Home » Modeling » ATL » Problem when setting values of applied Stereotypes(The property comes from an association between two stereotypes.)
Problem when setting values of applied Stereotypes [message #1076437] |
Wed, 31 July 2013 07:54  |
Hi everyone,
I got a profile with two stereotypes: View and Perspective. Both have two properties (name and icon, which are both Strings), Perspective also has a relationship with View (association called 'views') meaning it actually ends up having one more attribute which is a Sequence of Views.
So I can set values properly without a problem to both name and icon, but the problem comes when changing the value of the attribute "views". I can access the value properly and give it an empty sequence without any trouble, but I don't know how to add to it the other classes that are stereotyped with View.
Here is what I tried:
src.setValue(profile!Stereotype.allInstances().asSequence() -> select(i | i.qualifiedName ='RCP::Perspective').last(), 'views', UML2!Class. allInstancesFrom('OUT') -> select(e | not e.getAppliedStereotype('RCP::View').oclIsUndefined()));
And I get a java.lang.IllegalArgumentException because apparently the classes are not the proper argument. I thought that the property 'views' was addressing a sequence of different classes with the stereotype 'View', but I'm thinking that maybe it addresses the stereotypes directly, but I have no idea of how to get them.
So my question is, how do I do this? what is the proper call I should use to get those stereotypes or whatever I need and what kind of element is it expecting?
Well I hope that wasn't too confusing but if you need more information just ask.
Thanks in advance,
regards,
Javier
[Updated on: Wed, 31 July 2013 08:31] by Moderator
Re: Problem when setting values of applied Stereotypes [message #1077018 is a reply to message #1076471] |
Thu, 01 August 2013 02:21   |
Hi Hugo,
thanks for your answer, here is the whole code of my rule:
endpoint rule EndRule() {
do {
for(src in UML2!Class.allInstancesFrom('OUT')) {
if (src.getNearestPackage().name = 'View Actions'){
src.applyStereotype(profile!Stereotype.allInstances().asSequence() ->
select(i | i.qualifiedName = 'RCP::ViewAction').last());
src.name<-src.name + ' ViewAction';
else if (src.getNearestPackage().name = 'Workbench Actions'){
select(i | i.qualifiedName = 'RCP::WorkbenchAction').last());
qualifiedName = 'RCP::WorkbenchAction').last(), 'label', src.
getXmlAttribute('actionSet', 'label'));
src.name<-src.name + ' WorkbenchAction';
else if (src.getNearestPackage().name = 'Popup Menus'){
select(i | i.qualifiedName = 'RCP::PopupMenu').last());
src.name<-src.name + ' PopupMenu';
else if (src.getNearestPackage().name = 'Toolbars'){
select(i | i.qualifiedName = 'RCP::ToolBar').last());
-> select(i | i.qualifiedName = 'RCP::ToolBar').
last(), 'toolBar', src.getToolbarPath());
src.name<-'Toolbar ' + src.getToolbarPath();
else if (not src.getAppliedStereotype('RCP::Perspective').oclIsUndefined()){
------------------------TODO: make this work:
As you can see it's an endpoint rule, I thought it was ok to use allInstancesFrom('OUT') in there since it's the last thing that will be run, and as you can see I use it in other calls and it works alright.
By the way the problematic call is the last one, if I delete it everything runs smoothly.
My problem is that the input model has no profile applied so in my transformation I apply the profile and the stereotypes, and since I need to change these values I need to check on the output model. I tried using allInstances() but it shows the same result.
The complete stack trace I get is:
Quote:org.eclipse.m2m.atl.engine.emfvm.VMException: Exception during invocation of operation setValue on org.eclipse.uml2.uml.internal.impl.ClassImpl@9685c9 (name: MonitoringPerspective, visibility: <unset>) (isLeaf: false, isAbstract: false) (isActive: false)
Java Stack:
at org.eclipse.m2m.atl.engine.emfvm.adapter.EMFModelAdapter.invoke(EMFModelAdapter.java:734)
at org.eclipse.m2m.atl.engine.emfvm.ASMOperation.exec(ASMOperation.java:425)
at org.eclipse.m2m.atl.engine.emfvm.ASMOperation.exec(ASMOperation.java:388)
at org.eclipse.m2m.atl.engine.emfvm.ASM.run(ASM.java:208)
at org.eclipse.m2m.atl.engine.emfvm.launch.EMFVMLauncher.internalLaunch(EMFVMLauncher.java:170)
at org.eclipse.m2m.atl.engine.emfvm.launch.EMFVMUILauncher.launch(EMFVMUILauncher.java:46)
at org.eclipse.m2m.atl.core.service.LauncherService.launch(LauncherService.java:136)
at org.eclipse.m2m.atl.core.ui.launch.AtlLaunchConfigurationDelegate.launchOrDebug(AtlLaunchConfigurationDelegate.java:300)
at org.eclipse.m2m.atl.core.ui.launch.AtlLaunchConfigurationDelegate.launch(AtlLaunchConfigurationDelegate.java:237)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:854)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:703)
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(DebugUIPlugin.java:937)
at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlugin.java:1141)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Caused by: java.lang.IllegalArgumentException: [org.eclipse.uml2.uml.internal.impl.ClassImpl@3435a9 (name: MapElementsView, visibility: <unset>) (isLeaf: false, isAbstract: false) (isActive: false), org.eclipse.uml2.uml.internal.impl.ClassImpl@1af27e6 (name: IncidentTreeView, visibility: <unset>) (isLeaf: false, isAbstract: false) (isActive: false), org.eclipse.uml2.uml.internal.impl.ClassImpl@648371 (name: DetailView, visibility: <unset>) (isLeaf: false, isAbstract: false) (isActive: false), org.eclipse.uml2.uml.internal.impl.ClassImpl@f1ad77 (name: SnapshotView, visibility: <unset>) (isLeaf: false, isAbstract: false) (isActive: false)]
at org.eclipse.uml2.uml.internal.operations.ElementOperations.setValue(ElementOperations.java:752)
at org.eclipse.uml2.uml.internal.impl.ElementImpl.setValue(ElementImpl.java:306)
at org.eclipse.m2m.atl.engine.emfvm.adapter.EMFModelAdapter.invoke(EMFModelAdapter.java:727)
... 13 more
So I think that I'm just not using the proper arguments and I don't know what should I use instead.
I have tried this both with eclipse Indigo and Juno and I get the same result.
[Updated on: Thu, 01 August 2013 02:51] by Moderator
Current Time: Fri Jul 25 21:08:56 EDT 2025
Powered by FUDForum. Page generated in 0.05290 seconds
