Home » Modeling » EMF » Combining EMF Commands and Text Editor operations
Combining EMF Commands and Text Editor operations [message #1075319] Mon, 29 July 2013 04:20 Go to next message
I have a multi page editor . One tab has a model and another one has a corresponding source
I trigger an EMF AddCommand (A1) in the model editor followed by a text operation (T1) (Initiated by the text editor editor framework).
Then I have number of set commands (S1...S3) depending upon some condition. (for e.g. on page change)
Like this A1->T1->S1->S2->S3
Now I would like to have undo/redo for a transaction shown as the sequence above. How this can this be achieved in a better way. Both text operation and EMF model commands have to work seamlessly.
The framework must revert in the above order starting from S3.
Do I have to put all the commands in the Compound Command. In that case how can I achieve the text operation synchronization ?.
Saurav
Re: Combining EMF Commands and Text Editor operations [message #1075332 is a reply to message #1075319] Mon, 29 July 2013 04:54 Go to previous messageGo to next message
Saurav,
Comments below.
On 29/07/2013 10:20 AM, saurav sarkar wrote:
I've never looked at solving that problem. Each has their own command
stack but you need for there to be one command stack.
Each separately undoable thing needs to be part of a single command in
EMF's command stack.
Perhaps you should try to use EMF's command stack with commands to
encapsulate the text actions so that an undo on that command will undo
the text action or call the text editor's command stack to undo it. As
I said, I've never looked into how to solve such a problem...
> Cheers,
> Saurav
Re: Combining EMF Commands and Text Editor operations [message #1075529 is a reply to message #1075319] Mon, 29 July 2013 11:31 Go to previous messageGo to next message
Thanks for the comments Ed.
I could achieve the same by using Compound Command and overriding the doUndo() method to undo the text editor stack changes.
Just a curiosity on what would EMFCompositeOperation and NonEMFTransaction in org.eclipse.emf.workspace plugin are used for ?any sample implementation done on those ?
cheers,
Saurav
Re: Combining EMF Commands and Text Editor operations [message #1075531 is a reply to message #1075529] Mon, 29 July 2013 11:36 Go to previous messageGo to next message
Saurav,
Comments below.
Yes. I'm not sure how you're doing the text change itself right now,
but it should be part of the doExecute and then you reverse the effect
in doUndo...
I can't really comment on the transaction framework because I have
pretty much no experience with that. Maybe someone else will answer...
> cheers,
> Saurav
Re: Combining EMF Commands and Text Editor operations [message #1075548 is a reply to message #1075531] Mon, 29 July 2013 12:11 Go to previous messageGo to next message
Yes i forgot to mention about the actual text change.
Its done as you mentioned.
cheers,
Saurav
Re: Combining EMF Commands and Text Editor operations [message #1075628 is a reply to message #1075529] Mon, 29 July 2013 15:29 Go to previous message
Hi, Saurav,
EMFCompositeOperation is an IUndoableOperation (as defined by the
Eclipse Operation History API) that aggregates multiple discrete
operations on EMF models/editing-domains. It is analogous to the
CompoundCommand in EMF.Edit.
The NonEMFTransaction is intended to encapsulate undoable state changes
in stuff that is not EMF model content, to embed it in an EMF
transaction's change description for undo/redo. Updates to the state
of UI components is an example of what this is intended to capture.
As far as I recall (it has been several years, now) the
NonEMFTransaction is supposed only to be used internally by the
TransactionalEditingDomain, but I could be wrong. I don't there is
public API for creating and manipulating these transactions ... A
search of the code would answer that for you.
HTH,
Christian
> cheers,
> Saurav
Previous Topic:Regenerating Ecore from XSD
Next Topic:where could I get map file of EMF?
Current Time: Thu Jul 31 01:19:04 EDT 2025
Powered by FUDForum. Page generated in 0.08875 seconds
