[Texo] usage of other JSON/WS [message #1073716] |
Thu, 25 July 2013 07:07  |
Hello
i have an existing JSON/WS and want to use it in a RCP-CLient application.
My idea is to generate an EMF Model for my WS classes and to use Texo for WS calls and for marshalling JSON to EMF.
Is there a possibility to use TEXO, respectively some of the TEXO components for this use case?
regards
Peter
Re: [Texo] usage of other JSON/WS [message #1073781 is a reply to message #1073716] |
Thu, 25 July 2013 09:20  |
Hi Peter,
Yes for sure, see the JSONModelConverter or the JSONEMFConverter and the convert methods on these converter classes.
Maybe you have to create your own subclasses and override some methods to handle resolving of types etc.
If you need to read the database during de-serialization so that the data is read from the database and updated from
json then you need to set an EntityManagerObjectStore instance as the ObjectResolver.
Btw, if it works for you it can be great to share some code with me, if possible, then I will/can blog about it.
gr. Martin
On 07/25/2013 01:07 PM, peter meyer wrote:
> Hello
> regards
> Peter
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
FUDForum. Page generated in 0.02981 seconds
