[Xcore] How to define/constrain a class when it is referenced in two containers [message #1071624] |
Sat, 20 July 2013 13:53  |
Given the wrong model below:
class Room {
Sting name
contains Box[] boxes
contains Thing[] things
class SmallBox {
String name
containss Thing[1] specialThing
contains Thing[] justRegularThnigs
class Thing {
String name
How does one make sure that Things are only created and stored first in
Room.things, also, SmallBox.specialThing and SmallBox.justRegularThings
are populate only from references to Room.things and not new instances
of Thing.
-H
Re: [Xcore] How to define/constrain a class when it is referenced in two containers [message #1071874 is a reply to message #1071820] |
Sun, 21 July 2013 08:33   |
On 2013-07-21 10:41, Ed Merks wrote:
> Hugo,
> Comments below.
> On 20/07/2013 7:53 PM, Hugo A. Garcia wrote:
>> Hi
>> class Room {
>> Sting name
CHANGED THE NAME FROM SmallBox to Box
class Box {
>> String name
>> class Thing {
>> String name
>> in Room.things, also,
> What do you mean by "first"?
NOTE: There is name change in the above model.
Thinking on how a user creates a model either using Xtext or a Graphiti.
First create a Room then full of hings. Now add a box to the room and
_fill_ the Box with a Box.specialThing and Box.justRegularThings from
the list of Room.things.
>> SmallBox.specialThing and SmallBox.justRegularThings are populate only
>> from references to Room.things and not new instances of Thing.
> It's a contradiction. An EObject x can be contained in at most one
> container y, accessible via EObject.eContainer and must be present in
> y.eGet(x.eContainmentFeature()). So if x is a Thing and y is a Room it
> must be in y.getThings() and nowhere else.
Exactly, that is the problem that I am facing. So either I convert the
model to a regular tree structure which might not quite express the
intent of the model OR....
> Are some of these features supposed to be derived? Perhaps some type of
> "directlyContains" containment reference and a derived
> "directlyOrIndirectlyContains" cross reference?
Yes, something of derived feature for Box.specialThing and
Box.justRegularThings. Furthermore, in the Xtext or Graphit edtior or
even in the regular EMF editor... the available things in the room
should be visualized as a dropdown when filling the box.
>> -H
Re: [Xcore] How to define/constrain a class when it is referenced in two containers [message #1071879 is a reply to message #1071874] |
Sun, 21 July 2013 08:53  |
Hugo,
Comments below.
>> Hugo,
>> Comments below.
>>> Hi
>>> class Room {
>>> Sting name
> class Box {
>>> String name
>>> class Thing {
>>> String name
So those latter two relationships should be cross references...
In the end, it really comes down to your intent and what you want to do
with such a model.
It's easy enough to filter the choices available for the property
descriptor in the item provider to only allow the choice of things as
you see fit.
>>> -H
FUDForum. Page generated in 0.05527 seconds
