Home » Modeling » EMF » Modeling implicits (how to?)
Modeling implicits (how to?) [message #1073100] Wed, 24 July 2013 02:19 Go to next message
Hi!
How to model things, which have some implicit, for example, containments? Lets take the following description: 'Pipeline can have some declared ports, and implicitly declares a port named 'source''
So, whenever I see something like
<pipeline>
  <port name="my-port" />
</pipeline>
I should treat it as it was
<pipeline>
  <port name="source" />
</pipeline>
I'm thinking of two approaches to model that thing:
1. Overriding generated getPort code (not exactly overriding, but creating getPortGen method to be able to re-generate the code), than returning the DelegatingEList, that can add new ports to original backing list (from getPort), and will always return implicits in it's get methods.
2. Creating one more feature (like allPorts) and doing things in getAllPorts, returning an UnmodifiableEList.
Is there any (better) ways of modeling implicits? Is there any implemented examples I can learn from?
Re: Modeling implicits (how to?) [message #1073109 is a reply to message #1073100] Wed, 24 July 2013 02:50 Go to previous messageGo to next message
Leonid,
Comments below.
On 24/07/2013 8:19 AM, Leonid Ripeynih wrote:
> Hi!
> <pipeline>
> </pipeline>
> <pipeline>
> </pipeline>
> get methods.
That sounds problematic. EcoreUtil.copy will copy them all and the
serializer will serialize them all. So how to deal with something
that's implicitly there also being explicitly added during
deserialization and copying
Such a feature could be transient, derived, and read only, so it
wouldn't be serialized, wouldn't be copied, and wouldn't be changeable.
But a derived reference can't be a containment reference (because an
EObject x knows it's contained by x.eContainer() and knows that it's in
x.eContainer().eGet(x.eContainmentReference()), so you'd also need to
model a containment reference to contain the implicit port; if that
feature is also transient, derived, and read only, you could populate it
in the constructor.
I can't think of any examples just like this. Depending on your goal,
you could avoid this entirely and instead define a constraint or
invariant that a Pipeline must have a first port named "source" if it
has any ports, and specialize the Pipeline item provider's command
creation to try to maintain this constraint, i.e., when a Port is added
to a Pipeline, you add two ports if there are currently none...
Re: Modeling implicits (how to?) [message #1073146 is a reply to message #1073109] Wed, 24 July 2013 04:09 Go to previous messageGo to next message
Ed Merks wrote on Wed, 24 July 2013 02:50
In that context, implicit means, it will never be added explicitly, and adding another port named 'source' will just violate constraint on unique port name, just like adding two ports named 'my-port' will. Also, backing list is featureMap.list, so any features already marked as transient, derived and volatile. Does it make it a better idea in that case?
in the constructor.
Am I understand you correctly, that we're forcing a user of the model to read from one feature (say, 'allPorts') to get the whole picture, and write to another (say, 'ports')? And writing to allPorts shoud be prohibited, and allPorts should be UnmodifiableEList?
I think you didn't understand me entirely. Pipeline will always have the 'source' port, and can have arbitrary number of user defined ports. But 'source' is always here, ready to be connected and referenced by pipes. And that port will never appear in serialized XML. So, any ways to make sure it's here from the moment pipeline is created?
Thanks for you attention.
Re: Modeling implicits (how to?) [message #1073180 is a reply to message #1073146] Wed, 24 July 2013 05:19 Go to previous message
Leonid,
Comments below.
> that case?
It's hard to say without the full details of the model.
>> changeable. But a derived reference can't be a containment reference
>> (because an EObject x knows it's contained by x.eContainer() and
>> knows that it's in x.eContainer().eGet(x.eContainmentReference()), so
>> you'd also need to model a containment reference to contain the
>> implicit port; if that feature is also transient, derived, and read
>> only, you could populate it in the constructor.
I thought that was your proposal...
>> goal, you could avoid this entirely and instead define a constraint
>> or invariant that a Pipeline must have a first port named "source" if
>> it has any ports, and specialize the Pipeline item provider's command
>> added to a Pipeline, you add two ports if there are currently none...
I see.
I see.
You can do things in the constructor, and assuming you've got things set
up so that EcoreUtil.copy doesn't duplicate the implicit "always there"
port, that nothing ever deletes it, and that's it's not serialized and
hence not deserialized, I suppose that should work.
So if you think you have it right, test if EcoreUtil.copy works properly
and that save/load round-trips it properly.
Previous Topic:EMF and memory usage
Next Topic:Resolve PlatformPlugin-URIs to file URIs in a test setup
Current Time: Wed Jul 30 10:22:30 EDT 2025
Powered by FUDForum. Page generated in 0.03471 seconds
