Does EGit use .git/info/exclude? [message #1076036] |
Tue, 30 July 2013 11:03  |
I've just started using EGit to work with a local repository on a project that has a large (VERY large) number of files, some symlinked from a NFS, that get created in the local repository, but should be totally ignored for the purposes of git operations: checkout, commit, branch, etc.
I've added the directories to the .git/info/exclude file, and git operations from the command line work as expected: I can throw a new local branch, checkout to switch between my local branches, etc.
Everytime I use EGit to do similar commands though, the operation hangs. Taking a stack trace shows things like:
"Worker-6" prio=10 tid=0x9d400800 nid=0x6c80 runnable [0x9d3fe000]
java.lang.Thread.State: RUNNABLE
at java.io.UnixFileSystem.list(Native Method)
at java.io.File.list(File.java:1048)
at java.io.File.listFiles(File.java:1133)
at org.eclipse.jgit.treewalk.FileTreeIterator.entries(FileTreeIterator.java:138)
at org.eclipse.jgit.treewalk.FileTreeIterator.<init>(FileTreeIterator.java:128)
at org.eclipse.jgit.treewalk.FileTreeIterator.createSubtreeIterator(FileTreeIterator.java:134)
at org.eclipse.jgit.treewalk.AbstractTreeIterator.createSubtreeIterator(AbstractTreeIterator.java:535)
at org.eclipse.jgit.treewalk.TreeWalk.enterSubtree(TreeWalk.java:908)
at org.eclipse.jgit.treewalk.TreeWalk.next(TreeWalk.java:566)
at org.eclipse.egit.core.op.BranchOperation.getMissingProjects(BranchOperation.java:241)
at org.eclipse.egit.core.op.BranchOperation.access$1(BranchOperation.java:204)
at org.eclipse.egit.core.op.BranchOperation$1.run(BranchOperation.java:108)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2344)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2326)
at org.eclipse.egit.core.op.BranchOperation.execute(BranchOperation.java:162)
at org.eclipse.egit.ui.internal.branch.BranchOperationUI$1.run(BranchOperationUI.java:199)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
I suspect that egit/jgit is walking a directory structure that I really want it to just ignore, and which I've put in to the exclude file for that reason. Is that the case? How should I be telling egit not to look at those directories?
Re: Does EGit use .git/info/exclude? [message #1076510 is a reply to message #1076036] |
Wed, 31 July 2013 09:57   |
Chris Leon skrev 2013-07-30 19.28:
It's correct that JGit walks ignored directories and then ignores them. It's a performance bug.
-- robin
FUDForum. Page generated in 0.04494 seconds
