Home » Newcomers » Newcomers » Out Of Memory error in Eclipse Juno
Out Of Memory error in Eclipse Juno [message #1076361] Wed, 31 July 2013 04:54 Go to next message
Hi guys,
first, I want to ask you sorry for my bad english.
I have a problem with Eclipse Juno.
The error that the software back to me is the following:
Exception in thread "main" java.sql.SQLException: out of memory
at org.sqlite.DB.throwex(DB.java:288)
at org.sqlite.NestedDB._open(NestedDB.java:73)
at org.sqlite.DB.open(DB.java:77)
at org.sqlite.Conn.<init>(Conn.java:88)
at org.sqlite.JDBC.connect(JDBC.java:64)
at java.sql.DriverManager.getConnection(Unknown Source)
at ProvaDB1.main(ProvaDB1.java:10)
The line 10, is the line:
Connection conn = DriverManager.getConnection("jdbc:sqlite:db.db");
how you can understand, I'm trying to connect with a DataBase sqlite.
I have imported the sqlite JAR's file.
I read on web that the problem may be relative at memory allocated to eclipse, than i must rise this memory from Eclipse.ini file.
I have done it, my file eclipse.ini now is:
but, my problem persist.
The java code that i wrote is:
public class ProvaDB1 {
public static void main(String[] args) throws Exception{
Class.forName("org.sqlite.JDBC");
//try{
Statement stm = conn.createStatement();
stm.close();
conn.close();
this is all code that i wrote!
Just two month ago, I had an old PC with Windows 7, now I have a new PC with Windows 8 (4gb ram). With the old PC eclipse work very well, now....
I'm not able to solve this problem, thanks for all of you that can help me.
[Updated on: Wed, 31 July 2013 07:40] by Moderator
Re: Out Of Memory error in Eclipse Juno [message #1076447 is a reply to message #1076361] Wed, 31 July 2013 08:05 Go to previous messageGo to next message
Michael,
What's running out of heap space, the IDE (in which case increasing it
in the eclipse.ini will help) or in your own launched application (in
which case you need that option in the launch configuration for your
application).
On 31/07/2013 1:33 PM, michael m wrote:
> Hi guys,
> now....
> help me.
Re: Out Of Memory error in Eclipse Juno [message #1078794 is a reply to message #1076447] Sat, 03 August 2013 11:32 Go to previous messageGo to next message
Thanks for your answer.
I have already increased the memory with eclipse.ini file but the problem persist.
My .ini file it's the following:
-startup
plugins/org.eclipse.equinox.launcher_1.3.0.v20120522-1813.jar
--launcher.library
plugins/org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.200.v20120522-1813
-product
org.eclipse.epp.package.jee.product
--launcher.defaultAction
openFile
--launcher.XXMaxPermSize
256M
-showsplash
org.eclipse.platform
256m
openFile
-vmargs
-Dosgi.requiredJavaVersion=1.5
-Dhelp.lucene.tokenizer=standard
-Xms512m
-Xmx1024m
-XX:MaxPermSize=512m
thanks again.
Re: Out Of Memory error in Eclipse Juno [message #1078867 is a reply to message #1078794] Sat, 03 August 2013 14:17 Go to previous messageGo to next message
Your launched application is what's running out of memory, not Eclipse. You need to modify its launch configuration.
Re: Out Of Memory error in Eclipse Juno [message #1079229 is a reply to message #1078867] Sun, 04 August 2013 03:58 Go to previous messageGo to next message
Thanks for your answer!
But I'm not able to do what you say me to do.
how I have to do this?
which parameter I have to modify?
thanks again.
Re: Out Of Memory error in Eclipse Juno [message #1079551 is a reply to message #1079229] Sun, 04 August 2013 15:44 Go to previous message
> thanks again.
When you run your application, the one that's trying to open the SQLite
database, you have a "launch" or "run/debug configuration" whether
you're running the debugger or just running it. For the specific
application, you'll find tabs in that configuration that allow you to
specify arguments, environment variables, etc.
Hope this helps.
Previous Topic:How To Create proxy service xsd and wsdl based on business service xsd and wsdl
Next Topic:Subversive with WindowBuilder
Current Time: Sun Jul 20 20:17:12 EDT 2025
Powered by FUDForum. Page generated in 0.09860 seconds
