Home » Eclipse Projects » EclipseLink » EclipseLink MOXy: Logical operators in XmlPath annotation
EclipseLink MOXy: Logical operators in XmlPath annotation [message #1076643] Wed, 31 July 2013 13:28 Go to next message
Do logical operators work in XmlPath annotations of EclipseLink MOXy? I tried and could not make it work (no Exception is thrown and nothing is bound to "elements").
For example, I would like to have in a bindings file something like this:
    <java-type name="Content">
        <java-attributes>
           <xml-element java-attribute="elements" xml-path="/a/b/ | /c/d"
            type="ElementType" container-type="java.util.List" />
        </java-attributes>
    </java-type>
Is there a way to achieve the same result from a modification of the bindings without using the logical or in the xml-path?
I can only think of a workaround where one would use getters and settings in the domain model, bind both
/a/b
and
/c/d
to elements and have the setters append elements to the List rather then replacing the list upon each call to setElements(). I'd rather handle it in the bindings file, though.
Does there exist a place in the documentation that specifies which parts of XPath are supported in MOXy?
[Updated on: Wed, 31 July 2013 13:40] by Moderator
Re: EclipseLink MOXy: Logical operators in XmlPath annotation [message #1076675 is a reply to message #1076643] Wed, 31 July 2013 14:28 Go to previous message
Here is an example of how you could support this use case.
Mapping Document (bindings.xml)
You could use the xml-elements mapping for this use case. On each of the nested xml-element mappings you would specify a different xml-path.
<?xml version="1.0"?>
<xml-bindings
    xmlns="http://www.eclipse.org/eclipselink/xsds/persistence/oxm"
    package-name="forum17977009">
    <java-types>
            <xml-root-element/>
             <java-attributes>
                <xml-elements java-attribute="elements">
                    <xml-element xml-path="a/b"/>
                    <xml-element xml-path="c/d"/>
                </xml-elements>
             </java-attributes>
        </java-type>
    </java-types>
</xml-bindings>
Java Model (Content)
Below is the Java model we will use for this example.
package forum17977009;
import java.util.List;
public class Content {
    private List<ElementType> elements;
    public List<ElementType> getElements() {
        return elements;
    public void setElements(List<ElementType> elements) {
        this.elements = elements;
jaxb.properties
To specify MOXy as your JAXB provider you include a file called jaxb.properties in the same package as your domain model with the following entry (see: http://blog.bdoughan.com/2011/05/specifying-eclipselink-moxy-as-your.html).
javax.xml.bind.context.factory=org.eclipse.persistence.jaxb.JAXBContextFactory
Input (input.xml)
Below is a sample input document.
<content>
    <a>
        <b/>
        <b/>
    </a>
    <c>
        <d/>
        <d/>
    </c>
</content>
Demo
Below is some demo code you can run to prove that everything works:
import java.io.File;
import java.util.*;
import javax.xml.bind.*;
import org.eclipse.persistence.jaxb.JAXBContextProperties;
public class Demo {
    public static void main(String[] args) throws Exception {
        Map<String, Object> properties = new HashMap<String, Object>(1);
        properties.put(JAXBContextProperties.OXM_METADATA_SOURCE, "forum17977009/bindings.xml");
        JAXBContext jc = JAXBContext.newInstance(new Class[] {Content.class}, properties);
        Unmarshaller unmarshaller = jc.createUnmarshaller();
        File xml = new File("src/forum17977009/input.xml");
        Content content = (Content) unmarshaller.unmarshal(xml);
        Marshaller marshaller = jc.createMarshaller();
        marshaller.setProperty(Marshaller.JAXB_FORMATTED_OUTPUT, true);
        marshaller.marshal(content, System.out);
Output
Since all of the items are of the same type, they will output based on the xml-path of the first xml-element in the xml-elements mapping:
<content>
   <a>
      <b/>
      <b/>
      <b/>
      <b/>
   </a>
</content>
Previous Topic:EclipseLink MOXy exception due to package structure
Next Topic:MOXy: Override rules of binding files
Current Time: Sun Jul 20 22:15:54 EDT 2025
Powered by FUDForum. Page generated in 0.06347 seconds
