Home » Eclipse Projects » Rich Client Platform (RCP) » Split plugin.xml in small parts(How to divide plugin.xml file in some smaller files dedicated to only one extention type. )
Split plugin.xml in small parts [message #728477] Fri, 23 September 2011 06:36 Go to next message
I have projects divided in various plugins but even doing this my plugin.xml files are growing huge, especially when starting to use conditions on the various extension points.
Is there a way to split the plugin.xml file, using a kind of 'import' mecanism or some extension file ?
Bruno
Re: Split plugin.xml in small parts [message #874371 is a reply to message #728477] Sun, 20 May 2012 13:43 Go to previous messageGo to next message
Hi Sinou,
Have you found the answer? I made only a script that merge sub-module description into one plugin.xml.
Marek
Re: Split plugin.xml in small parts [message #880166 is a reply to message #874371] Fri, 01 June 2012 10:47 Go to previous messageGo to next message
The PDE Editor wouldn't be able to work with your plugin.xml split into smaller files, at least not very well.
Does using XML entities allow you to suck in the smaller fragments during runtime?
PW
Re: Split plugin.xml in small parts [message #1052999 is a reply to message #880166] Wed, 01 May 2013 16:30 Go to previous messageGo to next message
Sorry,
I haven't seen your question. I was evoking my script automatically in compile-time. At least, I could well organize my plugin.xml during development. I didn't need to look into huge final file.
Marek
Re: Split plugin.xml in small parts [message #1071890 is a reply to message #1052999] Sun, 21 July 2013 09:33 Go to previous messageGo to next message
Is the script used for merge files into plugin.xml based on XSLT? And is it run as ANT task at compile time?
It would be really helpful if you can share the script with everybody.
Re: Split plugin.xml in small parts [message #1071893 is a reply to message #1052999] Sun, 21 July 2013 09:42 Go to previous message
Marek Jagielski wrote on Wed, 01 May 2013 16:30
Sorry,
Marek
Hi Marek,
Is the script you developed for this purpose based on XSLT? And is it run as an ANT task?
I would be really helpful if you can share your script or post a snippet on how you are merging the files into plugin.xml file at compile time.
Previous Topic:Standalone RCP application: missing Bundle
Next Topic:Source bundle generation for bundle only
Current Time: Wed Jul 23 13:33:25 EDT 2025
Powered by FUDForum. Page generated in 0.07636 seconds
