Home » Archived » BIRT » Read A CrossTab reptdesign from a java EE application (Error when reading a .reptDesign file and not when preiewing it in the birt report viewer)
Read A CrossTab reptdesign from a java EE application [message #1073162] |
Wed, 24 July 2013 04:48  |
hi, i am woeking on birt 4.2 and tomcat 6, struts 2 , i have designed a crosstab with birt, when i preview this it works, but when i try to open this file (".rptdeign") from my web application i have this stack trace:
Error.DesignFileException.SYNTAX_ERROR - 19 errors found!
1.) ( line = 4911, tag = extended-item) (Element = ExtendedItem, Name = null), org.eclipse.birt.report.model.api.command.ContentException (code = Error.ContentException.SLOT_IS_FULL, message : The slot(header) of the report.Body[0] is full.)
2.) ( line = 4917, tag = extended-item) (Element = ExtendedItem, Name = null), org.eclipse.birt.report.model.api.command.ContentException (code = Error.ContentException.SLOT_IS_FULL, message : The slot(header) of the report.Body[0] is full.)
3.) ( line = 4923, tag = extended-item) (Element = ExtendedItem, Name = null), org.eclipse.birt.report.model.api.command.ContentException (code = Error.ContentException.SLOT_IS_FULL, message : The slot(header) of the report.Body[0] is full.)
4.) ( line = 4930, tag = extended-item) (Element = ExtendedItem, Name = null), org.eclipse.birt.report.model.api.command.ContentException (code = Error.ContentException.SLOT_IS_FULL, message : The slot(header) of the report.Body[0] is full.)
5.) ( line = 4936, tag = extended-item) (Element = ExtendedItem, Name = null), org.eclipse.birt.report.model.api.command.ContentException (code = Error.ContentException.SLOT_IS_FULL, message : The slot(header) of the report.Body[0] is full.)
6.) ( line = 4937, tag = extended-item) (Element = ExtendedItem, Name = null), org.eclipse.birt.report.model.api.command.ContentException (code = Error.ContentException.SLOT_IS_FULL, message : The slot(header) of the report.Body[0] is full.)
7.) ( line = 4938, tag = extended-item) (Element = ExtendedItem, Name = null), org.eclipse.birt.report.model.api.command.ContentException (code = Error.ContentException.SLOT_IS_FULL, message : The slot(header) of the report.Body[0] is full.)
8.) ( line = 4945, tag = extended-item) (Element = ExtendedItem, Name = null), org.eclipse.birt.report.model.api.command.ContentException (code = Error.ContentException.SLOT_IS_FULL, message : The slot(header) of the report.Body[0] is full.)
9.) ( line = 4946, tag = extended-item) (Element = ExtendedItem, Name = null), org.eclipse.birt.report.model.api.command.ContentException (code = Error.ContentException.SLOT_IS_FULL, message : The slot(header) of the report.Body[0] is full.)
10.) ( line = 4947, tag = extended-item) (Element = ExtendedItem, Name = null), org.eclipse.birt.report.model.api.command.ContentException (code = Error.ContentException.SLOT_IS_FULL, message : The slot(header) of the report.Body[0] is full.)
11.) ( line = 4948, tag = extended-item) (Element = ExtendedItem, Name = null), org.eclipse.birt.report.model.api.command.ContentException (code = Error.ContentException.SLOT_IS_FULL, message : The slot(header) of the report.Body[0] is full.)
12.) ( line = 4955, tag = extended-item) (Element = ExtendedItem, Name = null), org.eclipse.birt.report.model.api.command.ContentException (code = Error.ContentException.SLOT_IS_FULL, message : The slot(header) of the report.Body[0] is full.)
13.) ( line = 4956, tag = extended-item) (Element = ExtendedItem, Name = null), org.eclipse.birt.report.model.api.command.ContentException (code = Error.ContentException.SLOT_IS_FULL, message : The slot(header) of the report.Body[0] is full.)
14.) ( line = 4957, tag = extended-item) (Element = ExtendedItem, Name = null), org.eclipse.birt.report.model.api.command.ContentException (code = Error.ContentException.SLOT_IS_FULL, message : The slot(header) of the report.Body[0] is full.)
15.) ( line = 4958, tag = extended-item) (Element = ExtendedItem, Name = null), org.eclipse.birt.report.model.api.command.ContentException (code = Error.ContentException.SLOT_IS_FULL, message : The slot(header) of the report.Body[0] is full.)
16.) ( line = 4965, tag = extended-item) (Element = ExtendedItem, Name = null), org.eclipse.birt.report.model.api.command.ContentException (code = Error.ContentException.SLOT_IS_FULL, message : The slot(header) of the report.Body[0] is full.)
17.) ( line = 4972, tag = extended-item) (Element = ExtendedItem, Name = null), org.eclipse.birt.report.model.api.command.ContentException (code = Error.ContentException.SLOT_IS_FULL, message : The slot(header) of the report.Body[0] is full.)
18.) ( line = 4979, tag = extended-item) (Element = ExtendedItem, Name = null), org.eclipse.birt.report.model.api.command.ContentException (code = Error.ContentException.SLOT_IS_FULL, message : The slot(header) of the report.Body[0] is full.)
19.) ( line = 4986, tag = extended-item) (Element = ExtendedItem, Name = null), org.eclipse.birt.report.model.api.command.ContentException (code = Error.ContentException.SLOT_IS_FULL, message : The slot(header) of the report.Body[0] is full.)
Current Time: Wed Jul 23 11:41:57 EDT 2025
Powered by FUDForum. Page generated in 0.15741 seconds
