Swing - JPanel - Border Properties = Error [message #1071132] |
Fri, 19 July 2013 08:14  |
I am running Eclipse Kepler using the J2EE download on Mac OSX Mountain Lion. If I create from scratch a simple JFrame and add a JPanel to it, I am then unable to set the Border type using the properties inspector without crashing the WindowBuilder.
WindowBuilder Core 1.6.0.r43x201305211944 org.eclipse.wb.core.feature.feature.group Eclipse.org
Java(TM) SE Runtime Environment (build 1.7.0_25-b15)
Java HotSpot(TM) 64-Bit Server VM (build 23.25-b01, mixed mode)
The following error dialog appears :-
Designer [1.6.0.r43x201305211944.201307191313]: Not implemented (java.lang.ClassNotFoundException: sun.lwawt.macosx.CViewEmbeddedFrame cannot be found by org.eclipse.swt_3.102.0.v20130605-1539)
[Updated on: Fri, 19 July 2013 08:15] by Moderator
FUDForum. Page generated in 0.05154 seconds
