Home » Modeling » ATL » EMF operation invocation in an ATL module
EMF operation invocation in an ATL module [message #1075395] Mon, 29 July 2013 06:59 Go to next message
Hi there,
rule rule_getDevice{
from
a: source!DeviceItem
to
p:target!Device(
name <- a.Name,
s7DeviceReference<-a.DeviceReference,
isSelectedWithinStep7 <-a.stringToBool(a.IsSelected)
stringToBool() defined in the source EMF meta-model. I set the Operation Reflection feature of the gen model to True.
I get the following error, When I run this transformation using ATL Run configuration,
org.eclipse.m2m.atl.engine.emfvm.VMException: Operation not found: IN!<unnamed>.stringToBool(java.lang.String)
Any help is appreciated.
Kosala
Re: EMF operation invocation in an ATL module [message #1075499 is a reply to message #1075395] Mon, 29 July 2013 10:38 Go to previous messageGo to next message
Invoking such Java-implemented operations is generally not a recommended practice in ATL.
However, the refInvokeOperation operation allows to do so when really needed.
Re: EMF operation invocation in an ATL module [message #1075504 is a reply to message #1075499] Mon, 29 July 2013 10:48 Go to previous messageGo to next message
Hi Hugo,
Thanks. Do you have any clue how to use refInvokeOperation in the above example?
[Updated on: Mon, 29 July 2013 10:50] by Moderator
Re: EMF operation invocation in an ATL module [message #1075506 is a reply to message #1075504] Mon, 29 July 2013 10:51 Go to previous message
As explained in the manual, something like: a.refInvokeOperation('stringToBool',Sequence{a.IsSelected})
Previous Topic:Incremental ATL
Next Topic:problem in helper
Current Time: Thu Jul 24 11:22:50 EDT 2025
Powered by FUDForum. Page generated in 0.07703 seconds
