Home » Modeling » EMF » [CDO - MySQL] java.util.concurrent.TimeoutException(Connectivity issue with MySQL adapter for CDO)
[CDO - MySQL] java.util.concurrent.TimeoutException [message #1075378] |
Mon, 29 July 2013 06:23  |
To whom it may concern,
I am trying to configure CDO-MySQL to a new installation of Kepler (With Eclipse Modeling Tools).
I am able to run the client + server as per the tutorial (http://wiki.eclipse.org/CDO/User_Contributed_Documentation - An Introduction to CDO 4.0 (by Vincenzo Caselli, RCPVision)) but when I try to commit a transaction (even one with only a single model element in it, either using the CDO session UI, or programmatically) I get:
org.eclipse.emf.cdo.common.util.TransportException: java.util.concurrent.TimeoutException
at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtocol.send(CDOClientProtocol.java:526)
at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtocol.commitTransaction(CDOClientProtocol.java:393)
at org.eclipse.emf.internal.cdo.session.DelegatingSessionProtocol.commitTransaction(DelegatingSessionProtocol.java:292)
at org.eclipse.emf.internal.cdo.transaction.CDOSingleTransactionStrategyImpl.commit(CDOSingleTransactionStrategyImpl.java:72)
at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.commit(CDOTransactionImpl.java:1191)
at org.eclipse.emf.cdo.internal.ui.editor.CDOEditor$22.run(CDOEditor.java:1845)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
Caused by: java.util.concurrent.TimeoutException
at org.eclipse.net4j.util.io.IOTimeoutException.createTimeoutException(IOTimeoutException.java:46)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:257)
at org.eclipse.net4j.signal.SignalProtocol.startSignal(SignalProtocol.java:442)
at org.eclipse.net4j.signal.RequestWithConfirmation.doSend(RequestWithConfirmation.java:89)
at org.eclipse.net4j.signal.RequestWithConfirmation.send(RequestWithConfirmation.java:75)
at org.eclipse.net4j.signal.RequestWithMonitoring.send(RequestWithMonitoring.java:110)
at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtocol.send(CDOClientProtocol.java:518)
... 6 more
Caused by: org.eclipse.net4j.util.io.IOTimeoutException
at org.eclipse.net4j.buffer.BufferInputStream.computeTimeout(BufferInputStream.java:216)
at org.eclipse.net4j.buffer.BufferInputStream.ensureBuffer(BufferInputStream.java:189)
at org.eclipse.net4j.buffer.BufferInputStream.read(BufferInputStream.java:116)
at java.io.DataInputStream.readBoolean(Unknown Source)
at org.eclipse.net4j.util.io.ExtendedDataInput$Delegating.readBoolean(ExtendedDataInput.java:60)
at org.eclipse.emf.cdo.internal.net4j.protocol.CommitTransactionRequest.confirmingCheckError(CommitTransactionRequest.java:304)
at org.eclipse.emf.cdo.internal.net4j.protocol.CommitTransactionRequest.confirming(CommitTransactionRequest.java:290)
at org.eclipse.emf.cdo.internal.net4j.protocol.CommitTransactionRequest.confirming(CommitTransactionRequest.java:1)
at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientRequestWithMonitoring.confirming(CDOClientRequestWithMonitoring.java:117)
at org.eclipse.net4j.signal.RequestWithMonitoring.confirming(RequestWithMonitoring.java:171)
at org.eclipse.net4j.signal.RequestWithConfirmation.doExtendedInput(RequestWithConfirmation.java:125)
at org.eclipse.net4j.signal.Signal.doInput(Signal.java:328)
at org.eclipse.net4j.signal.RequestWithConfirmation.doExecute(RequestWithConfirmation.java:105)
at org.eclipse.net4j.signal.RequestWithMonitoring.doExecute(RequestWithMonitoring.java:235)
at org.eclipse.net4j.signal.SignalActor.execute(SignalActor.java:53)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:253)
... 11 more
In case it is of use, the server initializes normally with:
[INFO] CDO server starting
!SESSION 2013-07-29 10:59:44.943 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_25
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_GB
Framework arguments: -product org.eclipse.emf.cdo.server.product.tcp_h2
Command-line arguments: -product org.eclipse.emf.cdo.server.product.tcp_h2 -data D:\workspace-cdo/../runtime-CDO-Server.product -dev file:D:/workspace-cdo/.metadata/.plugins/org.eclipse.pde.core/CDO-Server.product/dev.properties -os win32 -ws win32 -arch x86_64 -consoleLog
!ENTRY org.eclipse.emf.cdo.server 1 0 2013-07-29 10:59:45.565
!MESSAGE CDO server starting
[WARN] Detected crash of repository demo
!ENTRY org.eclipse.emf.cdo.server.db 2 0 2013-07-29 10:59:46.087
!MESSAGE Detected crash of repository demo
[INFO] Repaired crash of repository demo: lastObjectID=OID2, nextLocalObjectID=OID9223372036854775807, lastBranchID=0, lastCommitTime=1,374,766,710,269, lastNonLocalCommitTime=1,374,766,710,269
!ENTRY org.eclipse.emf.cdo.server.db 1 0 2013-07-29 10:59:46.101
!MESSAGE Repaired crash of repository demo: lastObjectID=OID2, nextLocalObjectID=OID9223372036854775807, lastBranchID=0, lastCommitTime=1,374,766,710,269, lastNonLocalCommitTime=1,374,766,710,269
[INFO] Net4j extension starting
!ENTRY org.eclipse.emf.cdo.server.net4j 1 0 2013-07-29 10:59:46.288
!MESSAGE Net4j extension starting
[INFO] Net4j extension started
!ENTRY org.eclipse.emf.cdo.server.net4j 1 0 2013-07-29 10:59:46.318
!MESSAGE Net4j extension started
[INFO] CDO server started
!ENTRY org.eclipse.emf.cdo.server 1 0 2013-07-29 10:59:46.319
!MESSAGE CDO server started
Computer Software Setup:
Windows 7 - 64bit
Eclipse Modeling Tools 2.0.0.20130613-0530
with: CDO Model Repository EPP 4.2.0.v20130613-1556
using: Net4j DB Framework MYSQL Adapter 4.2.0.v20130601-1611
running: MySQL server 5.5
Config file (cdo-server.xml):
<cdoServer>
<acceptor type="tcp" listenAddr="0.0.0.0" port="2038">
</acceptor>
<repository name="demo">
<store type="db">
<mappingStrategy type="horizontal"/>
<dbAdapter name="mysql"/>
<dataSource
class="com.mysql.jdbc.jdbc2.optional.MysqlDataSource"
url="jdbc:mysql://localhost:2038/cdotest?createDatabaseIfNotExist=true"
user="root"
password="admin"
<property name="drop" value="true"/>
</store>
</repository>
</cdoServer>
As far as I understand this may be due to an error in communication of the CDO client to the CDO server (unless the server initializes normally but then cannot communicate with the MySQL service). In either case, I do not know how to proceed to solve this.
Please let me know if you need any more diagnostics,
Thank you in advance for any help or pointers to solutions,
Yours faithfully,
Re: [CDO - MySQL] java.util.concurrent.TimeoutException [message #1075396 is a reply to message #1075378] |
Mon, 29 July 2013 06:56   |
Am 29.07.2013 12:23, schrieb Konstantinos Barmpis:
Are you sure that server and clients use the same (versions of the) binaries?
Does the server log any warnings or exceptions at the same time?
Can you load/navigate models on your client?
Please try to add the following to the <repository> element of teh cdo-server.xml:
<property name="optimisticLockingTimeout" value="10000"/>
Does that help?
Cheers
/Eike
http://www.esc-net.de
> at
> at
> ... 6 more
> at
> at
> ... 11 more
> Windows 7 - 64bit
> <cdoServer>
> </acceptor>
> <store type="db">
> <dataSource
> user="root"
> password="admin"
> </store>
> </repository>
> </cdoServer>
> Yours faithfully,
Current Time: Wed Jul 23 12:33:50 EDT 2025
Powered by FUDForum. Page generated in 0.07152 seconds
