Home » Eclipse Projects » WindowBuilder » Swing - JPanel - Border Properties = Error(Error setting Border Type for JPanel with WindowBuilder)
Swing - JPanel - Border Properties = Error [message #1071132] Fri, 19 July 2013 08:14 Go to next message
I am running Eclipse Kepler using the J2EE download on Mac OSX Mountain Lion. If I create from scratch a simple JFrame and add a JPanel to it, I am then unable to set the Border type using the properties inspector without crashing the WindowBuilder.
WindowBuilder Core 1.6.0.r43x201305211944 org.eclipse.wb.core.feature.feature.group Eclipse.org
Java(TM) SE Runtime Environment (build 1.7.0_25-b15)
Java HotSpot(TM) 64-Bit Server VM (build 23.25-b01, mixed mode)
The following error dialog appears :-
Designer [1.6.0.r43x201305211944.201307191313]: Not implemented (java.lang.ClassNotFoundException: sun.lwawt.macosx.CViewEmbeddedFrame cannot be found by org.eclipse.swt_3.102.0.v20130605-1539)
[Updated on: Fri, 19 July 2013 08:15] by Moderator
Re: Swing - JPanel - Border Properties = Error [message #1071722 is a reply to message #1071132] Sat, 20 July 2013 21:02 Go to previous messageGo to next message
I did exactly as you suggested, and it worked just fine.
Note that the ClassNotFoundException you reference is being triggered by Eclipse and reported by WindowBuilder. A ClassNotFoundException like this indicates some sort of incompatibility with your Java environment. In fact it looks like it is a known Eclipse issue.
https://lh3.googleusercontent.com/-XrVc-7uIoks/Uest7KSHJOI/AAAAAAAAARw/4Z8eCg1BSaM/s1600/wb-swing-frame.png
Re: Swing - JPanel - Border Properties = Error [message #1071770 is a reply to message #1071722] Sun, 21 July 2013 00:54 Go to previous messageGo to next message
I have just performed a fresh download of Kepler J2EE Eclipse and this time installed the current WindowBuilder Pro Integration version. I get the same error.
What versions of Eclipse and Java are you running to get it working please ?
Dave
Re: Swing - JPanel - Border Properties = Error [message #1072042 is a reply to message #1071770] Sun, 21 July 2013 19:42 Go to previous messageGo to next message
Try running Eclipse using JDK 1.6... or wait for a patch for Eclipse bugs 374199 and 378442 to be released.
Re: Swing - JPanel - Border Properties = Error [message #1072338 is a reply to message #1072042] Mon, 22 July 2013 10:53 Go to previous messageGo to next message
Would I need to unistall Java 7 to get 6 to become the default. The Oracle Java control panel does not list 1.6 as a version.
Re: Swing - JPanel - Border Properties = Error [message #1072378 is a reply to message #1072338] Mon, 22 July 2013 12:31 Go to previous message
You should be able to have multiple JDKs installed and should not need to uninstall Java 7.
Previous Topic:Using EMF Data Binding with EMF models from separate projects
Next Topic:Official documentation on how to extend the WB
Current Time: Sat Jul 26 21:32:48 EDT 2025
Powered by FUDForum. Page generated in 0.05108 seconds
