Home » Archived » BIRT » Rhino version(Rhino version 1.7R4)
Rhino version [message #1059021] Thu, 16 May 2013 05:07 Go to next message
Hi all!
In our application we are using Eclipse BIRT for generating reports. Application is deployed on Jboss 4.2.3. We are using Birt version 2.5.2.
The problem is, that we want to use rhino version 1.7R4 options in our other functionalities but this conflicts with rhino version shipped and supported by birt engine.
Is there any way to resolve this issue? When it is planned for Birt to ship with version 1.7R4 of rhino engine?
Thanks in advance for your answers!
Gregor
Re: Rhino version [message #1059123 is a reply to message #1059021] Thu, 16 May 2013 16:35 Go to previous messageGo to next message
BIRT 2.5.2 still uses the OSGi runtime which has its own classloader, so I don't think there should be a conflict between BIRT and your external use of a different release of Rhino. What is the conflict you're having?
Re: Rhino version [message #1067890 is a reply to message #1059123] Thu, 11 July 2013 03:02 Go to previous messageGo to next message
I have the same problem as described in post above. Using Birt 2.5.2 and rhino 1.7.R4 . The error trace is following after generating document via Birt engine:
Plug-in org.eclipse.birt.report.engine.script.javascript was unable to load class org.eclipse.birt.report.engine.javascript.JavascriptEngineFactory.
org.eclipse.core.runtime.CoreException: Plug-in org.eclipse.birt.report.engine.script.javascript was unable to load class org.eclipse.birt.report.engine.javascript.JavascriptEngineFactory.
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:180)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:162)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:874)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:51)
at org.eclipse.birt.core.internal.plugin.ScriptEngineFactoryManagerImpl.createFactory(ScriptEngineFactoryManagerImpl.java:60)
at org.eclipse.birt.core.script.ScriptEngineFactoryManager.getScriptEngineFactory(ScriptEngineFactoryManager.java:50)
at org.eclipse.birt.core.script.ScriptContext.getScriptEngine(ScriptContext.java:222)
at org.eclipse.birt.report.engine.adapter.ModelDteApiAdapter.<init>(ModelDteApiAdapter.java:176)
at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.<init>(AbstractDataEngine.java:107)
at org.eclipse.birt.report.engine.data.dte.DteDataEngine.<init>(DteDataEngine.java:85)
at org.eclipse.birt.report.engine.data.DataEngineFactory.createDataEngine(DataEngineFactory.java:100)
at org.eclipse.birt.report.engine.executor.ExecutionContext.openDataEngine(ExecutionContext.java:843)
at org.eclipse.birt.report.engine.executor.ExecutionContext.getDataEngine(ExecutionContext.java:865)
at org.eclipse.birt.report.engine.executor.ReportExecutor.execute(ReportExecutor.java:123)
at org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportExecutor.execute(WrappedReportExecutor.java:60)
at org.eclipse.birt.report.engine.internal.executor.dup.SuppressDuplciateReportExecutor.execute(SuppressDuplciateReportExecutor.java:42)
at org.eclipse.birt.report.engine.internal.executor.l18n.LocalizedReportExecutor.execute(LocalizedReportExecutor.java:61)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:168)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRenderTask.java:75)
at de.novum.vger.printing_archive.ejb.docgen.DocumentGeneration.execute(DocumentGeneration.java:156)
I would appreciate any help.
Thanks Boštjan
Re: Rhino version [message #1067913 is a reply to message #1059123] Thu, 11 July 2013 04:41 Go to previous messageGo to next message
Thanks Boštjan
Re: Rhino version [message #1071371 is a reply to message #1067913] Fri, 19 July 2013 20:15 Go to previous message
Are you replacing BIRT's version of Rhino? Can you explain more?
Previous Topic:Can Birt 4.2.2 work on CentOS 6.4?
Next Topic:missing fonts exporting to PDF
Current Time: Sun Jul 27 16:23:40 EDT 2025
Powered by FUDForum. Page generated in 0.04846 seconds
