Home » Eclipse Projects » Equinox » M6 with p2 removed - still not detecting some plugins
M6 with p2 removed - still not detecting some plugins [message #107349] Tue, 01 April 2008 20:13 Go to next message
Can anyone else confirm this:
Having installed M6, and had difficulty with p2, I've followed the
instructions at http://wiki.eclipse.org/Equinox_p2_Removal and started
eclipse with -clean (for good measure).
I can now install features from update sites as I could with previous M
builds, but, when I want to set my target platform, I'm not getting the
same list of plugins listed as being present in eclipse/plugins.
Instead, the options listed are only those plugins that are packaged as
a jar. Old-style folders are ignored. In my case, this means that the
AspectJ runtime cannot be resolved.
The same workspace accessed via 3.4M4 shows many more plugins.
Neale
Re: M6 with p2 removed - still not detecting some plugins [message #107438 is a reply to message #107349] Wed, 02 April 2008 10:52 Go to previous messageGo to next message
Please open a bug against PDE UI
"Neale" <neale@nealeupstone.com> wrote in message
news:fsuj33$t72$1@build.eclipse.org...
> Instead, the options listed are only those plugins that are packaged as a
> Cheers,
> Neale
Re: M6 with p2 removed - still not detecting some plugins [message #107448 is a reply to message #107349] Wed, 02 April 2008 11:58 Go to previous messageGo to next message
Originally posted by: zx.us.ibm.com
How are you installing things to the folder you're pointing to as your
target platform?
~ Chris
Re: M6 with p2 removed - still not detecting some plugins [message #107460 is a reply to message #107349] Wed, 02 April 2008 12:00 Go to previous messageGo to next message
Check out https://bugs.eclipse.org/bugs/show_bug.cgi?id=225148
That may be the same issue.
~ Chris
Re: M6 with p2 removed - still not detecting some plugins [message #107499 is a reply to message #107460] Thu, 03 April 2008 06:55 Go to previous message
Certainly seems a complicated set of use cases to get to grips with, for
p2, but I'm not talking about p2. What I'm seeing is a regression: that
with p2 removed, I don't get the same behaviour as in the previous
M-build (in my case M4, as I didn't grab M5).
I'll open a but, as there's clearly something not right with PDE on this
one.
Hope you're not doing too many late nights on this... p2 is a big bold step!
Neale
> Cheers,
> ~ Chris
Previous Topic:importing existing projects programmatically
Next Topic:Cannot launch the Update UI
Current Time: Wed Nov 05 21:47:52 EST 2025
Powered by FUDForum. Page generated in 0.04426 seconds
