computer Software Setup:
Windows 7 - 64bit
Eclipse Modeling Tools 2.0.0.20130613-0530
with: CDO Model Repository EPP 4.2.0.v20130613-1556
using: Net4j DB Framework MYSQL Adapter 4.2.0.v20130601-1611
running: MySQL server 5.5
Config file (cdo-server.xml):
<cdoServer>
    <acceptor type="tcp" listenAddr="0.0.0.0" port="2038">
    </acceptor>
    <repository name="demo">
        <store type="db">
            <mappingStrategy type="horizontal"/>
            <dbAdapter name="mysql"/>
            <dataSource
                class="com.mysql.jdbc.jdbc2.optional.MysqlDataSource"
                url="jdbc:mysql://localhost:2038/cdotest?createDatabaseIfNotExist=true"
                user="root"
                password="admin"
                <property name="drop" value="true"/>
        </store>
    </repository>
</cdoServer>
As far as I understand this may be due to an error in communication of the CDO client to the CDO server (unless the server initializes normally but then cannot communicate with the MySQL service). In either case, I do not know how to proceed to solve this.
Please let me know if you need any more diagnostics,
Thank you in advance for any help or pointers to solutions,
Yours faithfully,
Re: [CDO - MySQL] java.util.concurrent.TimeoutException [message #1075396 is a reply to message #1075378] Mon, 29 July 2013 06:56 Go to previous messageGo to next message
Am 29.07.2013 12:23, schrieb Konstantinos Barmpis:
Are you sure that server and clients use the same (versions of the) binaries?
Does the server log any warnings or exceptions at the same time?
Can you load/navigate models on your client?
Please try to add the following to the <repository> element of teh cdo-server.xml:
<property name="optimisticLockingTimeout" value="10000"/>
Does that help?
Cheers
/Eike
http://www.esc-net.de
> at
> at
> ... 6 more
> at
> at
> ... 11 more
> Windows 7 - 64bit
> <cdoServer>
> </acceptor>
> <store type="db">
> <dataSource
> user="root"
> password="admin"
> </store>
> </repository>
> </cdoServer>
> Yours faithfully,
Re: [CDO - MySQL] java.util.concurrent.TimeoutException [message #1075571 is a reply to message #1075396] Mon, 29 July 2013 12:55 Go to previous messageGo to next message
Thank you for your prompt response:
There seems to be no communication at all happening.
I cannot commit any changes so cannot test any model loading or navigation.
Using the CDO Session UI I can virtually add model elements (and nest/navigate them from the editor) but then cannot persist them.
I have added this, and also a similar line in the client app, doesn't seem to help.
For now I am working with the embedded H2 store as it works as expected, but it would be nice to work with MySQL if I can resolve this.
Re: [CDO - MySQL] java.util.concurrent.TimeoutException [message #1075605 is a reply to message #1075571] Mon, 29 July 2013 14:23 Go to previous messageGo to next message
Am 29.07.2013 18:55, schrieb Konstantinos Barmpis:
Hmm, how would that be related to the chosen database type? That only makes sense if the time is really being spent in
Mysql. I wonder if you can debug/step through the server, starting with a breakpoint in
Repository.commit(InternalCommitContext, OMMonitor)...
Cheers
/Eike
> persist them.
> can resolve this.
Re: [CDO - MySQL] java.util.concurrent.TimeoutException [message #1077175 is a reply to message #1075605] Thu, 01 August 2013 06:32 Go to previous messageGo to next message
It would seem that the issue was that both the MySQL server and the CDO server were using the same port, so even though the client could see the server, it could not actually commit data.
It got resolved simply by having them use different ports.
Nevertheless thank you for your help,
Re: [CDO - MySQL] java.util.concurrent.TimeoutException [message #1077206 is a reply to message #1077175] Thu, 01 August 2013 07:16 Go to previous message
Am 01.08.2013 12:32, schrieb Konstantinos Barmpis:
Indeed, that seems obvious :P
Cheers
/Eike
Previous Topic:change generated Validator to ensure that referenced features are valid, too
Next Topic:Refactor URI to separate bundle?
Current Time: Fri Jul 25 23:40:16 EDT 2025
Powered by FUDForum. Page generated in 0.03712 seconds
