Home » Modeling » TMF (Xtext) » How to run DSL-Editor in my common Eclipse-Workspace
How to run DSL-Editor in my common Eclipse-Workspace [message #1075153] Sun, 28 July 2013 18:42 Go to next message
I've implemented my Grammar and a Generator. Everything works fine.
But I always have to select "Run As/ EclipseApplication" to start my DSL-Editor.
Is it possible to configure my Eclipse in the way that I can use Java for my common work any my new DSL directly as soon as I started my every-day-Eclipse (without "Run As/ EclipseApplication")?
Thanks for advice
Greets Björn
Re: How to run DSL-Editor in my common Eclipse-Workspace [message #1075155 is a reply to message #1075153] Sun, 28 July 2013 18:50 Go to previous messageGo to next message
you can (using the pregenerate sdk project) use the Export -> Deployable Features Wizard to create an Update Site you can use to install the plugins into any eclipse
Re: How to run DSL-Editor in my common Eclipse-Workspace [message #1075256 is a reply to message #1075155] Mon, 29 July 2013 02:02 Go to previous messageGo to next message
I think that we can export into a jar, copy it into the plugins directory of the targeted Eclipse used to run DSL.
[Updated on: Mon, 29 July 2013 21:39] by Moderator
Re: How to run DSL-Editor in my common Eclipse-Workspace [message #1075749 is a reply to message #1075256] Mon, 29 July 2013 21:39 Go to previous messageGo to next message
But then, I have a question: where is the .jar file that contain the plugin for the eclipse Run Time ?
Say if we use an initial Eclipse to work with xtext grammar in a workspace, say C:/ws, and if we choose to run the run time model by "Run as Eclipse Application", then the workspace of the run time will be C:/ws/runtime-EclipseApplication. The problem is: I cannot find the plugin .jar file inside any sub directory of C:/ws
Can someone provide me with a hint ?
Re: How to run DSL-Editor in my common Eclipse-Workspace [message #1075764 is a reply to message #1075256] Mon, 29 July 2013 22:32 Go to previous messageGo to next message
On 2013-29-07 8:02, J A wrote:
> Or you can export into a jar, copy it into the plugins directory of the
That is not recommended.
Use the update site method.
- henrik
Re: How to run DSL-Editor in my common Eclipse-Workspace [message #1075885 is a reply to message #1075764] Tue, 30 July 2013 05:15 Go to previous messageGo to next message
Henrik Lindberg wrote on Mon, 29 July 2013 22:32
- henrik
Thanks.
Can you answer me in the case of "Run as Eclipse Application", where the .jar plugin file of the generating project is put in the workspace / source of the run time project ?
Re: How to run DSL-Editor in my common Eclipse-Workspace [message #1076029 is a reply to message #1075885] Tue, 30 July 2013 10:40 Go to previous messageGo to next message
>> - henrik
> Thanks.
> Thanks
You mean when running self-hosted? Why do you need to know where the
files are? What are you trying to do? Just make sure you have the things
you need in your launch config and run it. What is it that is not
working for you?
- henrik
Re: How to run DSL-Editor in my common Eclipse-Workspace [message #1076075 is a reply to message #1075155] Tue, 30 July 2013 13:13 Go to previous messageGo to next message
@ Christian Dietrich: This works. Thank you!
The followed website explains more precise what to do:
http://wiki.eclipse.org/Xtext/GettingStarted#Deployment
Greets Björn
[Updated on: Tue, 30 July 2013 13:14] by Moderator
Re: How to run DSL-Editor in my common Eclipse-Workspace [message #1076174 is a reply to message #1076075] Tue, 30 July 2013 17:45 Go to previous messageGo to next message
Björn Rellesch wrote on Tue, 30 July 2013 13:13
Greets Björn
And here http://www.vogella.com/articles/EclipsePlugIn/article.html#p2deployplugin is a very easy-to-do tutorial on how to make an update site for your xtext plugin. I tried making the plugin using juno, and try to update it to a kepler. It does not work.
However a juno updating from a juno is fine
[Updated on: Tue, 30 July 2013 17:45] by Moderator
Re: How to run DSL-Editor in my common Eclipse-Workspace [message #1076337 is a reply to message #1076174] Wed, 31 July 2013 03:41 Go to previous messageGo to next message
Hi again,
now I have a plugin so I can use the editor.
But now I want to start the generator automatically when I save the file containing my DSL-Code(the same behaviour, when I use "Run As / Eclipse Application"). How can I achieve this?
I found this, but it is quite complex:
http://jevopisdeveloperblog.blogspot.de/2011/02/extract-xtext-project-wizard.html
Greets Björn
[Updated on: Wed, 31 July 2013 03:42] by Moderator
Re: How to run DSL-Editor in my common Eclipse-Workspace [message #1076387 is a reply to message #1076337] Wed, 31 July 2013 05:47 Go to previous messageGo to next message
Hi this should work automatically (with test project having Xtext
nature and build automatically on)
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: How to run DSL-Editor in my common Eclipse-Workspace [message #1077375 is a reply to message #1076387] Thu, 01 August 2013 12:04 Go to previous messageGo to next message
I've analyzed the Problem.
I use my own BuilderParticipant. I registered the class in my UIModule-Class.
If I comment the registration the generator is called during build.
But I need my own BuilderParticipant-class to modify the logic for gathering my DSL-files. How can I use the export as a plugin (as described above) and my BuildParticipant at the same time (to use the DSL in my everyday Eclipse including the generator, who works with a modified set of DSL-files)?
Greets Björn
[Updated on: Thu, 01 August 2013 12:05] by Moderator
Re: How to run DSL-Editor in my common Eclipse-Workspace [message #1077381 is a reply to message #1077375] Thu, 01 August 2013 12:06 Go to previous messageGo to next message
Hi thus should work out if the box. I have no idea what goes wrong in
your case
Re: How to run DSL-Editor in my common Eclipse-Workspace [message #1081490 is a reply to message #1077381] Wed, 07 August 2013 05:36 Go to previous message
I haven't found the reason for my problem. So I moved the Functionality from my overridden BuilderParticipant to the Generator. That's ok for me. Greets Björn
Previous Topic:No EObjectDescription could be found in Scope Web.sitePermission for
Next Topic:calling XbaseCompiler 2.4 in the inferrer
Current Time: Wed Jul 23 05:48:26 EDT 2025
Powered by FUDForum. Page generated in 0.04372 seconds
