Home » Archived » BIRT » birt error while creating XLS report(java.lang.NegativeArraySizeException)
birt error while creating XLS report [message #1072441] Mon, 22 July 2013 15:17 Go to next message
hi,
i am getting the below exception while running one of the reports. all other reports run fine.
i am using birt 3.7.2 for generation of xls. can anyone help here?
java.lang.Exception: org.eclipse.birt.report.engine.api.EngineException: Error happened while running the report.
at amdocs.ThreadedBIRTEngine$ReportAgent.run(ThreadedBIRTEngine.java:269)
Caused by: org.eclipse.birt.report.engine.api.EngineException: Error happened while running the report.
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:196)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRenderTask.java:77)
at amdocs.ThreadedBIRTEngine$ReportAgent.run(ThreadedBIRTEngine.java:244)
Caused by: java.lang.NegativeArraySizeException
at org.eclipse.birt.report.engine.emitter.excel.layout.Page.synchronize(Page.java:773)
at org.eclipse.birt.report.engine.emitter.excel.layout.ExcelLayoutEngine.endRow(ExcelLayoutEngine.java:516)
at org.eclipse.birt.report.engine.emitter.excel.ExcelEmitter.endRow(ExcelEmitter.java:117)
at org.eclipse.birt.report.engine.emitter.CompositeContentEmitter.endRow(CompositeContentEmitter.java:179)
at org.eclipse.birt.report.engine.layout.html.HTMLTableLayoutEmitter.flushRow(HTMLTableLayoutEmitter.java:363)
at org.eclipse.birt.report.engine.layout.html.HTMLTableLayoutEmitter.flush(HTMLTableLayoutEmitter.java:313)
at org.eclipse.birt.report.engine.layout.html.HTMLTableLayoutEmitter.endRow(HTMLTableLayoutEmitter.java:636)
at org.eclipse.birt.report.engine.emitter.ContentEmitterUtil.endContent(ContentEmitterUtil.java:111)
at org.eclipse.birt.report.engine.layout.html.buffer.DummyPageBuffer.endContainer(DummyPageBuffer.java:67)
at org.eclipse.birt.report.engine.layout.html.HTMLStackingLM.end(HTMLStackingLM.java:42)
at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.layout(HTMLAbstractLM.java:141)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:70)
at org.eclipse.birt.report.engine.layout.html.HTMLStackingLM.layoutChildren(HTMLStackingLM.java:26)
at org.eclipse.birt.report.engine.layout.html.HTMLTableBandLM.layoutChildren(HTMLTableBandLM.java:67)
at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.layout(HTMLAbstractLM.java:140)
at org.eclipse.birt.report.engine.layout.html.HTMLGroupLM.layoutChildren(HTMLGroupLM.java:117)
thanks
Sughandh
Re: birt error while creating XLS report [message #1072964 is a reply to message #1072441] Tue, 23 July 2013 17:05 Go to previous messageGo to next message
Does this report work in other non-XLS outputs? Can you attach the design?
Re: birt error while creating XLS report [message #1076093 is a reply to message #1072441] Tue, 30 July 2013 13:48 Go to previous message
What is the size of dataset. Negative array size is on int overflow, and my guess is your dataset is too huge to fit in xls limit of rows.
[Updated on: Tue, 30 July 2013 13:56] by Moderator
Previous Topic:change date parameter value from script
Next Topic:Add link to Maximo page to launch report in "Browser View"
Current Time: Wed Jul 23 10:51:51 EDT 2025
Powered by FUDForum. Page generated in 0.04291 seconds
