Home » Eclipse Projects » Requirements Modeling Framework  » Getting orphaned SpecObject back?
Getting orphaned SpecObject back? [message #1073307] Wed, 24 July 2013 09:48 Go to next message
Hello again,
I have looked around, but am unable to find out how to "un-orphan" a SpecObject. I can see it under the SpecObjects in the Outline view, but I cannot figure out how to get it back into the specifications. I have tried drag and drop, cut and paste, copy and paste all without success. The target specification in both the editor and the outline view will not accept a drop or paste. Is there a way to do this?
Thank you.
Jerry
Re: Getting orphaned SpecObject back? [message #1073309 is a reply to message #1073307] Wed, 24 July 2013 09:54 Go to previous message
Hi Jerry,
Drop and Drag used to work, if it doesn't you found a bug. Would be great if you could file it in Bugzilla - I'll try to get this into 0.8.0, due mid August.
For the time being, here is a workaround:
  1. Create an empty SpecHierarchy
  2. Select it
  3. In the Properties View, switch to "All Attributes"
  4. In "Object" you can select an existing SpecObject from the drop-down.
Best,
- Michael
Previous Topic:Easier selection?
Next Topic:RMF/ProR 0.8.0 released
Current Time: Sat Jul 26 20:43:47 EDT 2025
Powered by FUDForum. Page generated in 0.06658 seconds
