Home » Modeling » TMF (Xtext) » Scope for C# like Attribute-Class
Scope for C# like Attribute-Class [message #1073266] Wed, 24 July 2013 08:38 Go to next message
I´m currently working on a grammer for a class diagram.
I wrote a Rule called Reflection:
Reflection:
'[' name=[Attribute]('('var += [ParameterName] (','var += [ParameterName])*')') ']'
Attribute:
visib=Visibility 'attribute' name = ID'{'
(attributes+=Variable)*
(methodes+=Abstract_Method)*
Because i only want those ParameterName´s who belong to a Variable in my Reflection Rule i wrote a Scope-Operator.
IScope scope_Reflection_var(Reflection refl, EReference ref)
ArrayList<ParameterName> params = new ArrayList<ParameterName>();
for (Variable variable : refl.getName().getAttributes())
params.add(variable.getParam().getName());
return Scopes.scopeFor(params);
It seems like that i´m doing something wrong, because writing the grammer i get no propsals.
Maybe somebody can tell me what i´m doing wrong!?
Thx,
Günther
Re: Scope for C# like Attribute-Class [message #1073288 is a reply to message #1073266] Wed, 24 July 2013 09:23 Go to previous messageGo to next message
Well, after debugging and building everything new, the Scope works fine. But the intellisense does not work. Any ideas?
Re: Scope for C# like Attribute-Class [message #1073295 is a reply to message #1073288] Wed, 24 July 2013 09:35 Go to previous messageGo to next message
HI,
is this about ContentAssist for Attribute or for ParameterName
Re: Scope for C# like Attribute-Class [message #1073302 is a reply to message #1073295] Wed, 24 July 2013 09:45 Go to previous messageGo to next message
ContentAssist for ParamaterName.
Re: Scope for C# like Attribute-Class [message #1073310 is a reply to message #1073302] Wed, 24 July 2013 09:54 Go to previous messageGo to next message
Hmm sry i have no idea, can you share a pasteable grammar and scopeprovider?
Re: Scope for C# like Attribute-Class [message #1073335 is a reply to message #1073310] Wed, 24 July 2013 10:40 Go to previous messageGo to next message
Isn't that the problem with the difference between BatchScopeProvider and ScopeProvider, the first one being used for checking and a lot of stuff while the second one is only used for content assist?
(or something like that...)
Re: Scope for C# like Attribute-Class [message #1073337 is a reply to message #1073335] Wed, 24 July 2013 10:42 Go to previous messageGo to next message
sorry yes this might be the case if you use xbase. did not look so from what you have posted so far.
Re: Scope for C# like Attribute-Class [message #1073707 is a reply to message #1073337] Thu, 25 July 2013 06:44 Go to previous message
If you use xbase, that's the way I found to do it: http://www.eclipse.org/forums/index.php/mv/msg/465327/1073705/#msg_1073705
Previous Topic:"scope" problem
Next Topic:A simple error break a whole file: how to avoid?
Current Time: Sun Jul 27 18:42:26 EDT 2025
Powered by FUDForum. Page generated in 0.25160 seconds
