Home » Eclipse Projects » Eclipse 4 » create contextual menu in view part
create contextual menu in view part [message #1073661] Thu, 25 July 2013 04:54 Go to next message
Hello ,
I try to implements contextual menu in view part but when i performed with right click nothing happend . I have searched on e4 forum and web but i find anything about this .
With the application model we can create contextual menu with popup menu yet?
My application.xmi (problem is on testLabel Part
Thanks for your help
Re: create contextual menu in view part [message #1073666 is a reply to message #1073661] Thu, 25 July 2013 05:02 Go to previous messageGo to next message
How are you registering your popup menu to the label?
Re: create contextual menu in view part [message #1073671 is a reply to message #1073666] Thu, 25 July 2013 05:20 Go to previous messageGo to next message
In my part(TestLabel with ID: test.rcp.part.testlabel) i create new menu(popup menu with ID:test.rcp.part.testlabel.popupmenu.popup) in menu i add handledMenuItem hello(Id: test.rcp.part.testlabel.popupmenu.popup.hello) , new menu ( Id submenu)
Re: create contextual menu in view part [message #1073787 is a reply to message #1073671] Thu, 25 July 2013 09:37 Go to previous message
I've found solution thanks to you !
I follow http://www.eclipse.org/forums/index.php/t/487190/
Thanks you very much
Previous Topic:Command Handler is not called since Kepler
Next Topic:Eclipse e4 CSS Export
Current Time: Wed Jul 23 12:53:39 EDT 2025
Powered by FUDForum. Page generated in 0.31192 seconds
