Home » Archived » Test and Performance Tools Platform (TPTP) » AGR execution hangs in standard mode
AGR execution hangs in standard mode [message #106935] |
Tue, 31 July 2007 10:37  |
Hi All,
I have two machines with seemingly the same configuration and one of
them runs UI tests without problems and the other hangs as described in
other posts in here.
I have gone through the previous posts on this subject and eliminated
the Java 6 JRE problem.
I have also tested the "Profiling and logging" hosts connections and I
am getting the same results on both machines - success for direct
connection and "ac not available" for localhost.
After the machine hangs and I cancel the launch it leaves a java process
running which causes the previously mentioned connection test on
localhost fail with a message saying something about "direct connection
active". When I kill the extra java process I get the previous
connection test results again.
Obviously I am missing some other important difference between the two
machines, otherwise they would bot behave the same.
Any ideas on this problem will be appreciated.
Cheers
Martin
Re: AGR execution hangs in standard mode [message #107039 is a reply to message #107001] |
Wed, 01 August 2007 08:50   |
Hi Paul,
I use the IAC and version of TPTP is is v4.2.0 - that's what we are
required to use at the moment, i.e. no upgrading to the latest version
possible.
I did read all of the thread you mention, but that was no help in my
case unfortunately.
Following is the configuration information from the Eclipse where the
hang occurs. Hope that could be of some help.
Cheers
Martin
*** Date: Wed Aug 01 13:44:08 BST 2007
*** Platform Details:
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.buildId=M20060921-0945
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-launcher
G:\SDEJ_UIMEditor\build\guitestenv\eclipse.exe
-name
Eclipse
-showsplash
600
-exitdata
f78_78
-vm
C:\WINDOWS\system32\javaw.exe
eclipse.ee.install.verify=false
eclipse.product=org.eclipse.sdk.ide
eclipse.startTime=1185972136687
eclipse.vm=C:\WINDOWS\system32\javaw.exe
eclipse.vmargs=-Xms40m
-Xmx256m
-jar
G:\SDEJ_UIMEditor\build\guitestenv\startup.jar
eof=eof
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=G:\SDEJ_UIMEditor\build\guitestenv\startup.j ar
java.class.version=49.0
java.endorsed.dirs=C:\Program Files\Java\jre1.5.0_12\lib\endorsed
java.ext.dirs=C:\Program Files\Java\jre1.5.0_12\lib\ext
java.home=C:\Program Files\Java\jre1.5.0_12
java.io.tmpdir=C:\DOCUME~1\MVik\LOCALS~1\Temp\
java.library.path=C:\WINDOWS\system32;.;C:\WINDOWS\system32; C:\WINDOWS;C:\Program
Files\GnuWin32\bin;C:\Program
Files\Perl\bin;C:\oracle\ora92\bin;C:\WINDOWS\system32;C:\WI NDOWS;C:\WINDOWS\System32\Wbem;C:\Program
Files\Microsoft Office\OFFICE11\Business Contact Manager\IM;C:\Program
Files\Microsoft SQL Server\80\Tools\Binn;C:\Program Files\Microsoft
Manager;C:\java\jdk5\bin;C:\java\j2sdkee1.3.1\bin;C:\Program
Files\apache-ant-1.6.2\bin;C:/oracle/ora92\jdbc\lib\classes1 2.zip;C:\Program
Files\Rational\ClearQuest;C:\bin;C:\Program
Files\Aspell\bin;C:\hyades-rac\bin;C:\Program
Files\Rational\common;C:\groovy\bin;C:\Program
Files\Subversion\bin;C:\Program Files\Common
Files\GTK\2.0\bin;C:\Program Files\Rational\ClearCase\bin;C:\Program
Files\Maven1.0.2\bin
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.5.0_12-b04
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.5
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.5.0_12
java.vm.info=mixed mode, sharing
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.5.0_12-b04
line.separator=
org.osgi.framework.bootdelegation=*
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5
org.osgi.framework.language=en
org.osgi.framework.os.name=WindowsXP
org.osgi.framework.os.version=5.1
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax .activity,javax.crypto,javax.crypto.interfaces,javax.crypto. spec,javax.imageio,javax.imageio.event,javax.imageio.metadat a,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax .imageio.spi,javax.imageio.stream,javax.management,javax..ma nagement.loading,javax.management.modelmbean,javax.managemen t.monitor,javax.management.openmbean,javax.management.relati on,javax.management.remote,javax.management.remote.rmi,javax .management.timer,javax.naming,javax.naming.directory,javax. naming.event,javax.naming.ldap,javax.naming.spi,javax.net,ja vax.net.ssl,javax.print,javax.print.attribute,javax.print.at tribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA ,javax.rmi.ssl,javax.security.auth,javax.security.auth.callb ack,javax.security.auth.kerberos,javax.security.auth.login,j avax.security.auth.spi,javax.security.auth.x500,javax.securi ty.cert,javax.security.sasl,javax.sound.midi,javax.sound.mid i.spi,javax.sound.sampled,java
x.sound.sampled.spi,javax.sql,javax.sql.rowset,javax.sql.row set.serial,javax.sql.rowset.spi,javax.swing,javax.swing.bord er,javax.swing.colorchooser,javax.swing.event,javax.swing.fi lechooser,javax.swing.plaf,javax.swing.plaf.basic,javax.swin g.plaf.metal,javax.swing.plaf.multi,javax.swing.plaf.synth,j avax.swing.table,javax.swing.text,javax.swing.text.html,java x.swing.text.html.parser,javax.swing.text.rtf,javax.swing.tr ee,javax.swing.undo,javax.transaction,javax.transaction.xa,j avax.xml,javax.xml.datatype,javax.xml.namespace,javax.xml.pa rsers,javax.xml.transform,javax.xml.transform.dom,javax.xml. transform.sax,javax.xml.transform.stream,javax.xml.validatio n,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,org.omg.CORBA_ 2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynAnyPackage,o rg.omg.CORBA.ORBPackage,org.omg.CORBA.portable,org.omg.CORBA .TypeCodePackage,org.omg.CosNaming,org.omg.CosNaming.NamingC ontextExtPackage,org.omg.CosNaming.NamingContextPackage,org. omg.Dynamic,org.omg.DynamicAny
,org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny. DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,or g.omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInt erceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org. omg.PortableServer,org.omg.PortableServer.CurrentPackage,org .omg.PortableServer.POAManagerPackage,org.omg.PortableServer .POAPackage,org.omg.PortableServer.portable,org.omg.Portable Server.ServantLocatorPackage,org.omg.SendingContext,org.omg. stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom. events,org.w3c.dom.ls,org.xml.sax,org.xml.sax.ext,org.xml.sa x.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.3.0
org.osgi.supports.framework.extension=true
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.bundles=org.eclipse.equinox.common@2:start,
org.eclipse.update.configurator@3:start, org.eclipse.core.runtime@start
osgi.bundlestore=G:\SDEJ_UIMEditor\build\guitestenv\configur ation\org.eclipse.osgi\bundles
osgi.configuration.area=file:/G:/SDEJ_UIMEditor/build/guites tenv/configuration/
osgi.framework=file:/g:/SDEJ_UIMEditor/build/guitestenv/plug ins/org.eclipse.osgi_3.2.1.R32x_v20060919.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.2.1.R32x_v20060919
osgi.install.area=file:/G:/SDEJ_UIMEditor/build/guitestenv/
osgi.instance.area=file:/G:/SDEJ_UIMEditor/build/guitestenv/ test-workspace/
osgi.instance.area.default=file:/C:/Documents and Settings/MVik/workspace/
osgi.logfile=G:\SDEJ_UIMEditor\build\guitestenv\test-workspa ce\.metadata\.log
osgi.manifest.cache=G:\SDEJ_UIMEditor\build\guitestenv\confi guration\org.eclipse.osgi\manifests
osgi.nl=en_IE
osgi.os=win32
osgi.splashLocation=g:\SDEJ_UIMEditor\build\guitestenv\plugi ns\org.eclipse.platform_3.2.0.v20060601\splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=g:\SDEJ_UIMEditor\build\guitestenv\plugins
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=C:\Program
Files\Java\jre1.5.0_12\lib\rt.jar;C:\Program
Files\Java\jre1.5.0_12\lib\i18n.jar;C:\Program
Files\Java\jre1.5.0_12\lib\sunrsasign.jar;C:\Program
Files\Java\jre1.5.0_12\lib\jsse.jar;C:\Program
Files\Java\jre1.5.0_12\lib\jce.jar;C:\Program
Files\Java\jre1.5.0_12\lib\charsets.jar;C:\Program
Files\Java\jre1.5.0_12\classes
sun.boot.library.path=C:\Program Files\Java\jre1.5.0_12\bin
sun.cpu.endian=little
sun.cpu.isalist=
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.java.launcher=SUN_STANDARD
sun.jnu.encoding=Cp1252
sun.management.compiler=HotSpot Client Compiler
sun.os.patch.level=Service Pack 2
user.country=IE
user.dir=G:\SDEJ_UIMEditor\build\guitestenv
user.home=C:\Documents and Settings\MVik
user.language=en
user.name=MVlk
user.timezone=Europe/London
user.variant=
workspace.projectclasspath=G:\SDEJ_UIMEditor\build\guitesten v\test-workspace\gui-test-suite\bin
*** Features:
com.lowagie.itext (1.3.0.N20060628-1351) "Lowagie Itext"
org.apache.batik (1.6.0.N20060628-1351) "Apache Batik"
org.apache.batik.pdf (1.6.0.N20060628-1351) "Apache Batik Pdf"
org.apache.commons.codec (1.3.0.N20060628-1351) "Apache Commons Codec"
org.apache.derby.core (10.1.2.1) "Apache Derby Core Plug-in for Eclipse"
org.eclipse.birt (2.1.0.N20060628-1351) "Business Intelligence and
Reporting Tools"
org.eclipse.birt.chart (2.1.0.N20060628-1351) "BIRT Chart Framework"
org.eclipse.birt.chart.cshelp (2.1.0.N20060628-1351) "BIRT Chart
Context-sensitive Help"
org.eclipse.birt.chart.doc.isv (2.1.0.N20060628-1351) "BIRT Chart ISV
Documentation"
org.eclipse.birt.chart.runtime (2.1.0.N20060628-1351) "BIRT Chart Runtime"
org.eclipse.birt.cshelp (2.1.0.N20060628-1351) "BIRT Context-sensitive Help"
org.eclipse.birt.doc (2.1.0.N20060628-1351) "BIRT Documentation"
org.eclipse.birt.doc.isv (2.1.0.N20060628-1351) "BIRT ISV Documentation"
org.eclipse.birt.example (2.1.0.N20060628-1351) "BIRT Example"
org.eclipse.birt.report.designer (2.1.0.N20060628-1351) "BIRT Report
Designer"
org.eclipse.birt.report.runtime (2.1.0.N20060628-1351) "BIRT Report Runtime"
org.eclipse.datatools.connectivity.oda.designer.feature
(0.9.0.200606161) "Eclipse Data Tools Platform Connectivity Open Data
Access (ODA) Designer"
org.eclipse.datatools.connectivity.oda.feature (0.9.0.200606161)
"Eclipse Data Tools Platform Connectivity Open Data Access (ODA)"
org.eclipse.emf (2.2.1.v200609210005) "Eclipse Modeling Framework (EMF)"
org.eclipse.emf.doc (2.2.1.v200609210005) "Eclipse Modeling Framework
(EMF) Programmers Guide"
org.eclipse.emf.ecore.sdo (2.2.0.v200609210005) "EMF Service Data
Objects (SDO)"
org.eclipse.emf.ecore.sdo.doc (2.2.1.v200609210005) "EMF Service Data
Objects (SDO) Programmers Guide"
org.eclipse.emf.ecore.sdo.source (2.2.0.v200609210005) "EMF Service Data
Objects (SDO) Source"
org.eclipse.emf.source (2.2.1.v200609210005) "Eclipse Modeling Framework
(EMF) Source"
org.eclipse.gef (3.2.1.v20060921) "Graphical Editing Framework"
org.eclipse.gef.sdk (3.2.1.v20060921) "Graphical Editing Framework
Developer Resources"
org.eclipse.gef.source (3.2.1.v20060921) "Graphical Editing Framework
org.eclipse.jdt (3.2.1.r321_v20060905-R4CM1Znkvre9wC-) "Eclipse Java
Development Tools"
org.eclipse.jdt.source (3.2.1.r321_v20060905-R4CM1Znkvre9wC-) "Eclipse
Java Development Tools SDK"
org.eclipse.jem (1.2.0.v20060530_RC2--ZasJzJJez) "Java EMF Model"
org.eclipse.jem.sdk (1.2.0.v20060530_RC2--FEM8P88GP) "Java EMF Model SDK"
org.eclipse.jem.source (1.2.0.v20060530_RC2--ZasJzJJez) "Java EMF Model
Source"
org.eclipse.jst (1.5.0.v200606092300-kW-O_ysCRLJsxJt) "J2EE Standard
Tools (JST)"
org.eclipse.pde (3.2.1.r321_v20060823-6vYLLdQ3Nk8DrFG) "Eclipse Plug-in
Development Environment"
org.eclipse.pde.source (3.2.1.r321_v20060823-6vYLLdQ3Nk8DrFG) "Eclipse
Plug-in Development Environment Developer Resources"
org.eclipse.platform (3.2.1.r321_v20060921-b_XVA-INSQSyMtx) "Eclipse
Platform"
org.eclipse.platform.source (3.2.1.r321_v20060921-b_XVA-INSQSyMtx)
"Eclipse Platform Plug-in Developer Resources"
org.eclipse.rcp (3.2.1.r321_v20060801-2ekW2BxmcpPUOoq) "Eclipse RCP"
org.eclipse.rcp.source (3.2.1.r321_v20060801-2ekW2BxmcpPUOoq) "Eclipse
RCP Plug-in Developer Resources"
org.eclipse.sdk (3.2.1.r321_v20060801-tQ1w49KnTArT0FZ) "Eclipse Project SDK"
org.eclipse.tptp.monitoring (4.2.0.v200606131519--_OmSTOTOd6a3aR) "TPTP
Monitoring"
org.eclipse.tptp.monitoring.doc.user
(4.2.0.v200606121835--0842282835373A) "TPTP Monitoring Project
Documentation"
org.eclipse.tptp.monitoring.examples
(4.2.0.v200606121835--0842282835373A) "User examples for the TPTP
Monitoring Tools Plugins"
org.eclipse.tptp.monitoring.profile.server
(4.1.100.v200606131519--0842282835373A) "TPTP Profile On Server Logging
Utility"
org.eclipse.tptp.monitoring.report.birt
(4.2.0.v200606131519--2PD88P8PAGAMAY) "BIRT Monitor Reports for TPTP
Branding Plugin"
org.eclipse.tptp.platform.analysis (4.2.0.v200606131519--3YIAAYAYEMEUEk)
"TPTP Analysis"
org.eclipse.tptp.platform.analysis.codereview.java
(4.2.0.v200606131519--1G955G5G7A7E7M) "Java Code Review Plug-in"
org.eclipse.tptp.platform.analysis.engine
(4.2.0.v200606131519--1G955G5G7A7E7M) "TPTP Analysis Engine"
org.eclipse.tptp.platform.core (4.2.0.v200606150100--Cq0bcpcppNmQn0)
"TPTP Platform"
org.eclipse.tptp.platform.core.doc.user
(4.2.0.v200606121835--1G955G5G7A7E7M) "TPTP Platform Project Documentation"
org.eclipse.tptp.platform.doc.user (4.2.0.v200606121835-8AcKKEiFfIYIiEo)
org.eclipse.tptp.platform.examples (4.2.0.v200606121835--0842282835373A)
"TPTP Platform Examples"
org.eclipse.tptp.platform.lta (4.2.0.v200606131519--1G955G5G7A7E7M)
"TPTP Log and Trace Analyzer"
org.eclipse.tptp.platform.probekit (4.2.0.v200606131519--3YIAAYAYEMEUEk)
"TPTP ProbeKit"
org.eclipse.tptp.platform.probekit.doc.user
(4.2.0.v200606121835--0842282835373A) "Probekit User Documentation"
org.eclipse.tptp.platform.profile.server
(4.1.100.v200606180100--2PD88P8PAGAMAY) "TPTP Profile on Server"
org.eclipse.tptp.platform.report (4.1.100.v200606150100--2PD88P8PAGAMAY)
"TPTP Charting Service"
org.eclipse.tptp.platform.report.birt
(4.2.0.v200606131519--1G955G5G7A7E7M) "BIRT Reporting for TPTP Branding
plugin"
org.eclipse.tptp.platform.samples (4.2.0.v200606131519--2PD88P8PAGAMAY)
"TPTP Platform Samples"
org.eclipse.tptp.platform.statistical.ui
(4.1.100.v200606131519--1G955G5G7A7E7M) "TPTP Statistical UI"
org.eclipse.tptp.platform.trace (4.2.0.v200606131519--2PD88P8PAGAMAY)
"TPTP Platform Trace"
org.eclipse.tptp.test (4.2.0.v200606131519--4hNDDhDhISIcIw) "TPTP Test"
org.eclipse.tptp.test.auto (4.1.100.v200606131519--1G955G5G7A7E7M) "TPTP
Automated GUI Recording and Playback"
org.eclipse.tptp.test.doc.user (4.2.0.v200606121835--0842282835373A)
"Test Tools User Documentation"
org.eclipse.tptp.test.report.birt (4.2.0.v200606131519--2PD88P8PAGAMAY)
"BIRT Test Reports for TPTP Branding Plugin"
org.eclipse.tptp.test.samples (4.1.100.v200606131519--0842282835373A)
"TPTP Test Samples"
org.eclipse.tptp.test.tools (4.2.0.v200606131519--2PD88P8PAGAMAY) "TPTP
Test Tools"
org.eclipse.tptp.trace (4.1.100.v200606131519--1G955G5G7A7E7M) "TPTP Trace"
org.eclipse.tptp.trace.report.birt (4.2.0.v200606131519--2PD88P8PAGAMAY)
"BIRT Trace Reports for TPTP Branding Plugin"
org.eclipse.uml2 (2.0.2.v200610251409) "UML2"
org.eclipse.uml2.doc (2.0.2.v200610251409) "UML2 Documentation"
org.eclipse.uml2.examples (2.0.2.v200610251409) "UML2 Examples"
org.eclipse.uml2.examples.source (2.0.2.v200610251409) "UML2 Examples
Source"
org.eclipse.uml2.source (2.0.2.v200610251409) "UML2 Source"
org.eclipse.wst (1.5.0.v200606092300-U4T922yjOWsGK5Y) "Web Standard
Tools (WST)"
org.eclipse.xsd (2.2.1.v200609210005) "XML Schema Infoset Model (XSD)"
org.eclipse.xsd.doc (2.2.1.v200609210005) "XML Schema Infoset Model
(XSD) Programmers Guide"
org.eclipse.xsd.source (2.2.1.v200609210005) "XML Schema Infoset Model
(XSD) Source"
org.mozilla.rhino (1.6.0.N20060628-1351) "Mozilla Rhino"
org.w3c.sac (1.3.0.N20060628-1351) "W3C Sac"
*** Plug-in Registry:
com.ibm.etools.emf.event (3.0.0.v20060518_RC1) "Event Model" [Resolved]
com.ibm.icu (3.4.5) "International Components for Unicode for Java
(ICU4J)" [Active]
com.ibm.icu.source (3.4.5) "International Components for Unicode for
Java (ICU4J) source plug-in" [Resolved]
com.jcraft.jsch (0.1.28) "JSch" [Resolved]
com.lowagie.itext (1.3.0.N20060628-1351) "Lowagie Itext" [Resolved]
curam.internal.cmdleditor (1.0.0) "Curam Modeling Environment" [Resolved]
curam.internal.commons.eclipse (1.0.0) "Cúram (Internal) Commons for
Eclipse" [Resolved]
curam.internal.commons.eclipse.ui (1.0.0) "Cúram (Internal) Commons for
Eclipse UI" [Resolved]
curam.internal.commons.eclipse.ui.forms (1.0.0) "Cúram (Internal)
Commons for Generated Eclipse Forms" [Resolved]
curam.internal.libraries (1.0.0) "ThirdPartyTools Wrapper" [Resolved]
curam.internal.semdev.modelling.umlextensions (1.0.0) "Cúram Model UML2
Resources" [Resolved]
org.apache.ant (1.6.5) "Apache Ant" [Resolved]
org.apache.axis (1.3.0.v200606181221) "Apache Axis 1.3.0" [Resolved]
org.apache.batik (1.6.0.N20060623-1511) "Apache Batik" [Resolved]
org.apache.batik (1.6.0.v20060613-1220) "Apache Batik" [Resolved]
org.apache.batik.pdf (1.6.0.N20060623-1511) "Apache Batik Pdf" [Resolved]
org.apache.batik.pdf (1.6.0.v20060613-1220) "Apache Batik Pdf" [Resolved]
org.apache.cactus (1.7.2.v200606181221) "Cactus Resource Plug-in" [Resolved]
org.apache.commons_logging (1.0.4.v200606131651) "Apache commons logging
Plug-in" [Resolved]
[Resolved]
[Resolved]
org.apache.jakarta_log4j (1.2.8.v200606131651) "Apache Jakarta log4j
Plug-in" [Resolved]
org.apache.lucene (1.4.103.v20060601) "Apache Lucene" [Resolved]
org.apache.wsil4j (1.0.0.v200606181221) "Apache WSIL4J 1.0" [Resolved]
org.apache.xerces (2.8.0.N20060623-1511) "Xerces 2.8.0" [Resolved]
org.apache.xerces (2.8.0.v200606131651) "Xerces 2.8.0" [Resolved]
org.eclipse.ant.core (3.1.100.v20060531) "Ant Build Tool Core" [Resolved]
org.eclipse.ant.ui (3.2.1.r321_v20060828) "Ant UI" [Resolved]
Reporting Tools" [Resolved]
[Resolved]
Context-sensitive Help" [Resolved]
org.eclipse.birt.chart.device.extension (2.1.0.N20060628-1351) "BIRT
Chart Device Extension(s)" [Resolved]
org.eclipse.birt.chart.device.pdf (2.1.0.N20060628-1351) "BIRT Chart
Device PDF Extension" [Resolved]
org.eclipse.birt.chart.device.svg (2.1.0.N20060628-1351) "BIRT Chart
Device SVG Extension" [Resolved]
org.eclipse.birt.chart.device.swt (2.1.0.N20060628-1351) "BIRT Chart
Device SWT Extension" [Resolved]
Documentation" [Resolved]
org.eclipse.birt.chart.engine (2.1.0.N20060628-1351) "BIRT Chart Engine"
[Resolved]
org.eclipse.birt.chart.engine.extension (2.1.0.N20060628-1351) "BIRT
Chart Engine Extension" [Resolved]
org.eclipse.birt.chart.examples (2.1.0.N20060628-1351) "BIRT Chart
Examples Plug-in" [Resolved]
org.eclipse.birt.chart.reportitem (2.1.0.N20060628-1351) "BIRT
Chart-Report Integration" [Resolved]
org.eclipse.birt.chart.reportitem.ui (2.1.0.N20060628-1351) "BIRT
Chart-Report UI Integration Plug-in" [Resolved]
Runtime" [Resolved]
org.eclipse.birt.chart.ui (2.1.0.N20060628-1351) "BIRT Chart Library UI
Plug-in" [Resolved]
org.eclipse.birt.chart.ui.extension (2.1.0.N20060628-1351) "BIRT Chart
UI Extension" [Resolved]
org.eclipse.birt.core (2.1.0.N20060628-1351) "BIRT Core Package" [Resolved]
org.eclipse.birt.core.ui (2.1.0.N20060628-1351) "BIRT Core UI" [Resolved]
Help" [Resolved]
org.eclipse.birt.data (2.1.0.N20060628-1351) "BIRT Data Engine" [Resolved]
org.eclipse.birt.data.oda (2.0.2.N20060628-1351) "BIRT Open Data Access"
[Resolved]
org.eclipse.birt.data.oda.adapter.dtp (2.0.0.N20060628-1351) "BIRT-DTP
ODA Adapter Plug-in" [Resolved]
org.eclipse.birt.doc (2.1.0.N20060628-1351) "BIRT Documentation" [Resolved]
[Resolved]
org.eclipse.birt.example (2.1.0.N20060628-1351) "BIRT Example" [Resolved]
org.eclipse.birt.report.data.adapter (2.1.0.N20060628-1351) "BIRT Data
Adapter" [Resolved]
org.eclipse.birt.report.data.oda.jdbc (2.1.0.N20060628-1351) "BIRT
ODA-JDBC Bridge Driver" [Resolved]
org.eclipse.birt.report.data.oda.jdbc.ui (2.1.0.N20060628-1351) "BIRT
JDBC UI Plug-in" [Resolved]
org.eclipse.birt.report.data.oda.sampledb (2.1.0.N20060628-1351) "BIRT
Sample Database" [Resolved]
org.eclipse.birt.report.data.oda.sampledb.ui (2.1.0.N20060628-1351)
"BIRT Sample Database UI Plug-in" [Resolved]
org.eclipse.birt.report.data.oda.xml (2.1.0.N20060628-1351) "BIRT
ODA-XML Driver" [Resolved]
org.eclipse.birt.report.data.oda.xml.ui (2.1.0.N20060628-1351) "BIRT XML
org.eclipse.birt.report.debug.ui (2.1.0.N20060628-1351) "BIRT debug
Plug-in" [Active]
Designer" [Resolved]
org.eclipse.birt.report.designer.core (2.1.0.N20060628-1351) "BIRT
Designer Core" [Resolved]
org.eclipse.birt.report.designer.example.samplereport
(2.1.0.N20060628-1351) "BIRT Samplereport Plug-in" [Resolved]
org.eclipse.birt.report.designer.ui (2.1.0.N20060628-1351) "BIRT
Designer UI" [Resolved]
org.eclipse.birt.report.designer.ui.editors (2.1.0.N20060628-1351) "Rdt
Plug-in" [Resolved]
org.eclipse.birt.report.designer.ui.editors.schematic
(2.1.0.N20060628-1351) "BIRT Editors Plug-in" [Resolved]
org.eclipse.birt.report.designer.ui.ide (2.1.0.N20060628-1351) "BIRT
Designer UI for IDE" [Resolved]
org.eclipse.birt.report.designer.ui.lib (2.1.0.N20060628-1351) "BIRT
Designer UI for Library" [Resolved]
org.eclipse.birt.report.designer.ui.lib.explorer (2.1.0.N20060628-1351)
"BIRT Library Explorer Plug-in" [Resolved]
org.eclipse.birt.report.designer.ui.preview (2.1.0.N20060628-1351) "BIRT
Preview Plug-in" [Resolved]
org.eclipse.birt.report.engine (2.1.0.N20060628-1351) "BIRT Engine"
[Resolved]
org.eclipse.birt.report.engine.emitter.html (2.1.0.N20060628-1351) "BIRT
HTML Emitter" [Resolved]
org.eclipse.birt.report.engine.emitter.pdf (2.1.0.N20060628-1351) "BIRT
PDF emitter" [Resolved]
org.eclipse.birt.report.engine.fonts (2.1.0.N20060628-1351) "BIRT Engine
fonts" [Resolved]
org.eclipse.birt.report.model (2.1.0.N20060628-1351) "BIRT Model" [Resolved]
org.eclipse.birt.report.model.adapter.oda (2.1.0.N20060628-1351) "BIRT
Model ODA Adapter" [Resolved]
Runtime" [Resolved]
org.eclipse.birt.report.viewer (2.1.0.N20060628-1351) "BIRT Web Viewer"
[Active]
org.eclipse.compare (3.2.1.M20060711) "Compare Support" [Resolved]
org.eclipse.core.boot (3.1.100.v20060603) "Core Boot" [Resolved]
org.eclipse.core.commands (3.2.0.I20060605-1400) "Commands" [Resolved]
org.eclipse.core.contenttype (3.2.0.v20060603) "Eclipse Content
Mechanism" [Active]
org.eclipse.core.expressions (3.2.1.r321_v20060721) "Expression
Language" [Active]
org.eclipse.core.filebuffers (3.2.1.r321_v20060721) "File Buffers" [Active]
org.eclipse.core.filesystem (1.0.0.v20060603) "Core File Systems" [Resolved]
org.eclipse.core.filesystem.win32.x86 (1.0.0.v20060603) "Core File
System for Windows" [Resolved]
org.eclipse.core.jobs (3.2.0.v20060603) "Eclipse Jobs Mechanism" [Active]
org.eclipse.core.resources (3.2.1.R32x_v20060914) "Core Resource
Management" [Active]
org.eclipse.core.resources.compatibility (3.2.0.v20060603) "Core
Resource Management Compatibility Fragment" [Resolved]
org.eclipse.core.resources.win32 (3.2.0.v20060603) "Core Resource
Management Win32 Fragment" [Resolved]
org.eclipse.core.runtime (3.2.0.v20060603) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.1.100.v20060603) "Core Runtime
Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.0.v20060601)
"Authorization Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.registry (3.2.1.R32x_v20060907)
"Eclipse Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.1.100.v20060605) "Core Variables" [Resolved]
org.eclipse.datatools.connectivity (0.9.0.200606131) "Data Tools
Platform Connectivity Plug-in" [Resolved]
org.eclipse.datatools.connectivity.oda (3.0.1.200606081) "DTP Open Data
Access" [Resolved]
org.eclipse.datatools.connectivity.oda.consumer (3.0.1.200606071) "DTP
ODA Consumer Helper Component Plug-in" [Resolved]
org.eclipse.datatools.connectivity.oda.design (3.0.0.200605231) "DTP ODA
Design Session Model" [Resolved]
org.eclipse.datatools.connectivity.oda.design.ui (3.0.1.200606021) "DTP
ODA Designer UI Framework Plug-in" [Resolved]
org.eclipse.datatools.connectivity.oda.designer.finfo (0.9.0.200606161)
org.eclipse.datatools.connectivity.oda.finfo (0.9.0.200606161) "Eclipse
Data Tools Platform Connectivity Open Data Access (ODA)" [Resolved]
org.eclipse.datatools.connectivity.oda.flatfile (3.0.0.200606081) "DTP
ODA Flat File Run-time Driver" [Resolved]
org.eclipse.datatools.connectivity.oda.flatfile.ui (3.0.0.200606081)
"DTP ODA Flat File Designer" [Resolved]
org.eclipse.datatools.connectivity.oda.profile (3.0.0.200605101) "DTP
ODA Connection Profile Framework Plug-in" [Resolved]
org.eclipse.datatools.connectivity.ui (0.9.0.200606131) "Data Tools
Platform Connectivity UI Plug-in" [Resolved]
org.eclipse.datatools.connectivity.ui.dse (0.9.0.200606131) "Eclipse
Data Tools Platform Data Source Explorer Plug-in" [Resolved]
org.eclipse.debug.core (3.2.1.v20060823) "Debug Core" [Active]
org.eclipse.debug.ui (3.2.1.v20060823) "Debug UI" [Active]
org.eclipse.draw2d (3.2.1.v20060921) "Draw2d" [Resolved]
org.eclipse.draw2d.doc.isv (3.2.0.v20060626) "Draw2D Documentation"
[Resolved]
org.eclipse.emf (2.2.0.v200609210005) "Eclipse Modeling Framework (EMF)"
[Resolved]
org.eclipse.emf.ant (2.2.0.v200609210005) "EMF Ant Tasks" [Resolved]
org.eclipse.emf.cheatsheets (2.2.0.v200609210005) "EMF Cheat Sheets"
[Resolved]
org.eclipse.emf.codegen (2.2.1.v200609210005) "EMF Template Code
Generator" [Resolved]
org.eclipse.emf.codegen.ecore (2.2.1.v200609210005) "EMF Ecore Code
Generation" [Resolved]
org.eclipse.emf.codegen.ecore.ui (2.2.1.v200609210005) "EMF Ecore Code
Generation UI" [Resolved]
org.eclipse.emf.codegen.ui (2.1.0.v200609210005) "EMF Template Code
Generator UI" [Resolved]
org.eclipse.emf.common (2.2.1.v200609210005) "EMF Common" [Active]
org.eclipse.emf.common.ui (2.2.1.v200609210005) "EMF Common UI" [Resolved]
org.eclipse.emf.commonj.sdo (2.1.0.v200609210005) "CommonJ SDO" [Resolved]
org.eclipse.emf.converter (2.2.1.v200609210005) "EMF Model Convert
Support" [Resolved]
(EMF) Programmers Guide" [Resolved]
org.eclipse.emf.ecore (2.2.1.v200609210005) "EMF Ecore" [Active]
org.eclipse.emf.ecore.change (2.2.0.v200609210005) "EMF Ecore Change
Model" [Resolved]
org.eclipse.emf.ecore.change.edit (2.2.0.v200609210005) "EMF Ecore
Change Edit Support" [Resolved]
org.eclipse.emf.ecore.edit (2.2.0.v200609210005) "EMF Ecore Edit
Support" [Resolved]
org.eclipse.emf.ecore.editor (2.2.0.v200609210005) "Sample Ecore Editor"
[Resolved]
Objects (SDO)" [Resolved]
Objects (SDO) Programmers Guide" [Resolved]
org.eclipse.emf.ecore.sdo.edit (2.2.0.v200609210005) "EMF Service Data
Objects (SDO) Edit Support" [Resolved]
org.eclipse.emf.ecore.sdo.editor (2.2.0.v200609210005) "EMF Service Data
Objects (SDO) Editor" [Resolved]
Objects (SDO) Source" [Resolved]
org.eclipse.emf.ecore.xmi (2.2.1.v200609210005) "EMF XMI" [Active]
org.eclipse.emf.edit (2.2.1.v200609210005) "EMF Edit" [Resolved]
org.eclipse.emf.edit.ui (2.2.0.v200609210005) "EMF Edit UI" [Resolved]
org.eclipse.emf.exporter (2.2.0.v200609210005) "EMF Model Export
Support" [Resolved]
org.eclipse.emf.importer (2.2.1.v200609210005) "EMF Model Import
Support" [Resolved]
org.eclipse.emf.importer.ecore (2.2.0.v200609210005) "EMF Ecore
Importer" [Resolved]
org.eclipse.emf.importer.java (2.2.1.v200609210005) "EMF Annotated Java
org.eclipse.emf.importer.rose (2.2.0.v200609210005) "EMF Rose Importer"
[Resolved]
org.eclipse.emf.mapping (2.2.0.v200609210005) "EMF Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2ecore (2.2.0.v200609210005) "Ecore to
Ecore Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2ecore.editor (2.2.0.v200609210005) "Ecore
to Ecore Mapping Editor" [Resolved]
org.eclipse.emf.mapping.ecore2xml (2.2.0.v200609210005) "Ecore to XML
Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2xml.ui (2.2.0.v200609210005) "Ecore to XML
Mapping UI" [Resolved]
org.eclipse.emf.mapping.ui (2.2.1.v200609210005) "EMF Mapping UI" [Resolved]
org.eclipse.emf.mapping.xsd2ecore (2.1.0.v200609210005) "XSD to Ecore
Mapping" [Resolved]
org.eclipse.emf.mapping.xsd2ecore.editor (2.1.0.v200609210005) "XSD to
(EMF) Source" [Resolved]
org.eclipse.equinox.common (3.2.0.v20060603) "Common Eclipse Runtime"
[Active]
org.eclipse.equinox.preferences (3.2.1.R32x_v20060717) "Eclipse
Preferences Mechanism" [Active]
org.eclipse.equinox.registry (3.2.1.R32x_v20060814) "Extension Registry
Support" [Active]
org.eclipse.equinox.servlet.api (1.0.0.v20060601) "Servlet API" [Resolved]
org.eclipse.gef (3.2.1.v20060921) "Graphical Editing Framework" [Resolved]
org.eclipse.gef.doc.isv (3.2.0.v20060626) "Graphical Editing Framework
Developer Resources" [Resolved]
org.eclipse.help (3.2.1.R321_v20060920) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.100.v20060602) "Help Application Server"
[Resolved]
org.eclipse.help.base (3.2.1.R321_v20060822) "Help System Base" [Resolved]
org.eclipse.help.ui (3.2.0.v20060602) "Help System UI" [Resolved]
org.eclipse.help.webapp (3.2.1.R321_v20060803) "Help System Webapp"
[Resolved]
org.eclipse.hyades.analysis.engine (4.2.0.v200606131519) "Symptom Model"
[Resolved]
org.eclipse.hyades.execution (4.2.0.v200606131519) "TPTP Platform
Execution Plug-In" [Active]
org.eclipse.hyades.execution.correlation (4.1.100.v200606131519) "Hyades
Runtime Correlation Engine" [Resolved]
org.eclipse.hyades.execution.trace (4.1.100.v200606131519) "Hyades
Execution Trace" [Resolved]
org.eclipse.hyades.execution.win32.x86 (4.2.0.v200606131519) "TPTP
Platform Execution Plug-In" [Resolved]
org.eclipse.hyades.logging.adapter (4.2.0.v200606170100) "TPTP
Monitoring Project Generic Log Adapter" [Resolved]
org.eclipse.hyades.logging.adapter.ui (4.2.0.v200606131519) "Generic
Adapter UI" [Resolved]
org.eclipse.hyades.logging.core (4.2.0.v200606131519) "Hyades Logging
Agent, Common Base Events and Logging Facility Support" [Resolved]
org.eclipse.hyades.logging.core.sample (4.1.100.v200606131519) "Sample
for Hyades Logging Agent, Common Base Events and Logging Facility
Support" [Resolved]
org.eclipse.hyades.logging.parsers (4.2.0.v200606190100) "TPTP
Monitoring Project Log File Parsers" [Resolved]
org.eclipse.hyades.perfmon (4.2.0.v200606131519) "Perfmon StatCon
Module" [Resolved]
org.eclipse.hyades.probekit (4.2.0.v200606131519) "Hyades Probekit"
[Resolved]
org.eclipse.hyades.probekit.doc.user (4.1.100.v200606131519) "Probekit
User Documentation" [Resolved]
org.eclipse.hyades.probekit.ui (4.1.100.v200606131519) "Probe Editor"
[Resolved]
org.eclipse.hyades.resources.database (4.1.100.v200606190100) "Hyades
Core Resource Extensions" [Resolved]
org.eclipse.hyades.sdb (4.1.100.v200606140100) "Symptom Database tool"
[Resolved]
org.eclipse.hyades.statistical.ui (4.2.0.v200606131519) "Statistical UI"
[Active]
org.eclipse.hyades.test.core (4.2.0.v200606131519) "TPTP Test Core
Plug-In" [Active]
org.eclipse.hyades.test.doc.user (4.1.100.v200606131519) "Test Tools
org.eclipse.hyades.test.tools.core (4.2.0.v200606131519) "TPTP Test
Tools Core Plug-In" [Active]
org.eclipse.hyades.test.tools.ui (4.2.0.v200606131519) "TPTP Test Tools
UI Plug-In" [Resolved]
org.eclipse.hyades.test.ui (4.2.0.v200606131519) "TPTP Test UI Plug-In"
[Resolved]
org.eclipse.hyades.test.ui.extensions (4.2.0.v200606131519) "TPTP Test
UI Extension Plug-In" [Resolved]
org.eclipse.hyades.trace.sample (4.1.100.v200606131519) "Samples for the
TPTP Monitoring Tools Plugins" [Resolved]
org.eclipse.hyades.trace.ui (4.2.0.v200606131519) "Hyades Trace Core UI"
[Active]
org.eclipse.hyades.trace.views (4.1.100.v200606131519) "Hyades Trace
Views Plugin" [Resolved]
org.eclipse.hyades.ui (4.1.100.v200606131519) "Hyades UI" [Active]
org.eclipse.jdt (3.2.1.r321_v20060823) "Eclipse Java Development Tools"
[Resolved]
org.eclipse.jdt.apt.core (3.2.1.R32x_v20060822-2100) "Java Annotation
Processing Core" [Resolved]
org.eclipse.jdt.apt.ui (3.2.1.R32x_v20060822-2100) "Java Annotation
Processing UI" [Resolved]
org.eclipse.jdt.core (3.2.1.v_677_R32x) "Java Development Tools Core"
[Active]
org.eclipse.jdt.core.manipulation (1.0.1.r321_v20060721) "Java Code
Manipulation Functionality" [Resolved]
org.eclipse.jdt.debug (3.2.1.r321_v20060731) "JDI Debug Model" [Resolved]
org.eclipse.jdt.debug.ui (3.2.1.r321_v20060918) "JDI Debug UI" [Resolved]
org.eclipse.jdt.doc.isv (3.2.1.r321_v20060907) "Eclipse JDT Plug-in
Developer Guide" [Resolved]
org.eclipse.jdt.doc.user (3.2.0.v20060605-1400) "Eclipse Java
Development User Guide" [Resolved]
org.eclipse.jdt.junit (3.2.1.r321_v20060810) "Java Development Tools
JUnit support" [Resolved]
org.eclipse.jdt.junit.runtime (3.2.1.r321_v20060721) "Java Development
Tools JUnit runtime support" [Resolved]
org.eclipse.jdt.junit4.runtime (1.0.1.r321_v20060905) "Java Development
Tools JUnit4 runtime support" [Resolved]
org.eclipse.jdt.launching (3.2.1.r321_v20060731) "Java Development Tools
Launching Support" [Active]
Java Development Tools SDK" [Resolved]
org.eclipse.jdt.ui (3.2.1.r321_v20060907) "Java Development Tools UI"
[Active]
org.eclipse.jem (1.2.0.v20060530_RC2) "Java EMF Model" [Resolved]
org.eclipse.jem.beaninfo (1.2.0.v20060530_RC2) "Java EMF Model BeanInfo
(Introspection) Support" [Resolved]
org.eclipse.jem.proxy (1.2.0.v20060530_RC2) "Java EMF Model Proxy
Support" [Resolved]
org.eclipse.jem.sdk (1.2.0.v20060518_RC1) "Java EMF Model SDK" [Resolved]
Source" [Resolved]
org.eclipse.jem.ui (1.2.0.v20060518_RC1) "Java EMF Model UI" [Resolved]
org.eclipse.jem.util (1.2.0.v20060530_RC2) "Java EMF Model Utilities"
[Resolved]
org.eclipse.jem.workbench (1.2.0.v20060530_RC2) "Java EMF Model
Workbench Support" [Resolved]
org.eclipse.jface (3.2.1.M20060908-1000) "JFace" [Resolved]
org.eclipse.jface.databinding (1.0.0.I20060605-1400) "JFace Data
Binding" [Resolved]
org.eclipse.jface.text (3.2.1.r321_v20060810) "JFace Text" [Resolved]
org.eclipse.jst (1.0.1.v200605040115) "J2EE Standard Tools (JST)" [Resolved]
org.eclipse.jst.common.annotations.controller (1.1.0.v200606130315)
"Annotation Controller Plug-in" [Resolved]
org.eclipse.jst.common.annotations.core (1.1.0.v200606130315)
"Annotation Core Plug-in" [Resolved]
org.eclipse.jst.common.annotations.ui (1.1.0.v200606130315) "Annotations
org.eclipse.jst.common.frameworks (1.1.0.v200606130315) "Integration
Plug-in" [Resolved]
org.eclipse.jst.common.project.facet.core (1.1.0.v200606130315) "Project
Facet Core (Java Support)" [Resolved]
org.eclipse.jst.ejb.doc.user (1.0.201.v200605291441) "EJB docs" [Resolved]
org.eclipse.jst.ejb.ui (1.1.0.v200606130315) "WTP EJB UI Plug-in" [Resolved]
org.eclipse.jst.j2ee (1.1.0.v200606222043) "J2EE Component" [Resolved]
org.eclipse.jst.j2ee.core (1.1.0.v200606130315) "J2EE Core Component"
[Resolved]
org.eclipse.jst.j2ee.doc.user (1.0.201.v200605152316) "J2EE tools
documentation" [Resolved]
org.eclipse.jst.j2ee.ejb (1.1.0.v200606152049) "EJB component Plug-in"
[Resolved]
org.eclipse.jst.j2ee.ejb.annotation.model (1.1.0.v200606212143) "EJB
Annotation Model Plug-in" [Resolved]
org.eclipse.jst.j2ee.ejb.annotations.emitter (1.1.0.v200606130315) "EJB
Emitter Plug-in" [Resolved]
org.eclipse.jst.j2ee.ejb.annotations.ui (1.1.0.v200606212143) "EJB
Annotations Ui Plug-in" [Resolved]
org.eclipse.jst.j2ee.ejb.annotations.xdoclet (1.1.0.v200606130315)
"Xdoclet Annotations Plug-in" [Resolved]
org.eclipse.jst.j2ee.infopop (1.0.201.v200605040115) "J2EE tools
infopops" [Resolved]
org.eclipse.jst.j2ee.jca (1.1.0.v200606152049) "JCA Plug-in" [Resolved]
org.eclipse.jst.j2ee.jca.ui (1.1.0.v200606130315) "WTP JCA UI Plug-in"
[Resolved]
org.eclipse.jst.j2ee.navigator.ui (1.1.0.v200606130315) "J2EE Extensions
to Common Navigator" [Resolved]
org.eclipse.jst.j2ee.ui (1.1.0.v200606130315) "WTP J2EE UI Plug-in"
[Resolved]
org.eclipse.jst.j2ee.web (1.1.0.v200606152049) "Web Plug-in" [Resolved]
org.eclipse.jst.j2ee.webservice (1.1.0.v200606130315) "Web Service
Plug-in" [Resolved]
org.eclipse.jst.j2ee.webservice.ui (1.1.0.v200606130315) "WTP Webservice
org.eclipse.jst.j2ee.xdoclet.runtime (1.1.0.v200606130315)
"XDocletRuntime Plug-in" [Resolved]
org.eclipse.jst.jsp.core (1.1.0.v200606191945) "Structured Source JSP
Model" [Resolved]
org.eclipse.jst.jsp.ui (1.1.0.v200606191945) "SSE JSP Source Editor"
[Resolved]
org.eclipse.jst.jsp.ui.infopop (1.0.2.v200605040115) "JSP tools
org.eclipse.jst.server.core (1.0.102.v200606130315) "Java Server
Support" [Resolved]
org.eclipse.jst.server.generic.core (1.0.100.v200606130315) "Generic
Server Plugin" [Resolved]
org.eclipse.jst.server.generic.jboss (1.5.0.v200606130315) "JBoss
Generic server definitions" [Resolved]
org.eclipse.jst.server.generic.jonas (1.5.0.v200606130315) "JOnAS
Generic Server definitions" [Resolved]
org.eclipse.jst.server.generic.oc4j (1.5.0.v200606130315) "Oracle OC4J
v10.1.3 DP4 Generic Server Definition Core Plug-in" [Resolved]
org.eclipse.jst.server.generic.ui (1.0.100.v200606130315) "Generic
Server Plugin UI" [Resolved]
org.eclipse.jst.server.generic.weblogic (1.5.0.v200606130315) "Weblogic
generic server definitions" [Resolved]
org.eclipse.jst.server.installable (1.5.0.v200606130315) "Installable
servers" [Resolved]
org.eclipse.jst.server.tomcat.core (1.0.102.v200606130315) "Apache
Tomcat Support" [Resolved]
org.eclipse.jst.server.tomcat.ui (1.0.102.v200606130315) "Apache Tomcat
UI Support" [Resolved]
org.eclipse.jst.server.ui (1.0.102.v200606130315) "Java Server UI
Support" [Resolved]
org.eclipse.jst.server.ui.doc.user (1.0.1.v200605040115) "Server Tools
documentation for J2EE Standard Tools" [Resolved]
org.eclipse.jst.server.ui.infopop (1.0.2.v200605040115) "Server Tools
infopops for J2EE Standard Tools" [Resolved]
org.eclipse.jst.server.websphere.core (1.0.100.v200606130315) "WebSphere
org.eclipse.jst.servlet.ui (1.1.0.v200606130315) "WTP Servlet UI
Plug-in" [Resolved]
org.eclipse.jst.servlet.ui.infopop (1.0.201.v200606130315) "Servlet
infopop" [Resolved]
org.eclipse.jst.ws (1.0.101.v200606130315) "Web Services" [Resolved]
org.eclipse.jst.ws.axis.consumption.core (1.0.101.v200606130315) "Web
service Axis Consumption Core" [Resolved]
org.eclipse.jst.ws.axis.consumption.ui (1.0.101.v200606130315)
"Webservice Axis Consumption UI" [Resolved]
org.eclipse.jst.ws.axis.creation.ui (1.0.101.v200606130315) "Webservice
Axis Creation UI" [Resolved]
org.eclipse.jst.ws.axis.infopop (1.0.201.v200605152241) "Web services
Axis UI" [Resolved]
org.eclipse.jst.ws.axis.ui.doc.user (1.0.201.v200605111705) "Axis Web
services documentation" [Resolved]
org.eclipse.jst.ws.consumption (1.0.101.v200606131923) "Web Services
Consumption" [Resolved]
org.eclipse.jst.ws.consumption.infopop (1.0.201.v200605152241) "Web
services UI" [Resolved]
org.eclipse.jst.ws.consumption.ui (1.0.101.v200606130315) "Web Services
Consumption Graphical User Interface" [Resolved]
org.eclipse.jst.ws.consumption.ui.doc.user (1.0.201.v200605111705) "Web
service consumption documentation" [Resolved]
org.eclipse.jst.ws.creation.ejb.ui (1.0.0.v200606130315) "Web Services
Creation EJB Graphical User Interface" [Resolved]
org.eclipse.jst.ws.creation.ui (1.0.101.v200606130315) "Web Services
Creation Graphical User Interface" [Resolved]
org.eclipse.jst.ws.doc.user (1.0.201.v200605111641) "Web Services UI"
[Resolved]
org.eclipse.jst.ws.infopop (1.0.201.v200605162034) "Web services UI"
[Resolved]
org.eclipse.jst.ws.uddiregistry (1.0.100.v200606130315) "Web Services
Universal Description Discovery and Integration Registry" [Resolved]
org.eclipse.jst.ws.ui (1.0.100.v200606130315) "Web Services Graphical
org.eclipse.ltk.core.refactoring (3.2.1.r321_v20060823) "Refactoring
Core" [Resolved]
org.eclipse.ltk.ui.refactoring (3.2.1.r321_v20060726) "Refactoring UI"
[Resolved]
org.eclipse.osgi.services (3.1.100.v20060601) "OSGi Release 3 Services"
[Resolved]
org.eclipse.osgi.util (3.1.100.v20060601) "OSGi R3 Utility Classes"
[Resolved]
org.eclipse.pde (3.2.1.v20060810-0800) "Eclipse Plug-in Development
org.eclipse.pde.build (3.2.1.r321_v20060823) "Plug-in Development
Environment Build Support" [Resolved]
org.eclipse.pde.core (3.2.1.v20060915-0800) "Plug-in Development Core"
[Active]
org.eclipse.pde.doc.user (3.2.1.v20060816-0800) "Eclipse Plug-in
org.eclipse.pde.junit.runtime (3.2.0.v20060605) "PDE JUnit Plug-in Test"
[Resolved]
org.eclipse.pde.runtime (3.2.0.v20060605) "Plug-in Development
Environment Runtime" [Resolved]
Plug-in Development Environment Developer Resources" [Resolved]
org.eclipse.pde.ui (3.2.1.v20060816-0800) "Plug-in Development UI"
[Resolved]
org.eclipse.platform (3.2.0.v20060601) "Eclipse Platform" [Resolved]
org.eclipse.platform.doc.isv (3.2.1.r321_v2006030) "Eclipse Platform
Plug-in Developer Guide" [Resolved]
org.eclipse.platform.doc.user (3.2.1.R32x_v200608101155) "Eclipse
Workbench User Guide" [Resolved]
"Eclipse Platform Plug-in Developer Resources" [Resolved]
org.eclipse.platform.source.win32.win32.x86
(3.2.1.r321_v20060921-b_XVA-INSQSyMtx) "Eclipse Platform Plug-in
org.eclipse.rcp (3.2.0.v20060605) "Eclipse RCP" [Resolved]
RCP Plug-in Developer Resources" [Resolved]
org.eclipse.rcp.source.win32.win32.x86
(3.2.1.r321_v20060801-2ekW2BxmcpPUOoq) "Eclipse RCP Plug-in Developer
org.eclipse.sdk (3.2.1.r321_v20060705) "Eclipse Project SDK" [Resolved]
org.eclipse.search (3.2.1.r321_v20060726) "Search Support" [Resolved]
org.eclipse.swt (3.2.1.v3235e) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.win32.win32.x86 (3.2.1.v3235) "Standard Widget Toolkit
org.eclipse.team.core (3.2.1.M20060711) "Team Support Core" [Active]
org.eclipse.team.cvs.core (3.2.1.M200608161750) "CVS Team Provider Core"
[Resolved]
org.eclipse.team.cvs.ssh (3.2.0.I200606011710) "CVS SSH Core" [Resolved]
org.eclipse.team.cvs.ssh2 (3.2.0.I200606051140) "CVS SSH2" [Resolved]
org.eclipse.team.cvs.ui (3.2.1.M20060831) "CVS Team Provider UI" [Resolved]
org.eclipse.team.ui (3.2.1.M200608151725) "Team Support UI" [Resolved]
org.eclipse.text (3.2.0.v20060605-1400) "Text" [Resolved]
org.eclipse.tomcat (4.1.130.v20060601) "Tomcat Wrapper" [Resolved]
org.eclipse.tptp.monitoring (4.1.100.v200606131519) "TPTP Monitoring"
[Resolved]
org.eclipse.tptp.monitoring.doc.user (4.2.0.v200606131519) "TPTP
Monitoring Project Documentation" [Resolved]
org.eclipse.tptp.monitoring.examples (4.2.0.v200606131519) "User
examples for the TPTP Monitoring Tools Plugins" [Resolved]
org.eclipse.tptp.monitoring.logui (4.2.0.v200606131519) "Logui Plug-in"
[Resolved]
org.eclipse.tptp.monitoring.profile.server (4.1.100.v200606131519) "TPTP
Profile On Server Logging Utility" [Resolved]
org.eclipse.tptp.monitoring.report.birt (4.2.0.v200606131519) "BIRT
Monitor Reports for TPTP Branding Plugin" [Resolved]
org.eclipse.tptp.monitoring.report.birt.doc.user (4.2.0.v200606131519)
"Monitoring Tools Business Intelligence Reporting Tools Doc User
Plug-in" [Resolved]
org.eclipse.tptp.monitoring.report.birt.ui (4.2.0.v200606131519) "BIRT
Monitor Reports for TPTP" [Resolved]
org.eclipse.tptp.platform.agentcontroller (4.1.100.v200606170100) "TPTP
Agent Controller" [Resolved]
org.eclipse.tptp.platform.agentcontroller.doc.user (4.2.0.v200606131519)
"Agent Controller documentation" [Resolved]
org.eclipse.tptp.platform.analysis (4.1.100.v200606131519) "TPTP
Analysis" [Resolved]
org.eclipse.tptp.platform.analysis.codereview.java (4.2.0.v200606131519)
"Java Code Review Plug-in" [Resolved]
org.eclipse.tptp.platform.analysis.codereview.java.rules
(4.2.0.v200606131519) "Java Code Review Rules Plug-in" [Resolved]
org.eclipse.tptp.platform.analysis.core (4.2.0.v200606131519) "TPTP
Analysis Framework Core Plug-in" [Resolved]
org.eclipse.tptp.platform.analysis.core.ui (4.2.0.v200606131519) "Static
Analysis User Interface Plug-in" [Active]
org.eclipse.tptp.platform.analysis.core.ui.doc (4.2.0.v200606131519)
"Analysis run cofiguration online help" [Resolved]
org.eclipse.tptp.platform.analysis.engine (4.1.100.v200606131519) "TPTP
Analysis Engine" [Resolved]
org.eclipse.tptp.platform.collection.framework (4.1.100.v200606131519)
"TPTP Collection Framework" [Resolved]
org.eclipse.tptp.platform.core (4.1.100.v200606131519) "TPTP Platform"
[Resolved]
org.eclipse.tptp.platform.doc.user (4.1.100.v200606131519) "TPTP
Platform Project Documentation" [Resolved]
org.eclipse.tptp.platform.examples (4.2.0.v200606131519) "TPTP Platform
Examples" [Resolved]
org.eclipse.tptp.platform.execution (4.2.0.v200606140100) "TPTP Core
Platform (Provisional)" [Resolved]
org.eclipse.tptp.platform.log.views (4.2.0.v200606131519) "Hyades Log
UI" [Resolved]
org.eclipse.tptp.platform.lta (4.1.100.v200606131519) "TPTP Log and
Trace Analyzer" [Resolved]
org.eclipse.tptp.platform.models (4.2.0.v200606131519) "Hyades Models"
[Active]
org.eclipse.tptp.platform.probekit (4.1.100.v200606131519) "TPTP
ProbeKit" [Resolved]
org.eclipse.tptp.platform.probekit.launch (4.2.0.v200606131519)
"Probekit Launch Configuration" [Resolved]
org.eclipse.tptp.platform.profile.server (4.1.100.v200606131519) "TPTP
Profile on Server" [Resolved]
org.eclipse.tptp.platform.profile.server.core (4.1.100.v200606131519)
"TPTP Profile On Server Core" [Resolved]
org.eclipse.tptp.platform.profile.server.wst (4.1.100.v200606131519)
"TPTP Profile On Server WTP Utility" [Resolved]
org.eclipse.tptp.platform.report (4.1.100.v200606131519) "TPTP Charting
Service" [Resolved]
org.eclipse.tptp.platform.report.birt (4.2.0.v200606131519) "BIRT
Reporting for TPTP Branding plugin" [Resolved]
org.eclipse.tptp.platform.report.birt.ui (4.2.0.v200606131519) "BIRT
Reporting for TPTP" [Resolved]
org.eclipse.tptp.platform.report.core (4.1.100.v200606131519) "TPTP
Report Framework" [Resolved]
org.eclipse.tptp.platform.report.ui (4.1.100.v200606131519) "TPTP Report
UI" [Resolved]
org.eclipse.tptp.platform.samples (4.1.100.v200606131519) "TPTP Platform
Samples" [Resolved]
org.eclipse.tptp.platform.statistical.ui (4.1.100.v200606131519) "TPTP
Statistical UI" [Resolved]
org.eclipse.tptp.platform.trace (4.1.100.v200606131519) "TPTP Platform
Trace" [Resolved]
org.eclipse.tptp.test (4.1.100.v200606131519) "TPTP Test" [Resolved]
org.eclipse.tptp.test.auto (4.1.100.v200606131519) "TPTP Automated GUI
Recording and Playback" [Resolved]
org.eclipse.tptp.test.auto.gui (4.2.0.v200606131519) "TPTP Automated GUI
Test Tool" [Active]
org.eclipse.tptp.test.report.birt (4.2.0.v200606131519) "BIRT Test
org.eclipse.tptp.test.report.birt.doc.user (4.2.0.v200606131519)
"Testing Tools Business Intelligence Reporting Tools Doc User Plug-in"
[Resolved]
org.eclipse.tptp.test.report.birt.ui (4.2.0.v200606131519) "BIRT Test
org.eclipse.tptp.test.samples (4.1.100.v200606131519) "TPTP Test
Samples" [Resolved]
org.eclipse.tptp.test.tools (4.1.100.v200606131519) "TPTP Test Tools"
[Resolved]
org.eclipse.tptp.trace (4.1.100.v200606131519) "TPTP Trace" [Resolved]
org.eclipse.tptp.trace.report.birt (4.2.0.v200606131519) "BIRT Trace
org.eclipse.tptp.trace.report.birt.doc.user (4.2.0.v200606131519)
"Tracing and Profiling Tools Business Intelligence Reporting Tools Doc
User Plug-in" [Resolved]
org.eclipse.tptp.trace.report.birt.ui (4.2.0.v200606131519) "BIRT Trace
org.eclipse.ui (3.2.1.M20060913-0800) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.2.0.v20060602) "Browser Support" [Resolved]
org.eclipse.ui.cheatsheets (3.2.1.R321_v20060720) "Cheat Sheets" [Resolved]
org.eclipse.ui.console (3.1.100.v20060605) "Console" [Resolved]
org.eclipse.ui.editors (3.2.1.r321_v20060721) "Default Text Editor" [Active]
org.eclipse.ui.externaltools (3.1.101.r321_v20060802) "External Tools"
[Active]
org.eclipse.ui.forms (3.2.0.v20060602) "Eclipse Forms" [Resolved]
org.eclipse.ui.ide (3.2.1.M20060915-1030) "Eclipse IDE UI" [Active]
org.eclipse.ui.intro (3.2.1.R321_v20060810) "Welcome Framework" [Resolved]
org.eclipse.ui.intro.universal (3.2.1.R321_v20060905) "Universal
Welcome" [Resolved]
org.eclipse.ui.navigator (3.2.1.M20060913-0800) "Common Navigator View"
[Resolved]
org.eclipse.ui.navigator.resources (3.2.1.M20060906-0800b) "Navigator
Workbench Components" [Resolved]
org.eclipse.ui.presentations.r21 (3.2.0.I20060605-1400) "R21
Presentation Plug-in" [Resolved]
org.eclipse.ui.testing (3.2.0) "Eclipse Workbench Testing Plug-In"
[Resolved]
org.eclipse.ui.views (3.2.1.M20060906-0800) "Views" [Active]
org.eclipse.ui.views.properties.tabbed (3.2.1.M20060830-0800) "Tabbed
Properties View" [Resolved]
org.eclipse.ui.win32 (3.2.0.I20060605-1400) "Eclipse UI Win32
Enhancements" [Resolved]
org.eclipse.ui.workbench (3.2.1.M20060906-0800) "Workbench" [Active]
org.eclipse.ui.workbench.compatibility (3.2.0.I20060605-1400) "Workbench
Compatibility" [Resolved]
org.eclipse.ui.workbench.texteditor (3.2.0.v20060605-1400) "Text Editor
Framework" [Active]
org.eclipse.uml2 (2.0.2.v200610251409) "UML2" [Resolved]
org.eclipse.uml2.codegen.ecore (1.2.2.v200610251409) "UML2 Ecore Code
org.eclipse.uml2.codegen.ecore.ui (1.2.0.v200610251409) "UML2 Ecore Code
org.eclipse.uml2.common (1.2.2.v200610251409) "UML2 Common" [Resolved]
org.eclipse.uml2.common.edit (1.2.0.v200610251409) "UML2 Common Edit
Support" [Resolved]
org.eclipse.uml2.doc (2.0.2.v200610251409) "UML2 Documentation" [Resolved]
org.eclipse.uml2.examples (2.0.2.v200610251409) "UML2 Examples" [Resolved]
Source" [Resolved]
org.eclipse.uml2.examples.uml.ui (2.0.1.v200610251409) "UML2 UML
Examples UI" [Resolved]
org.eclipse.uml2.source (2.0.2.v200610251409) "UML2 Source" [Resolved]
org.eclipse.uml2.uml (2.0.2.v200610251409) "UML2 UML Model" [Resolved]
org.eclipse.uml2.uml.ecore.exporter (2.0.0.v200610251409) "UML2 UML
Exporter for EMF" [Resolved]
org.eclipse.uml2.uml.ecore.importer (2.0.0.v200610251409) "UML2 UML
Importer for EMF" [Resolved]
org.eclipse.uml2.uml.edit (2.0.2.v200610251409) "UML2 UML Edit Support"
[Resolved]
org.eclipse.uml2.uml.editor (2.0.1.v200610251409) "UML2 UML Editor"
[Resolved]
org.eclipse.uml2.uml.resources (2.0.2.v200610251409) "UML2 UML
org.eclipse.update.configurator (3.2.1.v20092006) "Install/Update
Configurator" [Active]
org.eclipse.update.core (3.2.1.v20092006) "Install/Update Core" [Active]
org.eclipse.update.core.win32 (3.2.1.v20092006) "Install/Update Core for
Windows" [Resolved]
org.eclipse.update.scheduler (3.2.1.v20092006) "Automatic Updates
Scheduler" [Active]
org.eclipse.update.ui (3.2.1.v20092006) "Install/Update UI" [Resolved]
org.eclipse.wst (1.0.1.v200605040144) "Web Standard Tools (WST)" [Resolved]
org.eclipse.wst.command.env (1.0.101.v200606130645) "Environment Command
Framework (headless)" [Resolved]
org.eclipse.wst.command.env.core (1.0.101.v200606130645) "Environment
Command Framework (core)" [Resolved]
org.eclipse.wst.command.env.infopop (1.0.2.v200605070230) "Web services
UI" [Resolved]
org.eclipse.wst.command.env.ui (1.0.101.v200606130645) "Environment
Command Framework (GUI)" [Resolved]
org.eclipse.wst.common.core (1.1.0.v200606130645) "WST Common Core
Plug-in" [Resolved]
org.eclipse.wst.common.emf (1.1.0.v200606130645) "EMF Utilities" [Resolved]
org.eclipse.wst.common.emfworkbench.integration (1.1.0.v200606130645)
"EMF Workbench Edit Plug-in" [Resolved]
org.eclipse.wst.common.environment (1.0.100.v200606130645) "Enviornment
Plug-in" [Resolved]
org.eclipse.wst.common.frameworks (1.1.0.v200606130645) "Common
Frameworks" [Resolved]
org.ec
Re: AGR execution hangs in standard mode [message #107291 is a reply to message #107039] |
Thu, 02 August 2007 06:23   |
Hi Martin,
Given the stability of the IAC in version 4.2.0, I would highly
recommend using the Agent Controller:
http://www.eclipse.org/tptp/home/downloads/drops/TPTP-4.2.0. html
Have a look at the 'getting started' guide:
http://www.eclipse.org/tptp/home/downloads/installguide/Agen tController42.html
Alternatively, when you are able, I would suggest to moving up to the
4.4.0 version since the IAC has been completely redesigned and is much more
stable.
Paul
"Martin Vlk" <mvlk@curamsoftware.com> wrote in message
news:f8pvj9$2t4$1@build.eclipse.org...
> Hi Paul,
> possible.
> I did read all of the thread you mention, but that was no help in my case
> unfortunately.
> Following is the configuration information from the Eclipse where the hang
> Cheers
> Martin
> win32
> -ws
> win32
> -arch
> x86
> -launcher
> -name
> Eclipse
> -showsplash
> 600
> -exitdata
> f78_78
> -vm
> -Xmx256m
> -jar
> eof=eof
> file.separator=\
> Files\Subversion\bin;C:\Program Files\Common Files\GTK\2.0\bin;C:\Program
> Files\Rational\ClearCase\bin;C:\Program Files\Maven1.0.2\bin
> line.separator=
> os.arch=x86
> os.name=Windows XP
> os.version=5.1
> osgi.arch=x86
> osgi.nl=en_IE
> osgi.os=win32
> osgi.ws=win32
> path.separator=;
> sun.cpu.isalist=
> sun.desktop=windows
> user.country=IE
> user.language=en
> user.name=MVlk
> user.variant=
> *** Features:
> Reporting Tools"
> Documentation"
> Help"
> Designer"
> Runtime"
> org.eclipse.datatools.connectivity.oda.designer.feature (0.9.0.200606161)
> "Eclipse Data Tools Platform Connectivity Open Data Access (ODA) Designer"
> org.eclipse.datatools.connectivity.oda.feature (0.9.0.200606161) "Eclipse
> org.eclipse.emf.ecore.sdo (2.2.0.v200609210005) "EMF Service Data Objects
> (SDO)"
> (EMF) Source"
> Development Tools"
> Source"
> org.eclipse.jst (1.5.0.v200606092300-kW-O_ysCRLJsxJt) "J2EE Standard Tools
> (JST)"
> Platform"
> org.eclipse.rcp.source (3.2.1.r321_v20060801-2ekW2BxmcpPUOoq) "Eclipse RCP
> SDK"
> Monitoring"
> org.eclipse.tptp.monitoring.doc.user (4.2.0.v200606121835--0842282835373A)
> "TPTP Monitoring Project Documentation"
> org.eclipse.tptp.monitoring.examples (4.2.0.v200606121835--0842282835373A)
> "User examples for the TPTP Monitoring Tools Plugins"
> Utility"
> Branding Plugin"
> "TPTP Analysis"
> org.eclipse.tptp.platform.core (4.2.0.v200606150100--Cq0bcpcppNmQn0) "TPTP
> Platform"
> Documentation"
> org.eclipse.tptp.platform.lta (4.2.0.v200606131519--1G955G5G7A7E7M) "TPTP
> "TPTP ProbeKit"
> plugin"
> org.eclipse.tptp.test.doc.user (4.2.0.v200606121835--0842282835373A) "Test
> "TPTP Test Samples"
> Test Tools"
> Trace"
> Source"
> org.eclipse.wst (1.5.0.v200606092300-U4T922yjOWsGK5Y) "Web Standard Tools
> (WST)"
> org.eclipse.xsd.doc (2.2.1.v200609210005) "XML Schema Infoset Model (XSD)
> Programmers Guide"
> (XSD) Source"
> (ICU4J)" [Active]
> com.ibm.icu.source (3.4.5) "International Components for Unicode for Java
Re: AGR execution hangs in standard mode [message #107472 is a reply to message #107444] |
Fri, 03 August 2007 07:48   |
Hi Martin,
In addition to this, you should find that the IAC will not start itself
if the full AC is already running. So, in theory, just by starting the
AC before invoking TPTP tests, you will prevent the IAC from being used.
--Joe
Martin Vlk wrote:
> Hi, just to wrap up - I have found the config file where this setting is
> stored.
> So if you need to switch off the IAC from a script, you can add a new
> line with the contents "Enable=false" into the following file:
> <your-workspace> \.metadata\.plugins\org.eclipse.core.runtime\.settings\org.e clipse.hyades.execution.prefs
> Cheers
> Martin
> Martin Vlk wrote:
>> Hi Paul, thanks for this - with the standalone AC running and IAC
>> disabled everything works fine!
>> Now I am wondering is there a way of switching off the IAC
>> programmatically or in a config file?
>> The thing is that I am running the AGR tests as part of a build
>> process and the whole Eclipse platform is installed automatically
>> prior to that without user intervention. I'd need to disable IAC from
>> an Ant script on that new Eclipse installation so that the standalone
>> AC is used instead.
Re: AGR execution hangs in standard mode [message #107639 is a reply to message #107483] |
Tue, 07 August 2007 07:32  |
Hi Martin,
It is really hard to say the cause of your IAC problem. There have been
many IAC defects fixed since 4.2.0. Since we do not have a 4.2.3 release
planned and you are bound to 4.2.0, I would think we should leave this issue
unresolved.
Paul
news:f8v762$srp$1@build.eclipse.org...
> Hi Joe, that sounds good - I'll try it out!
> I guess then the last remaining question is why the IAC works on some
> machines and doesn't on others. As in case of the other affected people in
> this newsgroup it's not a priority for me any more as I have a working
> system and other tasks to attend to, but still I'd be curious to find out.
> Just in case anyone comes across the answer.
> Cheers
> Martin
> Joe Toomey wrote:
>> Hi Martin,
Current Time: Tue Jul 22 06:38:55 EDT 2025
Powered by FUDForum. Page generated in 0.07927 seconds
