| 3rd party GMF editor integration in Papyrus 0.10.0 [message #1073708] |
Thu, 25 July 2013 06:45  |
I've integrated a gmf editor in Papyrus that does not base upon a UML model. At the moment I am updating from 0.9.6 to 0.10.0. I was able to fix all the things so that the integration works with 0.10.0, but every time a hover with the mouse over an edit part in the gmf editor I got this exception. Can I disable the navigation feature somehow?
!ENTRY org.eclipse.ui 4 0 2013-07-25 12:39:07.975
!MESSAGE Unhandled event loop exception
!STACK 0
at org.eclipse.papyrus.infra.gmfdiag.navigation.editpolicy.NavigationEditPolicy.showTargetFeedback(NavigationEditPolicy.java:85)
at org.eclipse.gef.editparts.AbstractEditPart.showTargetFeedback(AbstractEditPart.java:1119)
at org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPart.showTargetFeedback(GraphicalEditPart.java:1391)
at org.eclipse.gef.tools.TargetingTool.showTargetFeedback(TargetingTool.java:378)
at org.eclipse.gef.tools.SelectionTool.handleMove(SelectionTool.java:366)
at org.eclipse.gef.tools.AbstractTool.mouseMove(AbstractTool.java:1182)
at org.eclipse.gef.tools.SelectionTool.mouseMove(SelectionTool.java:563)
at org.eclipse.gef.EditDomain.mouseMove(EditDomain.java:287)
at org.eclipse.gef.ui.parts.DomainEventDispatcher.dispatchMouseMoved(DomainEventDispatcher.java:365)
at org.eclipse.draw2d.LightweightSystem$EventHandler.mouseMove(LightweightSystem.java:543)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:212)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1057)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4170)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3759)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1113)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:138)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:610)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
FUDForum. Page generated in 0.03224 seconds
