Home » Modeling » EMF » Copy On Write EList
Copy On Write EList [message #704108] Thu, 28 July 2011 05:30 Go to next message
Hi all,
I need to add concurrency protection to the EList. I know I should be using the transactional model but it is not possible to do so in this project. The threads are running within the model objects itself.
Therefore, I would like to give it a go to implement a CopyOnWriteBasicEList. This should not be too complicated. Now, knowing which subclasses of BasicEList i also need to implement as CopyOnWrite versions and what to take into account on the JET templates to instanteate the right List implementation, that's where it starts getting tricky, at least for me.
So, any guidelines or advise on this will be wellcome!
Cheers
Javi
Re: Copy On Write EList [message #704317 is a reply to message #704108] Thu, 28 July 2011 09:43 Go to previous messageGo to next message
Javi,
Comments below.
On 28/07/2011 2:30 AM, Xavipen wrote:
> Hi all,
It's generally very hard (impossible is probably the better word) to
achieve proper concurrency protection at a fine grained level without a
high level policy about how threads coordinate reads and writes of a model.
And what about single valued features? Of course the list that
implement a multi-valued feature are intimately tied to the object that
owns them, so I don't see the real possibility for this to be supported.
I think you'll find it is.
So you do want to copy a multi-valued feature's list...
It's just not going to work. The original uncopied owning object will
refer to which version of the list? The uncopied one? Who will ever
see the copied version given that no object refers to it?
You're better off looking into CDO.
> Cheers
> Javi
Re: Copy On Write EList [message #704393 is a reply to message #704317] Thu, 28 July 2011 11:14 Go to previous messageGo to next message
Comments below.
> Hi all,
In this case the model also reflects beheiviour. I am modelling a protocol chain where the beheiviour will change according to how the model is configured. Each main block (Which is also an EObject) will have its own thread.
I'm very aware this is a debiation of the objectives of EMF Model. However by modifiing the templates i can generate the concurrency for EAttributes and EReferneces when they are a single reference. (EReferencse actual object contain is then protected for a high level concurrency policy base in Actors)
However i have not found it for EList.
I'm sorry. I am not sure what do you mean with single valued features
I was going to take and look the implementation of java.util.concurrent.CopyOnWriteArrayList<E> from Java. AS this should be enough
protection for what i needed. Quoting Java doc: That implementation may be more efficient than alternatives when traversal operations vastly outnumber mutations, and is useful when you cannot or don't want to synchronize traversals, yet need to preclude interference among concurrent threads.
Again, not sure what do you mean by: So you do want to copy a multi-valued feature's list...
I have to look the exact implementation of the CopyonWrite, but basically what it will do is create a new array when a write operation is done. The iterators already created will be referencing the old array. The new ones will refer to the new array.
Read operations will synchronize getting the reference to the array containing the data. But all this is how the array is internally handle. Externally to EMF should be no difference. Shouldn't it?
> Cheers
> Javi
Re: Copy On Write EList [message #704397 is a reply to message #704393] Thu, 28 July 2011 11:21 Go to previous messageGo to next message
Well why don't you simply return a wrapper list which also has this high
level thread protection?
Tom
Am 28.07.11 17:14, schrieb Xavipen:
> Quote:
>> Comments below.
>> > Hi all,
>> be > using the transactional model but it is not possible to do so in
>> this > project. The threads are running within the model objects itself.
>> a high level policy about how threads coordinate reads and writes of a
>> model.
> Quote:
>> > Therefore, I would like to give it a go to implement a >
>> CopyOnWriteBasicEList. And what about single valued features? Of
>> course the list that implement a multi-valued feature are intimately
>> tied to the object that owns them, so I don't see the real possibility
> Quote:
>> > This should not be too complicated. I think you'll find it is.
> be enough protection for what i needed. Quoting Java doc: That
> Quote:
>> > as CopyOnWrite versions and what to take into account on the JET >
>> templates to instanteate the right List implementation, that's where >
>> will refer to which version of the list? The uncopied one? Who will
>> ever see the copied version given that no object refers to it?
> Quote:
>> > Cheers
>> > Javi
Re: Copy On Write EList [message #704412 is a reply to message #704393] Thu, 28 July 2011 11:39 Go to previous messageGo to next message
Comments below.
On 28/07/2011 8:14 AM, Xavipen wrote:
> Quote:
>> Comments below.
>> > Hi all,
>> a model.
This makes it sound like there isn't multi-threaded access to these but
rather each thread accesses a different thing...
I have no idea what those modifications would do... You're just talking
about adding synchronize?
> Quote:
You just said above "single reference"; that's what I mean.
> Quote:
It's a bit similar to what we do with BasicNotifierImpl.EAdapterList but
here the guy iterating over the list is basically given the array itself
and then that array will never be changed again.
> Quote:
>> implement > as CopyOnWrite versions and what to take into account on
>> the JET > templates to instanteate the right List implementation,
>> that's where > it starts getting tricky, at least for me.
You're talking about modify on write for lists and above you said "I've
not found it for EList; that's what I mean.
You're aware that copying JDK implementation details is a copyright/IP
issue?
It's impossible for me to understand if your application will behave
consistently if your readers don't see the full state of the model
that's changing underneath. Most applications will not work well under
such circumstances because they'll do something at the end of all that
reading that might well not be meaningful if the model isn't really in
the expected state anymore. Anything that was read might have been
removed and there might be all kinds of objects present that weren't
considered...
> Quote:
>> > Cheers
>> > Javi
Re: Copy On Write EList [message #704523 is a reply to message #704412] Thu, 28 July 2011 14:39 Go to previous messageGo to next message
Hi Ed,
I see the room for undesire/dangerous side effects and the need for a synchronization at a higher level, however for certain cases like list of specific listeners, this would be more than enough. For those cases. Yes, AdapterEList is along the lines of what i had in mind, but with a slight modification as follows: When add, remove, set or similar operations are called. A new array is created allways. (this bit of code of creating the new array will be synchronize with a lock).
Operations like get, indexOf, lastIndexOf, contains, etc... will no longer access data[] directly as they currently do, but in the first line of the method(or where appropiated) they will call data() (this method is already there) The method dta() will be also synchronize with a lock and return then the data[] as it is at that point in time.
If i have follow the hierarchy right this means that ECoreEList, EObjectEList EContainmendObjectEList.. will also need to take out their references to data[]. For now on when traversing the list fist it will be necesary to get a reference to the data[] via data().
Then JET templates should declared the new version of the EObjectList or EContainmentList when having a EReference to Many ( or a multi-valued feature List, is this the right thing to call it?)
Again, thanks for your comments and looking forward the next ones Smile
Javi
Re: Copy On Write EList [message #704530 is a reply to message #704397] Thu, 28 July 2011 14:56 Go to previous messageGo to next message
Tom
Hi Tom,
This is kind of what i was doing up to now. I will define on the interface the methods i needed to access the EList and then I model the class implementing the interface which would have a EList modelled and then i implement this thread protection myself and i was trying to simplify this somehow.
But now that i read your post for a second time, did you mean something like:
MyThreadProtectedElist implement EList{
public MyThreadProtectedEList ( EList list, Lock highlevellock){
internalList = list;
internalLock = lock;
// implement the synchronized calls to the internal list...
Humm, I did not though of that but I guess that could be a good alternative, unless I am missing something.
Javi
Re: Copy On Write EList [message #705220 is a reply to message #704523] Fri, 29 July 2011 10:59 Go to previous messageGo to next message
Javi,
Comments below.
On 28/07/2011 11:39 AM, Xavipen wrote:
> Hi Ed,
I see.
Of course as soon as you do locking, you can have dead lock...
I expect you'd be far better to look into using DelegatingEcoreEList:
multi-valued features should return something that implements
InternalEList and EStructuralFeature.Setting. This way you can
implement your specialized type of list once, rather than repeat the
logic for all the different types of Ecore lists...
> Again, thanks for your comments and looking forward the next ones :)
> Javi
Re: Copy On Write EList [message #1071980 is a reply to message #705220] Sun, 21 July 2013 15:54 Go to previous messageGo to next message
Hi! I know it has been a long time, but i would like to leave here my expirience on creating a threadSafe Model.
First, no proxy are use in this model. So there may be other side effects for that.
The first for the Elist was to modifiy the templates to create wrappers for the Elist and return the wrappers instead of the Elist. This solution was suggested here, and it works, with the side effect of deadlocks (but when dealing with multithreading is already a posibility). Unfortunatelly i did not have the time and i did not have to time to improve this solution by looking into DelegatingEcoreEList (project time constrains as usual) and i would not know were to start ( Some remarks would be aprreceated in case i have the time to revisit this).
The template generation also add thread safe by either using locks or Actors. This code and the EList wrappers are activated by an annotation in the model.
The next issue was the Adapters List in the EObject, for this I replace the implementation of the EAdapterList with my implementation (included at the end of the post, no guaratees but it is what we used with EMF 2.7.0).
Then some problems appear in the Edit Framework with the notifiers, so the solution was to replace the ChangeNotifier Implementation by a ConcurrentChangeNotifier and a ConcurrentComposedAdapterFactory with use a CopyOnWriteArraList to store the listeners.
public class SynchronizedCopyOnWriteAdapterEList<E extends Object & Adapter> extends SynchronizedCopyOnWriteEList<E> implements EObservableAdapterList{
	private static final long serialVersionUID = -3748233483677878593L;
	protected Notifier notifier;
	protected CopyOnWriteArrayList<Listener> listeners;
	public SynchronizedCopyOnWriteAdapterEList(Notifier notifier)
		this.notifier = notifier;
	protected boolean canContainNull()
		return false;
	protected boolean useEquals()
		return false;
	protected Object [] newData(int capacity)
		return new Adapter [capacity];
	protected void didAdd(int index, E newObject)
		if (listeners != null)
			for (Listener listener : listeners)
				listener.added(notifier, newObject);
		newObject.setTarget(notifier);
	protected void didRemove(int index, E oldObject)
				listener.removed(notifier, oldObject);
		E adapter = oldObject;
		if (notifier.eDeliver())
			Notification notification =
					new NotificationImpl(Notification.REMOVING_ADAPTER, oldObject, null, index)
				public Object getNotifier()
					return notifier;
			adapter.notifyChanged(notification);
		if (adapter instanceof Adapter.Internal)
			((Adapter.Internal)adapter).unsetTarget(notifier);
		else if (adapter.getTarget() == notifier)
			adapter.setTarget(null);
	public void addListener(Listener listener)
		listeners.add(listener);
	public void removeListener(Listener listener)
		listeners.remove(listener);
ublic class SynchronizedCopyOnWriteEList<E> extends BasicEList<E>{
	private static final long serialVersionUID = 5770072918610284023L;
	final protected ReentrantLock notificationLock = new ReentrantLock();
	volatile protected CopyOnWriteArrayList<Object> data = new CopyOnWriteArrayList<Object>();
	 * Creates an empty instance with no initial capacity.
	 * The data storage will be null.
	public SynchronizedCopyOnWriteEList()
		super();
	 * Creates an empty instance with the given capacity.
	 * @param initialCapacity the initial capacity of the list before it must grow.
	 * @exception IllegalArgumentException if the <code>initialCapacity</code> is negative.
	public SynchronizedCopyOnWriteEList(int initialCapacity)
		if (initialCapacity < 0)
			throw new IllegalArgumentException("Illegal Capacity: " + initialCapacity);
		//	    data = newData(initialCapacity);
	 * Creates an instance that is a copy of the collection.
	 * @param collection the initial contents of the list.
	public SynchronizedCopyOnWriteEList(Collection<? extends E> collection)
		data.addAll(collection);
	 * Creates an initialized instance that directly uses the given arguments.
	 * @param size the size of the list.
	 * @param data the underlying storage of the list.
	protected SynchronizedCopyOnWriteEList(int size, Object [] data)
		this.data.addAll(Arrays.asList(data));
	 * Returns new allocated data storage.
	 * Clients may override this to create typed storage.
	 * The cost of type checking via a typed array is negligible.
	 * @return new data storage.
		return new Object [capacity];
	 * Assigns the object into the data storage at the given index and returns the object that's been stored.
	 * Clients can monitor access to the storage via this method.
	 * @param index the position of the new content.
	 * @param object the new content.
	 * @return the object that's been stored.
	protected E assign(int index, E object)
		data.set(index, object);
		return object;
	 * Returns the number of objects in the list.
	 * @return the number of objects in the list.
	public int size()
		return data.size();
	 * Returns whether the list has zero size.
	 * @return whether the list has zero size.
	public boolean isEmpty()
		return data.isEmpty();
	 * Returns whether the list contains the object.
	 * This implementation uses either <code>equals</code> or <code>"=="</code> depending on {@link #useEquals useEquals}.
	 * @param object the object in question.
	 * @return whether the list contains the object.
	 * @see #useEquals
	public boolean contains(Object object)
		if (useEquals() && object != null)
			return data.contains(object);
		else
			for (Object element : data) if (element == object) return true;
		return false;
	 * Returns the position of the first occurrence of the object in the list.
	 * @return the position of the first occurrence of the object in the list.
	public int indexOf(Object object)
			return data.indexOf(object);
		else
			int index = 0;
			for (Object element : data){
				if (element == object) return index;
				index++;
		return -1;
	 * Returns the position of the last occurrence of the object in the list.
	 * @return the position of the last occurrence of the object in the list.
	public int lastIndexOf(Object object)
		return data.lastIndexOf(object);
	 * Returns an array containing all the objects in sequence.
	 * Clients may override {@link #newData newData} to create typed storage in this case.
	 * @return an array containing all the objects in sequence.
	 * @see #newData
	public Object[] toArray()
		return data.toArray();
	 * @param array the array that will be filled and returned, if it's big enough;
	 * otherwise, a suitably large array of the same type will be allocated and used instead.
	 * @see #newData
	public <T> T[] toArray(T[] array)
		return data.toArray(array);
	 * Returns direct <b>unsafe</b> access to the underlying data storage.
	 * Clients may <b>not</b> modify this
	 * and may <b>not</b> assume that the array remains valid as the list is modified.
	 * @return direct <b>unsafe</b> access to the underlying data storage.
	public Object [] data()
	 * Updates directly and <b>unsafely</b> the underlying data storage.
	 * Clients <b>must</b> be aware that this subverts all callbacks
	 * and hence possibly the integrity of the list.
	public void setData(int size, Object [] data)
		CopyOnWriteArrayList<Object> newList = new CopyOnWriteArrayList<Object>();
		newList.addAll(Arrays.asList(data));
		CopyOnWriteArrayList<Object> oldList = this.data;
		this.data = newList;
		oldList.clear();
		oldList = null;
	 * An IndexOutOfBoundsException that constructs a message from the argument data.
	 * Having this avoids having the byte code that computes the message repeated/inlined at the creation site.
	protected static class BasicIndexOutOfBoundsException extends AbstractEList.BasicIndexOutOfBoundsException
		private static final long serialVersionUID = 1L;
		 * Constructs an instance with a message based on the arguments.
		public BasicIndexOutOfBoundsException(int index, int size)
			super(index, size);
	 * Returns the object at the index.
	 * This implementation delegates to {@link #resolve resolve}
	 * so that clients may transform the fetched object.
	 * @param index the position in question.
	 * @return the object at the index.
	 * @exception IndexOutOfBoundsException if the index isn't within the size range.
	 * @see #resolve
	 * @see #basicGet
	@SuppressWarnings("unchecked")
	public E get(int index)
		if (index >= size)
			throw new BasicIndexOutOfBoundsException(index, size);
		return resolve(index, (E)data.get(index));
	 * Returns the object at the index without {@link #resolve resolving} it.
	 * @see #resolve
	 * @see #get
	public E basicGet(int index)
		if (index >= size)
		return primitiveGet(index);
	 * Returns the object at the index without {@link #resolve resolving} it and without range checking the index.
	 * @see #resolve
	 * @see #get
	 * @see #basicGet(int)
	protected E primitiveGet(int index)
		return (E)data.get(index);
	 * Sets the object at the index
	 * and returns the old object at the index;
	 * it does no ranging checking or uniqueness checking.
	 * This implementation delegates to {@link #assign assign}, {@link #didSet didSet}, and {@link #didChange didChange}.
	 * @param object the object to set.
	 * @return the old object at the index.
	 * @see #set
	public E setUnique(int index, E object)
		notificationLock.lock();
		try{
			@SuppressWarnings("unchecked") E oldObject = (E)data.get(index);
			assign(index, validate(index, object));
			didSet(index, object, oldObject);
			didChange();
			return oldObject;
		}finally{
			notificationLock.unlock();
	 * Adds the object at the end of the list;
	 * it does no uniqueness checking.
	 * This implementation delegates to {@link #assign assign}, {@link #didAdd didAdd}, and {@link #didChange didChange}.
	 * after uniqueness checking.
	 * @param object the object to be added.
	 * @see #add(Object)
	public void addUnique(E object)
		try{
			int newIndex = data.size();
			data.add(validate(newIndex, object));
			didAdd(newIndex, object);
			didChange();
		}finally{
	 * Adds the object at the given index in the list;
	 * @see #add(int, Object)
	public void addUnique(int index, E object)
		try{
			data.add(index, validate(data.size(), object));
			didAdd(index, object);
			didChange();
		}finally{
	 * Adds each object of the collection to the end of the list;
	 * @param collection the collection of objects to be added.
	 * @see #addAll(Collection)
	public boolean addAllUnique(Collection<? extends E> collection)
		for ( E object: collection)
			addUnique(object);
		return collection.size() != 0;
	 * Adds each object of the collection at each successive index in the list
	 * and returns whether any objects were added;
	 * @param index the index at which to add.
	 * @return whether any objects were added.
	 * @see #addAll(int, Collection)
	public boolean addAllUnique(int index, Collection<? extends E> collection)
		int insertIndex = index;
			addUnique(insertIndex, object);
			insertIndex++;
	 * Adds each object from start to end of the array at the index of list
	 * @param objects the objects to be added.
	 * @param start the index of first object to be added.
	 * @param end the index past the last object to be added.
	 * @see #addAllUnique(Object[], int, int)
	public boolean addAllUnique(Object [] objects, int start, int end)
		for (int i = start; i < end; ++i)
			@SuppressWarnings("unchecked") E object = (E)objects[i];
			addUnique(object);
		return (end - start) != 0;
	 * Adds each object from start to end of the array at each successive index in the list
	public boolean addAllUnique(int index, Object [] objects, int start, int end)
			insertIndex++;
	 * Removes the object at the index from the list and returns it.
	 * This implementation delegates to {@link #didRemove didRemove} and {@link #didChange didChange}.
	 * @param index the position of the object to remove.
	 * @return the removed object.
	public E remove(int index)
		try{
			@SuppressWarnings("unchecked") E oldObject = (E) data.remove(index);
			didRemove(index, oldObject);
			didChange();
			return oldObject;
		}finally{
	 * Clears the list of all objects.
	 * This implementation discards the data storage without modifying it
	 * and delegates to {@link #didClear didClear} and {@link #didChange didChange}.
	public void clear()
		try{
			Object [] oldData = data.toArray();
			int oldSize = oldData.length;
			data.clear();
			didClear(oldSize, oldData);
			didChange();
		}finally{
	 * Moves the object at the source index of the list to the target index of the list
	 * and returns the moved object.
	 * This implementation delegates to {@link #assign assign}, {@link #didMove didMove}, and {@link #didChange didChange}.
	 * @param targetIndex the new position for the object in the list.
	 * @param sourceIndex the old position of the object in the list.
	 * @return the moved object.
	 * @exception IndexOutOfBoundsException if either index isn't within the size range.
	public E move(int targetIndex, int sourceIndex)
		try{
			@SuppressWarnings("unchecked") E object = (E)data.remove(sourceIndex);
			data.add(targetIndex, object);
			didMove(targetIndex, object, sourceIndex);
			didChange();
			return object;
		}finally{
	 * Shrinks the capacity of the list to the minimal requirements.
	 * @see #grow
	public void shrink()
		// this is done by the arrayList.
	 * Grows the capacity of the list
	 * to ensure that no additional growth is needed until the size exceeds the specified minimum capacity.
	 * @see #shrink
	public void grow(int minimumCapacity)
	private synchronized void writeObject(ObjectOutputStream objectOutputStream) throws IOException
		objectOutputStream.defaultWriteObject();
		if (data.isEmpty())
			objectOutputStream.writeInt(0);
		else
			Object [] snapshotData = data.toArray();
			objectOutputStream.writeInt(snapshotData.length);
			for (int i = 0; i < snapshotData.length; ++i)
				objectOutputStream.writeObject(snapshotData[i]);
	private synchronized void readObject(ObjectInputStream objectInputStream) throws IOException, ClassNotFoundException
		data.clear();
		objectInputStream.defaultReadObject();
		int arrayLength = objectInputStream.readInt();
		if (arrayLength > 0)
			for (int i = 0; i < arrayLength; ++i)
				try{
					@SuppressWarnings("unchecked") E object = (E)objectInputStream.readObject();
					data.add(validate(i, object));
					didAdd(i, object);
				}finally{
	 * Returns a shallow copy of this list.
	 * @return a shallow copy of this list.
	public Object clone()
		SynchronizedCopyOnWriteEList<E> clone = new SynchronizedCopyOnWriteEList<E>();
		clone.data.addAll(this.data);
		return clone;
	 * An extensible iterator implementation.
	 * @deprecated
	 * @see AbstractEList.EIterator
	@Deprecated
	protected class EIterator<E1> extends AbstractEList<E>.EIterator<E1>
		// Pointless extension
	 * An extended read-only iterator that does not {@link BasicEList#resolve resolve} objects.
	 * @deprecated
	 * @see AbstractEList.NonResolvingEIterator
	@Deprecated
	protected class NonResolvingEIterator<E1> extends AbstractEList<E>.NonResolvingEIterator<E1>
	 * An extensible list iterator implementation.
	 * @deprecated
	 * @see AbstractEList.EListIterator
	@Deprecated
	protected class EListIterator<E1> extends AbstractEList<E>.EListIterator<E1>
		 * Creates an instance.
		public EListIterator()
			super();
		 * Creates an instance advanced to the index.
		 * @param index the starting index.
		public EListIterator(int index)
			super(index);
			cursor = index;
	 * An extended read-only list iterator that does not {@link BasicEList#resolve resolve} objects.
	 * @deprecated
	 * @see AbstractEList.NonResolvingEListIterator
	@Deprecated
	protected class NonResolvingEListIterator<E1> extends AbstractEList<E>.NonResolvingEListIterator<E1>
		public NonResolvingEListIterator()
			super();
		public NonResolvingEListIterator(int index)
			super(index);
	 * An unmodifiable version of {@link BasicEList}.
	public static class UnmodifiableEList<E> extends SynchronizedCopyOnWriteEList<E>
		 * Creates an initialized instance.
		public UnmodifiableEList(Object [] data)
		 * Throws an exception.
		 * @exception UnsupportedOperationException always because it's not supported.
		public E set(int index, E object)
			throw new UnsupportedOperationException();
		public boolean add(E object)
		public void add(int index, E object)
		public boolean addAll(Collection<? extends E> collection)
		public boolean addAll(int index, Collection<? extends E> collection)
		public boolean remove(Object object)
		public boolean removeAll(Collection<?> collection)
		public boolean retainAll(Collection<?> collection)
		public void clear()
		public void move(int index, E object)
		 * Returns the {@link BasicEList#basicIterator basic iterator}.
		 * @return the basic iterator.
		public Iterator<E> iterator()
			return basicIterator();
		 * Returns the {@link #basicListIterator() basic list iterator}.
		 * @return the basic list iterator.
		public ListIterator<E> listIterator()
			return basicListIterator();
		 * Returns the {@link #basicListIterator(int) basic list iterator} advanced to the index.
		public ListIterator<E> listIterator(int index)
			return basicListIterator(index);
	 * Returns an <b>unsafe</b> list that provides a {@link #resolve non-resolving} view of the underlying data storage.
	 * @return an <b>unsafe</b> list that provides a non-resolving view of the underlying data storage.
	protected List<E> basicList()
		if (size == 0)
			return ECollections.emptyEList();
		else
			return new SynchronizedCopyOnWriteEList.UnmodifiableEList<E>(data.toArray());
	 * A <code>BasicEList</code> that {@link #useEquals uses} <code>==</code> instead of <code>equals</code> to compare members.
	public static class FastCompare<E> extends BasicEList<E>
		public FastCompare()
			super();
		public FastCompare(int initialCapacity)
			super(initialCapacity);
		public FastCompare(Collection<? extends E> collection)
			super(collection.size());
			addAll(collection);
		 * Returns <code>false</code> because this list uses <code>==</code>.
		 * @return <code>false</code>.
			return false;
	   * Returns an iterator.
	   * This implementation allocates a {@link AbstractEList.EIterator}.
	   * @return an iterator.
	    return new SynchronizedCopyOnWriteEIterator();
	  protected class SynchronizedCopyOnWriteEIterator implements Iterator<E>
		  int index = -1;
		 Iterator<Object> internalIterator = data.iterator();
		public boolean hasNext() {
			return internalIterator.hasNext();
		public E next() {
			index++;
			E object = (E)internalIterator.next();
			return resolve(index, object);
		public void remove() {
			internalIterator.remove();
	   * Returns a read-only iterator that does not {@link #resolve resolve} objects.
	   * This implementation allocates a {@link NonResolvingEIterator}.
	   * @return a read-only iterator that does not resolve objects.
	  protected Iterator<E> basicIterator()
	    return new NonResolvingSynchronizedCopyOnWriteEIterator();
	   * An extended read-only iterator that does not {@link AbstractEList#resolve resolve} objects.
	  protected class NonResolvingSynchronizedCopyOnWriteEIterator extends SynchronizedCopyOnWriteEIterator
		  public E next() {
			  index++;
			  return (E)internalIterator.next();
		   * Throws and exception.
Re: Copy On Write EList [message #1072162 is a reply to message #1071980] Mon, 22 July 2013 03:56 Go to previous messageGo to next message
Xavipen,
Comments below.
> effects for that.
> this).
In general, it seems to me not possible to make a multi-threaded
application well behaved simply by making primitives thread safe. E.g.,
two threads operating on the opposite ends of a bidirectional reference
will tend to deadlock. Do the wrappers implement InternalEList and
EStructuralFeature.Setting?
Two threads both doing an addAll at some index will not generally
produce atomic results because none of the addAll methods lock over the
whole operation.
> with EMF 2.7.0).
This is an example of what I mean. Often an adapter factory will check
if an adapter is already present and then add it if not. Even if the
list is thread safe, the adapter can end up being added twice...
> Cheers,
> @Override
> return false;
> @Override
> return false;
> @Override
> @Override
> @Override
> Notification notification = new
> @Override
> return notifier;
> else if (adapter.getTarget() == notifier) {
> ReentrantLock(); volatile protected CopyOnWriteArrayList<Object>
> public SynchronizedCopyOnWriteEList() {
> super();
> it must grow.
> public SynchronizedCopyOnWriteEList(int initialCapacity) {
> initialCapacity); }
> // data = newData(initialCapacity); }
> collection) {
> data.addAll(collection); }
> arguments.
> this.data.addAll(Arrays.asList(data)); }
> return object;
> @Override
> public int size() {
> return data.size();
> @Override
> public boolean isEmpty() {
> * @see #useEquals
> @Override
> public boolean contains(Object object) {
> else
> true;
> return false;
> the list.
> the list.
> @Override
> public int indexOf(Object object) {
> else
> int index = 0;
> index++;
> return -1;
> the list.
> the list.
> @Override
> public int lastIndexOf(Object object) {
> * @see #newData
> @Override
> public Object[] toArray() {
> it's big enough;
> * @see #newData
> @Override
> public <T> T[] toArray(T[] array) {
> storage.
> * Clients may <b>not</b> modify this * and may <b>not</b>
> storage.
> * and hence possibly the integrity of the list. */
> oldList.clear();
> oldList = null;
> argument data.
> super(index, size);
> the size range.
> * @see #resolve
> * @see #basicGet
> @Override
> public E get(int index) {
> if (index >= size)
> resolving} it.
> the size range.
> * @see #resolve
> * @see #get
> @Override
> if (index >= size)
> * @see #resolve
> * @see #get
> @Override
> * Sets the object at the index * and returns the old object
> at the index;
> * @see #set
> @Override
> try{
> (E)data.get(index);
> didChange();
> return oldObject;
> }finally{
> * @see #add(Object)
> @Override
> public void addUnique(E object) {
> try{
> didChange();
> }finally{
> @Override
> public void addUnique(int index, E object) {
> try{
> didChange();
> }finally{
> @Override
> public boolean addAllUnique(Collection<? extends E> collection) {
> addUnique(object);
> the list * and returns whether any objects were added;
> @Override
> collection) {
> insertIndex++;
> @Override
> addUnique(object);
> successive index in the list * and returns whether any objects
> were added;
> @Override
> start, int end) {
> insertIndex++;
> the size range.
> @Override
> public E remove(int index) {
> try{
> data.remove(index);
> didChange();
> return oldObject;
> }finally{
> @Override
> public void clear() {
> try{
> data.clear();
> didChange();
> }finally{
> index of the list
> @Override
> try{
> didChange();
> return object;
> }finally{
> * @see #grow
> public void shrink() {
> * Grows the capacity of the list * to ensure that no
> minimum capacity.
> * @see #shrink
> public void grow(int minimumCapacity) {
> if (data.isEmpty())
> else
> data.clear();
> try{
> didAdd(i, object);
> }finally{
> @Override
> public Object clone() {
> return clone;
> * @deprecated * @see AbstractEList.EIterator
> @Deprecated
> * @deprecated
> @Deprecated
> * @deprecated
> @Deprecated
> public EListIterator() {
> super();
> public EListIterator(int index) {
> super(index);
> cursor = index;
> * @deprecated
> @Deprecated
> super();
> public NonResolvingEListIterator(int index) {
> super(index);
> public UnmodifiableEList(Object [] data) {
> it's not supported.
> @Override
> public E set(int index, E object) {
> it's not supported.
> @Override
> public boolean add(E object) {
> it's not supported.
> @Override
> public void add(int index, E object) {
> it's not supported.
> @Override
> it's not supported.
> @Override
> collection) {
> it's not supported.
> @Override
> public boolean remove(Object object) {
> it's not supported.
> @Override
> it's not supported.
> @Override
> public boolean removeAll(Collection<?> collection) {
> it's not supported.
> @Override
> public boolean retainAll(Collection<?> collection) {
> it's not supported.
> @Override
> it's not supported.
> @Override
> public void move(int index, E object) {
> it's not supported.
> @Override
> it's not supported.
> @Override
> it's not supported.
> @Override
> @Override
> public Iterator<E> iterator() {
> @Override
> public ListIterator<E> listIterator() {
> @Override
> public ListIterator<E> listIterator(int index) {
> @Override
> if (size == 0)
> else
> return new
> super();
> addAll(collection);
> <code>==</code>.
> @Override
> return false;
> @Override
> Iterator<E>
> int index = -1;
> @Override
> @Override
> public E next() {
> index++;
> @Override
> resolve} objects.
> @Override
> public E next() {
> index++;
> it's not supported.
> @Override
Re: Copy On Write EList [message #1072234 is a reply to message #1072162] Mon, 22 July 2013 07:04 Go to previous messageGo to next message
Ed Merks wrote on Mon, 22 July 2013 09:56
Xavipen,
Comments below.
> effects for that.
> this).
The Wrappers contain a reference to the internal EList implementation and a reference to the synchronization mechnism used. All calls in the wrapper are pass through the synchronization mechnism (it is different the way it is done between Locks and Actors) We have not defined bidirectional references, so i would have to have a look, but any reflective method needed could be overwritten in the template of code generation to ensure it is also called through the synchornization mechnism. In the case of Actors if the function does not return a value the call is asynchronous and no lock can happend.
For iterators on the Elist that is a bit more unclear how to deal with them. The Elist should be only handle with in the clas containing it. Only the GUI may want to iteract with the EList in such a manner. At the moment and till a time for a better implementation comes. The GUI (Parts) will do a copy of the EList and work with it and listen for the changes, so we avoid do iterations over the Elist. At least till i have time to understand better the EMF databinding and the Edit Framework.
whole operation.
I do not understand what you exactely mean with the addAll not being atomic.
I believe with the wrappers it will as the whole call to addAll is wrapped.
However i would like to have a bit more information in a clean way of delegating and implementation of an EList, in case i have time of working in an implementation.
> with EMF 2.7.0).
I have just started to look at the Edit Framework, so i am in a better position now to understand the issue you mention now.
It seems to me that there is an easy solution for this particular issue. Ensure Uniqueness in the Adapter list will solved having an adapter twice. Thanks for pointing this out. I will add that to the implementation as soon as i can.
> Cheers,
Re: Copy On Write EList [message #1072246 is a reply to message #1072234] Mon, 22 July 2013 07:27 Go to previous messageGo to next message
Xavipen,
Comments below.
>> Xavipen,
>> Comments below.
>> my > expirience on creating a threadSafe Model.
>> > First, no proxy are use in this model. So there may be other side >
>> effects for that.
>> > The first for the Elist was to modifiy the templates to create >
>> effect > of deadlocks (but when dealing with multithreading is
>> already a > posibility). Unfortunatelly i did not have the time and i
>> did not have > to time to improve this solution by looking into
>> DelegatingEcoreEList > (project time constrains as usual) and i would
>> not know were to start > ( Some remarks would be aprreceated in case
>> i have the time to revisit > this).
>> E.g., two threads operating on the opposite ends of a bidirectional
>> reference will tend to deadlock. Do the wrappers implement
>> InternalEList and EStructuralFeature.Setting?
The point is the EList returned for a multi-valued feature is assumed to
implement InternalEList and EStructuralFeature.Setting, so I imagined
that wrappers would need to implement those interfaces too, not just EList.
> Framework.
Of course it's very common to iterate over lists throughout the
framework and that's pretty much impossible to make thread safe without
a look being held during the entire processing done with the iterator...
> Quote:
>> the whole operation.
> atomic.
> wrapped.
I don't see any locking in this method:
addUnique(object);
As I mentioned already, I don't think it's possible to achieve proper
threaded application behavior just by making "primitives" thread safe.
For example, the following code isn't thread safe even if the list
itself is thread safe.
int index = list.indexOf(o);
if (index != -1)
list.remove(index);
That's because anything could modify the list between when indexOf is
called and when remove is called.
> Quote:
>> or > Actors. This code and the EList wrappers are activated by an >
>> > The next issue was the Adapters List in the EObject, for this I >
>> used > with EMF 2.7.0).
>> check if an adapter is already present and then add it if not. Even
>> if the list is thread safe, the adapter can end up being added twice...
In each case, it again boils down to making something behave atomically,
but as in the example I show above, some higher level logic will
nevertheless make assumptions about consistency between when the model
is read and when it's modified base on the information determined while
reading the model. In each case, the locking behavior needs to be moved
up the encompass of the higher level logic, e.g., hold a lock during the
entire lifetime of an iterator.
As such, it generally boils down to the application having a high level
locking/threading policy and when that is present, the fine grained
locks on the "primitives" serve no purpose other than to interfere by
giving rise to deadlocks.
> Quote:
>> so > the solution was to replace the ChangeNotifier Implementation by
>> a > ConcurrentChangeNotifier and a ConcurrentComposedAdapterFactory
>> with > use a CopyOnWriteArraList to store the listeners.
>> > Cheers,
Re: Copy On Write EList [message #1072270 is a reply to message #1072246] Mon, 22 July 2013 08:33 Go to previous messageGo to next message
Ed Merks wrote on Mon, 22 July 2013 13:27
Xavipen,
Comments below.
>> Xavipen,
>> Comments below.
>> effects for that.
The Wrappers implement InternalEList. I will need to have a look a EStructuralFeature.Setting interface.
> Framework.
Besides the EMF databinding and Edit Framework. The GUI code will not access the list directly. So, it may be possible to find an Iterator implmentation for that concrete problem. I comment more on this below. I agree that is impossible to find a global solution.
> Quote:
> atomic.
> wrapped.
addUnique(object);
That would be the implementation of the wrapper using locks.
public boolean addAll(int index, Collection<? extends E> c) {
dataLock.lock();
try{
return list.addAll(index, c);
}finally{
dataLock.unlock();
if (index != -1)
list.remove(index);
> Quote:
That is correct. That is why in our model the EClass that have the list as a feature
is the only code that works with the list an can modify it. For operations on the list a method needs to be added to the EClass. The GUI can use then commands to call those methods when it needs to modify the list, but it should never work on it on its own. This is what we can control in the design a implementation of our model.
The only other code that therefore should access the list directly are EMF databindings and Edit framework. How are they doing so is what i am trying to find out, to see if i can deal with it.
For example, if the iterations are mainly trigger by listening to change notification then it should be enough that the iterator contains an inmmutable copy of the list. If while iterating over the list the list is modified then a new notification would be received and processed afterwards, so the GUI will display the changes.
It is clear that some constrains will have to be used when writting the GUI code and dealing with the lists. For example it commens to mind: generic commands using the reflective methods are not to be used.
In the way we use the generated model, the whole logic and changes to the list should be inside the EClass code. I realise that this approach is not for everyone but only for the concrete problem we are trying to solve. It also means that some nice capabilities of the EMF Framework would not be used to ensure the Thread Safety.
This is what i am trying to assets currently.
> Quote:
>> > Cheers,
Re: Copy On Write EList [message #1072280 is a reply to message #1072270] Mon, 22 July 2013 08:53 Go to previous message
Javi,
Comments below.
>> Xavipen,
>> Comments below.
>> >> Xavipen,
>> >> Comments below.
>> here >> my > expirience on creating a threadSafe Model.
>> side > >> effects for that.
>> Elist. >> > This solution was suggested here, and it works, with the
>> side >> effect > of deadlocks (but when dealing with multithreading
>> is >> already a > posibility). Unfortunatelly i did not have the time
>> and i >> did not have > to time to improve this solution by looking
>> into >> DelegatingEcoreEList > (project time constrains as usual) and
>> i would >> not know were to start > ( Some remarks would be
>> aprreceated in case >> i have the time to revisit > this).
>> bidirectional >> reference will tend to deadlock. Do the wrappers
>> implement >> InternalEList and EStructuralFeature.Setting?
>> implementation > and a reference to the synchronization mechnism
>> used. All calls in the > wrapper are pass through the synchronization
>> mechnism (it is different > the way it is done between Locks and
>> Actors) We have not defined > bidirectional references, so i would
>> have to have a look, but any > reflective method needed could be
>> overwritten in the template of code > generation to ensure it is also
>> called through the synchornization > mechnism. In the case of Actors
>> if the function does not return a > value the call is asynchronous
>> to implement InternalEList and EStructuralFeature.Setting, so I
>> imagined that wrappers would need to implement those interfaces too,
>> not just EList.
That being missing will be something you notice if you use any of the
cross referencers (e.g., when using the DeleteCommand).
> Quote:
>> with > them. The Elist should be only handle with in the clas
>> containing it. > Only the GUI may want to iteract with the EList in
>> such a manner. At > the moment and till a time for a better
>> implementation comes. The GUI > (Parts) will do a copy of the EList
>> and work with it and listen for > the changes, so we avoid do
>> iterations over the Elist. At least till i > have time to understand
>> better the EMF databinding and the Edit > Framework.
>> without a look being held during the entire processing done with the
>> iterator...
> Quote:
>> > Quote:
>> over >> the whole operation.
>> being > atomic.
>> > wrapped.
>> collection) {
>> addUnique(object);
> @Override
> dataLock.lock();
> try{
> }finally{
> dataLock.unlock();
> Quote:
>> of > delegating and implementation of an EList, in case i have time
>> of > working in an implementation.
>> safe. For example, the following code isn't thread safe even if the
>> list itself is thread safe.
>> if (index != -1)
>> list.remove(index);
>> > Quote:
>> locks >> or > Actors. This code and the EList wrappers are activated
>> by an > >> annotation in the model.
>> implementation >> > (included at the end of the post, no guaratees
>> but it is what we >> used > with EMF 2.7.0).
>> Even >> if the list is thread safe, the adapter can end up being
>> added twice...
>> better > position now to understand the issue you mention now.
>> > It seems to me that there is an easy solution for this particular >
>> issue. Ensure Uniqueness in the Adapter list will solved having an >
>> adapter twice. Thanks for pointing this out. I will add that to the >
>> atomically, but as in the example I show above, some higher level
>> logic will nevertheless make assumptions about consistency between
>> when the model is read and when it's modified base on the information
>> determined while reading the model. In each case, the locking
>> behavior needs to be moved up the encompass of the higher level
>> logic, e.g., hold a lock during the entire lifetime of an iterator.
>> level locking/threading policy and when that is present, the fine
>> grained locks on the "primitives" serve no purpose other than to
>> interfere by giving rise to deadlocks.
> list as a feature
I see.
> Quote:
>> > Quote:
>> notifiers, >> so > the solution was to replace the ChangeNotifier
>> Implementation by >> a > ConcurrentChangeNotifier and a
>> ConcurrentComposedAdapterFactory >> with > use a CopyOnWriteArraList
>> >> > Cheers,
Previous Topic:Derived attributes, stored in feature map (for anyAttribute support)
Next Topic:[CDO] Databinding - ObservableListTreeContentProvider problem with removes from a list in a CDOView
Current Time: Wed Jul 30 12:13:45 EDT 2025
Powered by FUDForum. Page generated in 0.05222 seconds
