| Java profiling on AMD64 [message #10380] |
Mon, 14 March 2005 13:51  |
Originally posted by: harsha.jagasia.amd.com
I am trying to profile a rather simple Java application as described in
one of the tutorials on the TPTP page on an AMD64 platform running 64 bit
SuSE Linux 9.1. The way I understand it java profiling needs the agent
controller to be functional.
I have installed everything listed on the TPTP page with the build
TPTP-4.0-200503071459 including the agent controller and the prerequisites
of EMF and XSD. I have also installed the Hyades Runtime, Hyades Examples
and Hyades Component Test version 3.2.0 as instructed in the "getting
started with agent controller guide". In all cases I selected the Linux
IA32 versions as I did not find x86-64 versions.
I then followed the instructions in the getting started with agent
controller guide for Linux on IA32. When I start the server by running
<unzip directory>/bin/RAServer, I get the following messages in the log.
Note the config/servicelog.log is attached below:
When I start Java profiling, it takes me to the profiling and logging
perspective and lets me select the app to profile, but then complains
Error occurred during initialization of VM
Could not find agent library on the library path or in the local
directory: piAgent
The config/servicelog.log gets appended. This data is also given below.
Please help. Has TPTP, agent controller been tested on AMD64 platforms. Is
a seperate AMD64 port needed. Is such a port being developed?
I ran into probelms even getting Eclipse oprofile to work on AMD64 while
profiling a C/C++ application?
Does eclipse have any profiling abiity for 64 bit apps C/C++ and Java on
AMD64?
1. Log after starting RAServer:
<CommonBaseEvent creationTime="2005-03-14T19:29:45.000000Z"
globalInstanceId="k235E62900060AED0BEEBF0F74C58FEF" msg="Service starting"
severity="10" version="1.0.1">
<sourceComponentId component="Data Collection Engine"
componentIdType="Application" location="127.0.0.2" locationType="IPV4"
processId="12066"
subComponent="framework/RAServerConfig/RAServerConfigBinding2.cpp "
componentType="Eclipse_TPTP"/>
<situation categoryName="ReportSituation">
<situationType xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:type="ReportSituation" reasoningScope="INTERNAL" reportCategory="LOG"/>
</situation>
</CommonBaseEvent>
globalInstanceId="k235E6290006146C5922DA5169C069EE" msg="Severe error
while parsing
file=/usr/local/raserver-eclipse-tptp/plugins/org.eclipse.hy ades.logging.parsers/config/pluginconfig.xml
line=1 column=1 message=Invalid document structure" severity="55"
version="1.0.1">
processId="12066"
subComponent="framework/RAServerConfig/RAServerConfigHandler2.cpp "
</situation>
</CommonBaseEvent>
globalInstanceId="k235E62900061C44293195137ED86BF2" msg="Failure parsing
config file" severity="55" version="1.0.1">
processId="12066"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E629000621EA19FDC23E16B4E0C7" msg="Failed to load
plugin: org.eclipse.hyades.logging.parsers" severity="30" version="1.0.1">
processId="12066"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E6290006258947091EB20D78D135" msg="Successfully
loaded plugin: org.eclipse.hyades.perfmon.jmxagent" severity="10"
version="1.0.1">
processId="12066"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E6290006267F30E56C2B0E009A99" msg="Severe error
while parsing file= line=0 column=0 message=An exception occurred!
Type:RuntimeException, Message:The primary document entity could not be
opened.
Id=/usr/local/raserver-eclipse-tptp/plugins/org.junit_3.8.1/ config/pluginconfig.xml "
processId="12066"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E6290006270B0BA4CF642596E69D" msg="Failure parsing
processId="12066"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E6290006277A1D33D0520E0973C0" msg="Failed to load
plugin: org.junit_3.8.1" severity="30" version="1.0.1">
processId="12066"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E629000628210BCB8CEC19E27EB5" msg="Severe error
opened.
Id=/usr/local/raserver-eclipse-tptp/plugins/org.eclipse.tptp .platform.models_4.0.0/config/pluginconfig.xml "
processId="12066"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E6290006288162BA8CB23E20ECE0" msg="Failure parsing
processId="12066"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E629000628D92AECC9B77A287538" msg="Failed to load
plugin: org.eclipse.tptp.platform.models_4.0.0" severity="30"
version="1.0.1">
processId="12066"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E6290006297D16679B8375C93701" msg="Severe error
opened.
Id=/usr/local/raserver-eclipse-tptp/plugins/org.eclipse.emf. ecore.xmi_2.1.0/config/pluginconfig.xml "
processId="12066"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E629000629E76F9020E875DDFD03" msg="Failure parsing
processId="12066"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E62900062A4067E4B7557BA39FD4" msg="Failed to load
plugin: org.eclipse.emf.ecore.xmi_2.1.0" severity="30" version="1.0.1">
processId="12066"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E62900062AEC015E69017CE59B2B" msg="Severe error
opened.
Id=/usr/local/raserver-eclipse-tptp/plugins/org.eclipse.core .runtime_3.1.0/config/pluginconfig.xml "
processId="12066"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E62900062B4735CAA6C476CA4014" msg="Failure parsing
processId="12066"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E62900062B9F20E1072A0AE7812B" msg="Failed to load
plugin: org.eclipse.core.runtime_3.1.0" severity="30" version="1.0.1">
processId="12066"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E62900062C44681B49DA4452EE08" msg="Severe error
opened.
Id=/usr/local/raserver-eclipse-tptp/plugins/org.apache.jakar ta_commons_logging_1.0.3/config/pluginconfig.xml "
processId="12066"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E62900062CAF51D6ED2130401836" msg="Failure parsing
processId="12066"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E62900062D085EC8E30159579625" msg="Failed to load
plugin: org.apache.jakarta_commons_logging_1.0.3" severity="30"
version="1.0.1">
processId="12066"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E62900062E441F4B4BBF3FA2AFAB" msg="Successfully
loaded plugin: org.eclipse.hyades.perfmon.linux" severity="10"
version="1.0.1">
processId="12066"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E62900062EEF3DBEB5A368403BD0" msg="Severe error
while parsing
file=/usr/local/raserver-eclipse-tptp/plugins/org.eclipse.hy ades.test/config/pluginconfig.xml
version="1.0.1">
processId="12066"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E62900062F536310A4232E3B60A7" msg="Failure parsing
processId="12066"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E62900062FC204C6B460204D0440" msg="Failed to load
plugin: org.eclipse.hyades.test" severity="30" version="1.0.1">
processId="12066"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E629000632482983817D047A58B4" msg="Successfully
loaded plugin: org.eclipse.hyades.logging.core_4.0.0" severity="10"
version="1.0.1">
processId="12066"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E629000633A2496998EB0CA2CD82" msg="Successfully
loaded plugin: org.eclipse.hyades.logging.adapter_4.0.0" severity="10"
version="1.0.1">
processId="12066"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E629000634D16922C57960E3DD9E" msg="Successfully
loaded plugin: org.eclipse.tptp.platform.log.views_4.0.0" severity="10"
version="1.0.1">
processId="12066"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E6290006365E27225F827282F396" msg="Successfully
loaded plugin: org.eclipse.hyades.logging.parsers_4.0.0" severity="10"
version="1.0.1">
processId="12066"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E629000637D1204011451F637C66" msg="Successfully
loaded plugin: org.eclipse.hyades.execution_4.0.0" severity="10"
version="1.0.1">
processId="12066"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E629000639D73C93C00874FF05B7" msg="Successfully
version="1.0.1">
processId="12066"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E62900063B2C7869754163D5F550" msg="Successfully
loaded plugin: org.eclipse.hyades.test.core_4.0.0" severity="10"
version="1.0.1">
processId="12066"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E62900063D573A7DDEC079834DB8" msg="Successfully
version="1.0.1">
processId="12066"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E62900063DFF0FD631436CE49717" msg="Severe error
opened.
Id=/usr/local/raserver-eclipse-tptp/plugins/org.eclipse.emf. ecore_2.1.0/config/pluginconfig.xml "
processId="12066"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E62900063E61649C0EA8101F2B8A" msg="Failure parsing
processId="12066"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E62900063EB827B2EF836605DB41" msg="Failed to load
plugin: org.eclipse.emf.ecore_2.1.0" severity="30" version="1.0.1">
processId="12066"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E6290006405D28F61F7062A066DA" msg="Successfully
loaded plugin: org.eclipse.tptp.platform.collection.framework_4.0.0"
processId="12066"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E629000641016746842A0FA2358D" msg="Severe error
while parsing
file=/usr/local/raserver-eclipse-tptp/plugins/org.eclipse.hy ades.datacollection/config/pluginconfig.xml
version="1.0.1">
processId="12066"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E62900064162752E51150E86B8D7" msg="Failure parsing
processId="12066"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E629000641BF062EDB7238192888" msg="Failed to load
plugin: org.eclipse.hyades.datacollection" severity="30" version="1.0.1">
processId="12066"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E62900064308428CA71F59A6F011" msg="Successfully
version="1.0.1">
processId="12066"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E629000645E52C0660790ED1D13E" msg="Successfully
version="1.0.1">
processId="12066"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E6290006475A5A99F5737429307D" msg="Successfully
version="1.0.1">
processId="12066"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E629000648F73C3CC6A80CC33C0E" msg="Successfully
loaded plugin: org.eclipse.hyades.test.tools.core_4.0.0" severity="10"
version="1.0.1">
processId="12066"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E6290006499B7AA8A0D52283F195" msg="Severe error
opened.
Id=/usr/local/raserver-eclipse-tptp/plugins/org.eclipse.emf. common_2.1.0/config/pluginconfig.xml "
processId="12066"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E629000649FC3672BFBA2F13F497" msg="Failure parsing
processId="12066"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E62900064A523A4EACFE274D7C9C" msg="Failed to load
plugin: org.eclipse.emf.common_2.1.0" severity="30" version="1.0.1">
processId="12066"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E62900064B7E14D6C86C4DB562CE" msg="Successfully
version="1.0.1">
processId="12066"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E62900064BDF273452566957CCFF" msg="Active
configuration set to: default" severity="10" version="1.0.1">
processId="12066"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E62900064ED33379D5C06056A732" msg="Loaded
configuration: default" severity="10" version="1.0.1">
processId="12066"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E62900064F057953F54F72A6D4D7" msg="Service started
successfully" severity="10" version="1.0.1">
processId="12066"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E629000650ED47F54CED48D3C816" msg="Couldn't
load JVM library %JAVA_PATH%" severity="30" version="1.0.1">
processId="12066" subComponent="framework/RAServer/java.c"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E62900065123217BF95E768F478C" msg="Could not create
file server because JVM could not be created" severity="30"
version="1.0.1">
processId="12066" subComponent="framework/RAServer/RACommS.c"
</situation>
</CommonBaseEvent>
2. Log appended to on starting Java profiling:
<CommonBaseEvent creationTime="2005-03-14T19:37:10.000000Z"
globalInstanceId="k235E7E6000C65024CA84FE66E81221D" msg="Incoming
connection request on socket 6 from 0x200007f" severity="10"
version="1.0.1">
processId="12066" subComponent="framework/RAServer/messagePump.c"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E7E6000C65CA6630899648CC2C93" msg="Notify the client
that we are ready now since security is not enabled" severity="30"
version="1.0.1">
</situation>
</CommonBaseEvent>
globalInstanceId="k235E7E6000C678C2CE908855E802DC5" msg="Connection
accepted on socket 6" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
globalInstanceId="k235E7E6000DDF18289310E22EBB9C57" msg="Attempting to
launch process : java.exe -XrunpiAgent:server=controlled
profilingExample.CarModel" severity="10" version="1.0.1">
processId="12066" subComponent="framework/RAServer/launcher.c"
</situation>
</CommonBaseEvent>
globalInstanceId="k235E7E6000E01007D56BBDE53572936" msg="Adding agent
interest: Java Profiling Agent" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-03-14T19:37:15.000000Z"
globalInstanceId="k235E7EB00081C3B7E4812F842EB6C8A" msg="Process 12188
does not exist so scrub it" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
globalInstanceId="k235E7EB00081CB138A4FE53240296A2" msg="Process 12188
exited" severity="10" version="1.0.1">
processId="12066" subComponent="framework/RAServer/util.c"
| Re: Java profiling on AMD64 [message #10771 is a reply to message #10380] |
Mon, 21 March 2005 09:15  |
The TPTP profiler (piAgent) is only capable of profiling Java applications.
The error message:
> directory: piAgent
shows that the JVM is having problem loading the shared library
"libpiAgent.so".
Is the JVM 32-bit or 64-bit? The only thing I am concerning right now is the
binary compatibility between the profiler "libpiAgent.so" and the JVM since
the profiler is compiled on the IA32 arch.
Can you try the following scenario?
1. export LD_LIBRARY_PATH=$RASERVER_HOME/lib:$LD_LIBRARY_PATH
2. export CLASSPATH=<path containing the CarModel class>
3. java -XrunpiAgent:server=standalone profilingExample.CarModel
If everything works, this will produce a standalone profile trace
"trace.trcxml".
Samson
"Harsha Jagasia" <harsha.jagasia@amd.com> wrote in message
news:d14mfr$nsd$1@www.eclipse.org...
> directory: piAgent
> AMD64?
> processId="12066"
> </situation>
> </CommonBaseEvent>
> while parsing
> version="1.0.1">
> processId="12066"
> </situation>
> </CommonBaseEvent>
> processId="12066"
> </situation>
> </CommonBaseEvent>
> processId="12066"
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
> processId="12066"
> </situation>
> </CommonBaseEvent>
> opened.
fig.xml"
> processId="12066"
> </situation>
> </CommonBaseEvent>
> processId="12066"
> </situation>
> </CommonBaseEvent>
> processId="12066"
> </situation>
> </CommonBaseEvent>
> opened.
_4.0.0/config/pluginconfig.xml"
> processId="12066"
> </situation>
> </CommonBaseEvent>
> processId="12066"
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
> processId="12066"
> </situation>
> </CommonBaseEvent>
> opened.
> processId="12066"
> </situation>
> </CommonBaseEvent>
> processId="12066"
> </situation>
> </CommonBaseEvent>
> processId="12066"
> </situation>
> </CommonBaseEvent>
> opened.
> processId="12066"
> </situation>
> </CommonBaseEvent>
> processId="12066"
> </situation>
> </CommonBaseEvent>
> processId="12066"
> </situation>
> </CommonBaseEvent>
> opened.
ng_1.0.3/config/pluginconfig.xml"
> processId="12066"
> </situation>
> </CommonBaseEvent>
> processId="12066"
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
> processId="12066"
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
> processId="12066"
> </situation>
> </CommonBaseEvent>
> while parsing
/pluginconfig.xml
> version="1.0.1">
> processId="12066"
> </situation>
> </CommonBaseEvent>
> processId="12066"
> </situation>
> </CommonBaseEvent>
> processId="12066"
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
> processId="12066"
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
> processId="12066"
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
> processId="12066"
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
> processId="12066"
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
> processId="12066"
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
> processId="12066"
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
> processId="12066"
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
> processId="12066"
> </situation>
> </CommonBaseEvent>
> opened.
> processId="12066"
> </situation>
> </CommonBaseEvent>
> processId="12066"
> </situation>
> </CommonBaseEvent>
> processId="12066"
> </situation>
> </CommonBaseEvent>
> processId="12066"
> </situation>
> </CommonBaseEvent>
> while parsing
> version="1.0.1">
> processId="12066"
> </situation>
> </CommonBaseEvent>
> processId="12066"
> </situation>
> </CommonBaseEvent>
> processId="12066"
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
> processId="12066"
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
> processId="12066"
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
> processId="12066"
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
> processId="12066"
> </situation>
> </CommonBaseEvent>
> opened.
> processId="12066"
> </situation>
> </CommonBaseEvent>
> processId="12066"
> </situation>
> </CommonBaseEvent>
> processId="12066"
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
> processId="12066"
> </situation>
> </CommonBaseEvent>
> processId="12066"
> </situation>
> </CommonBaseEvent>
> processId="12066"
> </situation>
> </CommonBaseEvent>
> processId="12066"
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
FUDForum. Page generated in 0.03760 seconds
