Home » Modeling » EMF » Reading data stored in model objects and displaying the data
Reading data stored in model objects and displaying the data [message #1071527] Sat, 20 July 2013 07:00 Go to next message
hello, I have a scenario. I created the ecore model and I have an class named Reports. This contains certain field like date, some strings.
Is there a possibility to read the contents of the Reports (Model Object)and display the contents (in the client environment)
Its like Reports-> Right click -> a menu is generated and a sub item is like (read this report). On click this should read the contents of the model object(Reading logic resides in some class).
I skimmed through the book and it suggests to create wizards and wizard pages for the UI.
P.S: I can export it as a xmi file and read through the data. but I want it to be done like this.
Any suggestions.
[Updated on: Sat, 20 July 2013 07:08] by Moderator
Re: Reading data stored in model objects and displaying the data [message #1071533 is a reply to message #1071527] Sat, 20 July 2013 07:21 Go to previous messageGo to next message
Bim,
Comments below.
Yes.
> the model object.
Reading the model is trivial and as you can see in the generated editor,
displaying it is also easy.
So it's mostly a question of how/what you want to display, and that's
entirely unclear from your question. How is what you want to achieve
different from just opening the editor for your model?
> Any suggestions.
> Thanks
Re: Reading data stored in model objects and displaying the data [message #1071538 is a reply to message #1071533] Sat, 20 July 2013 07:41 Go to previous messageGo to next message
Ed,
entirely unclear from your question. > This is how my model element looks like:
<?xml version="1.0" encoding="ASCII"?>
<ReportModel:ReportContainer xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI">
  <Reports xsi:type="SampleReportModel:Report"  Date=10:01:2013, ReportName = SampleReport>
  </Reports>
</ReportModel:ReportContainer>
How is what you want to achieve different from just opening the editor for your model?
Sorry I did not understand this.
[Updated on: Sat, 20 July 2013 07:42] by Moderator
Re: Reading data stored in model objects and displaying the data [message #1071542 is a reply to message #1071538] Sat, 20 July 2013 07:58 Go to previous messageGo to next message
Bim,
Comments below.
On 20/07/2013 1:41 PM, bim boh wrote:
> Ed,
> looks like:
> <ReportModel:Reports xmi:version="2.0"
> </Reports>
And is that what you want to display?
> for your model?
There's a generated editor for the model that you can use to open a file
and display its contents in an outline view and then see the properties
in the properties view. Why don't you just use the editor?
Re: Reading data stored in model objects and displaying the data [message #1071545 is a reply to message #1071542] Sat, 20 July 2013 08:07 Go to previous messageGo to next message
Ed,
  </Reports>
> yes this is what I want to display.
> yes I know this properties view, but actually I am using an extension on EMF called EMFTrace. I do not get data in the properties view Sad.
Re: Reading data stored in model objects and displaying the data [message #1071556 is a reply to message #1071545] Sat, 20 July 2013 08:51 Go to previous message
Bim,
Comments below.
On 20/07/2013 2:07 PM, bim boh wrote:
> Ed,
> </Reports>
So you load the model into a resource and use something like to write it
to a string representation:
StringWriter writer = new StringWriter();
OutputStream out = new
URIConverter.WriteableOutputStream(writer, "UTF-8");
resource.save(out, null);
System.err.println(writer.toString());
You can invoke Generate Test Code to generate an XyzExample.java in the
*.tests project showing how to load a resource in a stand alone
application. If you're running in the Eclipse IDE, you don't need any
of the registration code, just a resource set to load the resource. Or
if you already have the model loaded, you can use eObject.eResource() to
get at the resource and use the code I show above write the whole thing
to a string.
> file and display its contents in an outline view and then see the
> properties in the properties view. Why don't you just use the editor?
>> on EMF called EMFTrace. I do not get data in the properties view :(.
Previous Topic:How to annotate HTML?
Next Topic:[Xcore] How to define/constrain a class when it is referenced in two containers
Current Time: Wed Jul 30 22:14:29 EDT 2025
Powered by FUDForum. Page generated in 0.18770 seconds
