Home » Archived » Jubula » My Jubula Toolkit plug-in for custom GUI-Components doesn't work(Jubula Extension-Development)
My Jubula Toolkit plug-in for custom GUI-Components doesn't work [message #1069634] Tue, 16 July 2013 05:28 Go to next message
Hi!
My goal is to extend the Jubula Application with my own custom GUI-Components.
They can't be captured by default.
So I started creating an Eclipse-plug-in following the Guidelines of the official "Functional Testing Extension Manual" (June 17, 2013) in chapter "2.2 ITE extension".
I used the "JSlider"-Example-plug-in-Project as a functional reference (it's shipped with the Jubula Installation 7.1.0).
My environment data:
Hostdetails: Windows Vista, 32 Bit
Java SDK: 1.7
Plugin development environment: eclipse Kepler (Classic Edition), Version: 4.3.0.v20130605-2000
Jubula environment: standalone Jubula Version: 7.1.0
Embedded AUT
Embedded Test-DB
The problems I experienced with the example-project:
1. The Target Platform configuration (set the Features org.eclipse.rcp and org.eclipse.jubula.feature) mentioned in the development-guidelines (2.2.1.3) isn't compatible with the example-toolkit-plugin-project as there are "Required Plug-ins" in the "Dependencies"-Config such as "org.eclipse.core.runtime" which are not supplied by these two Features.
My workaround was to add the eclipse-installation-folder with its plugins to the Target Platform. --> "org.eclipse.core.runtime" is now available
2. I created an "Update Site" and integrated the "Toolkit"-Feature (this encapsulates the toolkit-plug-in also as the "remote-control"-plug-in for the JSlider Component). Then I installed the Feature in my Jubula Environment.
The Component with its Action is available. But when I start the AUT I get an error: "5009:AUT Start Failed" described here: http://www.eclipse.org/forums/index.php/t/490155/
The problems I experienced with my own toolkit-plugin-project:
I. After installing my Plug-in over my Update-Site and restart Jubula, the "Test-Case-Browser", also as the "Test-Suite-Browser" and other Jubula-Components didn't load properly but throw an Exeption:
"Plug-in org.eclipse.jubula.client.ui.rcp was unable to load class org.eclipse.jubula.client.ui.rcp.views.TestSuiteBrowser"
Here is the detailed Exception-log:
org.eclipse.core.runtime.CoreException: Plug-in org.eclipse.jubula.client.ui.rcp was unable to load class org.eclipse.jubula.client.ui.rcp.views.TestSuiteBrowser.
	at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194)
	at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:176)
	at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
	at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
	at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
	at org.eclipse.ui.internal.registry.ViewDescriptor.createView(ViewDescriptor.java:62)
	at org.eclipse.ui.internal.ViewReference.createPart(ViewReference.java:112)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPart(CompatibilityPart.java:262)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:299)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:861)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:841)
	at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:113)
	at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:321)
	at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:242)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:161)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:102)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:71)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:53)
	at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:141)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:894)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:629)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$6.run(PartRenderingEngine.java:520)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:505)
	at org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer.createWidget(ElementReferenceRenderer.java:74)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:731)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:702)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:696)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:681)
	at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1115)
	at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:98)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:645)
	at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:59)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:641)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer.processContents(PerspectiveRenderer.java:59)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:103)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.postProcess(PerspectiveStackRenderer.java:77)
	at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:644)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:987)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:942)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
	at org.eclipse.jubula.app.Launcher.start(Launcher.java:242)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Caused by: org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$TerminatingClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.jubula.client.ui.rcp (262).
	at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:122)
	at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:469)
	at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
	at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:395)
	at org.eclipse.osgi.internal.loader.SingleSourcePackage.loadClass(SingleSourcePackage.java:35)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:461)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
	at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
	at java.lang.ClassLoader.defineClass1(Native Method)
	at java.lang.ClassLoader.defineClassCond(ClassLoader.java:631)
	at java.lang.ClassLoader.defineClass(ClassLoader.java:615)
	at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.defineClass(DefaultClassLoader.java:188)
	at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineClassHoldingLock(ClasspathManager.java:632)
	at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineClass(ClasspathManager.java:614)
	at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findClassImpl(ClasspathManager.java:568)
	at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClassImpl(ClasspathManager.java:492)
	at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:465)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:464)
	at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:340)
	at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:229)
	at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1212)
	at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
	at org.eclipse.ui.internal.services.WorkbenchServiceRegistry.getSourceProviders(WorkbenchServiceRegistry.java:175)
	at org.eclipse.ui.internal.services.SourceProviderService.readRegistry(SourceProviderService.java:105)
	at org.eclipse.ui.internal.Workbench$45.runWithException(Workbench.java:2079)
	at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
	at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
	at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
	at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4144)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3761)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2533)
	at org.eclipse.ui.internal.Workbench.access$7(Workbench.java:2441)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:586)
	... 17 more
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.jubula.client.ui.rcp.Plugin.start() of bundle org.eclipse.jubula.client.ui.rcp.
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
	at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
	at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:300)
	at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:440)
	at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:263)
	at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
	... 60 more
Caused by: org.eclipse.jubula.tools.exception.GDConfigXmlException
	at org.eclipse.jubula.toolkit.common.xml.businessprocess.ComponentBuilder.getCompSystem(ComponentBuilder.java:194)
	at org.eclipse.jubula.client.core.ClientTest.<init>(ClientTest.java:203)
	at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
	at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39)
	at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27)
	at java.lang.reflect.Constructor.newInstance(Constructor.java:513)
	at java.lang.Class.newInstance0(Class.java:357)
	at java.lang.Class.newInstance(Class.java:310)
	at org.eclipse.jubula.client.core.ClientTestFactory.getClientTest(ClientTestFactory.java:44)
	at org.eclipse.jubula.client.ui.rcp.controllers.TestExecutionContributor.<init>(TestExecutionContributor.java:97)
	at org.eclipse.jubula.client.ui.rcp.controllers.TestExecutionContributor.getInstance(TestExecutionContributor.java:778)
	at org.eclipse.jubula.client.ui.rcp.Plugin.registerPermanentServices(Plugin.java:1060)
	at org.eclipse.jubula.client.ui.rcp.Plugin.start(Plugin.java:1046)
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
	... 66 more
My plug-in is structured like the example-Project. I followed the guidelines one-by-one.
I have no idea why my plug-in doesn't work as well as the example-plug-in.
I would be pleased if you give me any hints, ideas or approaches. Smile
Thank you!
Regards, Hans.
Re: My Jubula Toolkit plug-in for custom GUI-Components doesn't work [message #1070236 is a reply to message #1069634] Wed, 17 July 2013 10:20 Go to previous messageGo to next message
The jubula-dev and jubula-rc-dev mailing list archives have some threads within them that have dealt with extensions. It might be worth having a look there. If those threads don't help, it would be great if you could repost the question to the jubula-rc-dev mailing list.
Thanks!
Alex
Re: My Jubula Toolkit plug-in for custom GUI-Components doesn't work [message #1072186 is a reply to message #1069634] Mon, 22 July 2013 04:53 Go to previous message
Hi Hans,
this works for me
http://dev.eclipse.org/mhonarc/lists/jubula-dev/msg00287.html
I remove the signatures from org.eclipse.jubula.rc.common_<version>.jar
and org.eclipse.jubula.rc.swing_<version>.jar in the plugins folder and i can launch the swing example and test the jslider.
I guess that you need remove the signatures from the other org.eclipse.jubula.rc.* plug-ins.
Best Regards,
Rodrigo
Previous Topic:How to wait for expanding a tree?
Next Topic:How to perform version control and test merge with Jubula?
Current Time: Mon Jul 21 00:41:38 EDT 2025
Powered by FUDForum. Page generated in 0.24597 seconds
