Home » Modeling » EMF » Ecore->XSD->Ecore roundtrip
Ecore->XSD->Ecore roundtrip [message #1072191] Mon, 22 July 2013 05:03 Go to next message
so after years of vanilla EMF modelling I'm finally forced to enter the world of XML Schema Neutral, meh.
What I currently do is: Take my models that are defined already in Ecore, and use the XSD Export function on the genmodel to get corresponding XSD models. The first question here:
What is the difference between "Export XSD for Ecore" and "Export XSD for XMI"?
Once I exported the ecore to schema, can I just use XML/XMI resources, and the serialized result will automatically be a valid according to the schemas? I guess if the original model is defined in Ecore, there's no need to use ExtendedMetadata in order to serialize?
Now, out of curiosity, I take the XSD files and re-create the Ecore models from them to do a full roundtrip. If I compare the original Ecore models against those created from the Schemas, I can see the following differences:
- The wrapper datatypes for nillable elements
- ExtendedMetadata annotations
So now I don't know If I should use the original Ecore models to serialize/deserialize, or the ones created from re-importing the corresponding XML schemas? My guts feeling is that I can skip the re-import, since the wrapper types are not used, and the annotations should represent some sort of "default" but maybe I miss something?
Once I'm done I'd be happy to contribute at least to the wiki or so Smile
Thanks for comments,
Felix.
[Updated on: Mon, 22 July 2013 05:04] by Moderator
Re: Ecore->XSD->Ecore roundtrip [message #1072206 is a reply to message #1072191] Mon, 22 July 2013 05:35 Go to previous messageGo to next message
Felix,
Comments below.
On 22/07/2013 11:03 AM, Felix Dorner wrote:
> the world of XML Schema :|, meh.
> for XMI"?
XMI schemas are basically useless. They provide a schema that describes
an XMI serialization of your model, but that schema is of essentially no
value because you can't describe an XMI serialization with a schema that
does a reasonable amount of validation.
> Once I exported the schema, can I just use XML/XMI resources, and the
> exported schema?
Yes, that's the idea. Another problem though is that XML Schema doesn't
support multiple inheritance so isn't general enough to describe all
Ecore models.
No.
I'd expect nillable elements only for things that already allow null,
i.e., for things that aren't primitives.
The original.
You shouldn't need to reimport from the generated schema.
> Once I'm done I'd be happy to contribute at least to the wiki or so :)
> Felix.
Re: Ecore->XSD->Ecore roundtrip [message #1072227 is a reply to message #1072206] Mon, 22 July 2013 06:45 Go to previous messageGo to next message
>> exported schema?
> Ecore models.
But the exporter can still create schemas for such models right? The
information that cannot be expressed in XSD is attached by using
ecore:... attributes in the schema.
Re: Ecore->XSD->Ecore roundtrip [message #1072240 is a reply to message #1072227] Mon, 22 July 2013 07:14 Go to previous messageGo to next message
Felix,
Comments below.
>>> exported schema?
>> Ecore models.
Yes.
> The information that cannot be expressed in XSD is attached by using
That's right.
Re: Ecore->XSD->Ecore roundtrip [message #1073683 is a reply to message #1072240] Thu, 25 July 2013 05:47 Go to previous messageGo to next message
Hi Ed,
>>>> exported schema?
>>> Ecore models.
> Yes.
> That's right.
But it looks like for example an EAttribute that comes from a
"secondary" superclass is lost in the schema representation, I give a
trivial example:
Airport
- runways: EInt
Trainstation
- platforms: EInt
TrafficHub -> Airport, Trainstation
- closedOnWeekends: EBoolean
The schema exporter generates a complex type TrafficHub like this:
<xsd:complexType ecore:implements="test1:Trainstation" name="TransportHub">
<xsd:complexContent>
<xsd:extension base="test1:Airport">
<xsd:attribute ecore:unsettable="false" name="closedOnWeekends"
type="ecore:EBoolean"/>
</xsd:extension>
</xsd:complexContent>
</xsd:complexType>
Aha Effect: The "platforms" attribute is missing from the TransportHub type.
When I now serialize a TrafficHub it will contain an attribute
"platforms" which is not allowed on a TrafficHub type according
to the schema, so a pure xml validator that uses the schema will report
the document invalid, and someone who wants to build tools around the
schema definition will miss important bits unless the ecore: attributes
are taken into account.
I guess that's what you meant with "Another problem.." above.
Felix
Re: Ecore-&gt;XSD-&gt;Ecore roundtrip [message #1074131 is a reply to message #1073683] Fri, 26 July 2013 03:08 Go to previous messageGo to next message
Felix,
Comments below.
On 25/07/2013 11:47 AM, Felix Dorner wrote:
> Hi Ed,
>>>>> exported schema?
>>>> doesn't
>>>> Ecore models.
>> Yes.
>> That's right.
> trivial example:
> Airport
> - runways: EInt
> Trainstation
> - platforms: EInt
XML Schema can't support multiple inheritance so in the end, it's
impossible for the schema to represent what you're serialize. Even if
we copied all the super class structure, a TrafficHub instance wouldn't
be allowed to appear where a Trainstation instance is allowed to appear,
so the serialization still can't generally conform to this schema.
> name="closedOnWeekends" type="ecore:EBoolean"/>
> </xsd:extension>
> </xsd:complexType>
> type.
> report the document invalid, and someone who wants to build tools
> around the schema definition will miss important bits unless the
> ecore: attributes are taken into account.
So if you want something that works for pure XML Schema you have to
avoid things not supported by XML Schema, e.g., no multiple inheritance.
Yes.
> Felix
Re: Ecore-&gt;XSD-&gt;Ecore roundtrip [message #1074271 is a reply to message #1074131] Fri, 26 July 2013 08:02 Go to previous message
have no idea about that buddy
Previous Topic:auto-split EMF model in several files
Next Topic:EMF operation call in ATL
Current Time: Thu Jul 31 00:44:59 EDT 2025
Powered by FUDForum. Page generated in 0.33905 seconds
