Home » Modeling » OCL » illegal operation signature: (oclContents())
illegal operation signature: (oclContents()) [message #1074581] |
Sat, 27 July 2013 02:02  |
Hi ed,
I was investigating your proposition for the closure operation, and i tested many requests in Xtext ocl console on a dynamic instance (xmi file), and it works, like:
self->asSet()->closure(oclContents()->select(oclIsKindOf(model::Activity)))->select(a:model::Activity| a.oclIsKindOf(model::Assign))->size()
but when i try to test it in my java code, it gives an exception on the use of the oclContents() operation. I thought that it is a problem of API version of the org.eclipse.ocl that i changed to 3.2.0, but without success:
org.eclipse.ocl.SemanticException: illegal operation signature: (oclContents())
at org.eclipse.ocl.util.OCLUtil.checkForErrors(OCLUtil.java:358)
at org.eclipse.ocl.util.OCLUtil.checkForErrors(OCLUtil.java:328)
at org.eclipse.ocl.internal.helper.HelperUtil.checkForErrors(HelperUtil.java:518)
at org.eclipse.ocl.internal.helper.HelperUtil.parseQuery(HelperUtil.java:165)
at org.eclipse.ocl.internal.helper.OCLHelperImpl.createQuery(OCLHelperImpl.java:176)
at arch.evol.qu.ConstraintParser.testquery(ConstraintParser.java:153)
at arch.evol.qu.CheckEvolutionChange.ParseContract(CheckEvolutionChange.java:173)
at arch.evol.qu.CheckEvolutionChange$1.widgetSelected(CheckEvolutionChange.java:96)
at org.eclipse.swt.widgets.TypedListener.handleEvent(Unknown Source)
at org.eclipse.swt.widgets.EventTable.sendEvent(Unknown Source)
at org.eclipse.swt.widgets.Widget.sendEvent(Unknown Source)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Unknown Source)
at org.eclipse.swt.widgets.Display.readAndDispatch(Unknown Source)
at arch.evol.qu.MainInterface$2.widgetSelected(MainInterface.java:91)
at arch.evol.qu.MainInterface.open(MainInterface.java:41)
at arch.evol.qu.MainInterface.main(MainInterface.java:26)
I changed also many API versions that OCL API depends on.
I'm using eclipse-modeling-juno-SR1
Please, can you help me to solve the problem.
Thanks in advance.
Re: illegal operation signature: (oclContents()) [message #1074692 is a reply to message #1074590] |
Sat, 27 July 2013 09:36   |
this my code:
OCL<?, EClassifier, ?, ?, ?, ?, ?, ?, ?, Constraint, EClass, EObject> ocl = null;
ocl = OCL.newInstance(EcoreEnvironmentFactory.INSTANCE);
OCLHelper<EClassifier, EOperation, EStructuralFeature, Constraint> helper = (OCLHelper<EClassifier, EOperation, EStructuralFeature, Constraint>) ocl.createOCLHelper();
helper.setContext(BPELPackage.Literals.PROCESS);
BasicEnvironment benv =OCLUtil.getAdapter(ocl.getEnvironment(), BasicEnvironment.class);
benv.setOption(ProblemOption.CLOSURE_ITERATOR,ProblemHandler.Severity.OK);
OCLExpression<EClassifier> query = helper.createQuery("self->asSet()->closure(oclContents()->select(oclIsKindOf(Activity)))->select(a:model::Activity| a.oclIsKindOf(Assign))->size()");
Query queryEval = ocl.createQuery(query);
String categories = (String) queryEval.evaluate(process).toString();
System.out.println(categories+ " in testquery");
Can you give some precisions please, how can i replace oclContens() with eContents().
Thanks in advance.
Re: illegal operation signature: (oclContents()) [message #1074707 is a reply to message #1074692] |
Sat, 27 July 2013 10:20   |
That is not your code; iut has no import statyeements, classpath,
dependencies, hiowever your question is trivial
Chnage
to
helper.createQuery("self->asSet()->closure(eContents()->select(oclIsKindOf(Activity)))->select(a:model::Activity|
Ed Willink
On 27/07/2013 14:36, Archevo tarek wrote:
> this my code:
> ocl = null;
> with eContents().
> Thanks in advance.
Re: illegal operation signature: (oclContents()) [message #1074719 is a reply to message #1074707] |
Sat, 27 July 2013 10:58   |
Thank you for answering me.
It is my code indeed ed. It is just an excerpt of a method, here is the imports of my class where the method public void testquery(Process process) is located:
import java.io.File;
import java.io.FileInputStream;
import java.io.FileOutputStream;
import java.io.IOException;
import java.io.InputStream;
import java.io.OutputStream;
import java.util.ArrayList;
import java.util.HashMap;
import java.util.List;
import java.util.Map;
import java.util.Set;
import javax.wsdl.WSDLException;
import org.eclipse.bpel.fnmeta.model.util.FMResourceFactoryImpl;
import org.eclipse.bpel.model.BPELFactory;
import org.eclipse.bpel.model.BPELPackage;
import org.eclipse.bpel.model.Process;
import org.eclipse.bpel.model.resource.BPELReader;
import org.eclipse.bpel.model.resource.BPELResource;
import org.eclipse.bpel.model.resource.BPELResourceFactoryImpl;
import org.eclipse.bpel.model.resource.BPELResourceImpl;
import org.eclipse.bpel.model.resource.BPELResourceSetImpl;
import org.eclipse.bpel.model.resource.BPELWriter;
import org.eclipse.bpel.model.util.WSDLUtil;
import org.eclipse.bpel.validator.Main;
import org.eclipse.bpel.validator.ModelQuery;
import org.eclipse.bpel.validator.helpers.ModelQueryImpl;
import org.eclipse.emf.common.notify.Adapter;
import org.eclipse.emf.common.notify.Notification;
import org.eclipse.emf.common.util.EList;
import org.eclipse.emf.common.util.TreeIterator;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.EClass;
import org.eclipse.emf.ecore.EClassifier;
import org.eclipse.emf.ecore.ENamedElement;
import org.eclipse.emf.ecore.EObject;
import org.eclipse.emf.ecore.EOperation;
import org.eclipse.emf.ecore.EPackage;
import org.eclipse.emf.ecore.EStructuralFeature;
import org.eclipse.emf.ecore.EcoreFactory;
import org.eclipse.emf.ecore.EcorePackage;
import org.eclipse.emf.ecore.impl.DynamicEObjectImpl;
import org.eclipse.emf.ecore.impl.EPackageRegistryImpl;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.Resource.Diagnostic;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.ocl.OCL;
import org.eclipse.ocl.OCLInput;
import org.eclipse.ocl.ParserException;
import org.eclipse.ocl.Query;
import org.eclipse.ocl.ecore.Constraint;
import org.eclipse.ocl.ecore.EcoreEnvironmentFactory;
import org.eclipse.ocl.expressions.OCLExpression;
import org.eclipse.ocl.helper.OCLHelper;
import org.eclipse.ocl.lpg.BasicEnvironment;
import org.eclipse.ocl.lpg.ProblemHandler;
import org.eclipse.ocl.options.ParsingOptions;
import org.eclipse.ocl.options.ProblemOption;
import org.eclipse.ocl.util.OCLUtil;
import org.eclipse.wst.wsdl.Definition;
import org.eclipse.wst.wsdl.WSDLFactory;
import org.eclipse.wst.wsdl.WSDLPackage;
import org.eclipse.wst.wsdl.internal.util.WSDLResourceFactoryImpl;
import org.eclipse.wst.wsdl.util.WSDLResourceImpl;
import org.eclipse.xsd.util.XSDResourceFactoryImpl;
public void testquery(Process process) throws ParserException {
Replacing the oclContents() directly in the request by eContents() returns the same exception, an org.eclipse.ocl.SemanticException: illegal operation signature: (eContents()).
I solve the problem like this:
I replaced this line:
by this one:
helper.setContext(EcorePackage.Literals.EOBJECT);
So i changed the context to the EcorePackage like you suggeted to work with EObject.
And i changed the request to:
self->asSet()->closure(eContents()->select(oclIsKindOf(model::Activity)).oclAsType(ecore::EObject))->size()
It works for now.
I'm testing now this request:
self->asSet()->closure(eContents()->select(oclIsKindOf(model::Activity)).oclAsType(ecore::EObject))->select(a:model::Activity| a.oclIsKindOf(model::Assign))->size()
It sends an exception:
org.eclipse.ocl.SemanticException: Iterator variable must have same type as source element type (Set {self}->asSet()->closure(temp1 : EObject | temp1.eContents()->select(temp2 : T | temp2.oclIsKindOf(model::Activity))->collect(temp3 : T | temp3.oclAsType(ecore::EObject)))->select(a : Activity | a.oclIsKindOf(model::Assign)))
Any help, please.
Thank
Current Time: Sat Jul 26 12:03:36 EDT 2025
Powered by FUDForum. Page generated in 0.08599 seconds
