Home » Archived » BIRT » Birt 4.3 in maven repository?
Birt 4.3 in maven repository? [message #1068137] Fri, 12 July 2013 07:13 Go to next message
I would like to update to birt 4.3 in a maven managed project. Unfortunately it seems as if birt 4.3 has not been published to maven. Am I using the wrong dependency or do I just have to wait?
Currently I'm using this dependency to use the previous birt version:
		<dependency>
			<groupId>org.eclipse.birt.runtime</groupId>
			<artifactId>org.eclipse.birt.runtime</artifactId>
			<version>4.2.2</version>
		</dependency>
I tried to upgrade with this dependency:
		<dependency>
			<version>4.3</version>
		</dependency>
Thanks in advance!
Re: Birt 4.3 in maven repository? [message #1069134 is a reply to message #1068137] Mon, 15 July 2013 04:16 Go to previous messageGo to next message
Woohoo - they heard me cry Wink
Birt 4.3 is available with:
		<dependency>
			<version>4.3.0</version>
		</dependency>
I had to exclude org.apache.poi in my project due to compilation errors (that dependency is included at several points). Don't know if that is a general problem, but in my case it works now.
Re: Birt 4.3 in maven repository? [message #1071247 is a reply to message #1069134] Fri, 19 July 2013 12:32 Go to previous messageGo to next message
Great! Thanks for updating the thread!
Re: Birt 4.3 in maven repository? [message #1131067 is a reply to message #1068137] Thu, 10 October 2013 02:46 Go to previous messageGo to next message
Birt 4.3.1 was released on september. It allows to fix an Excel bug (timeZone not used), which I have in some reports.
Is it planned to put birt 4.3.1 in maven repositories ?
Re: Birt 4.3 in maven repository? [message #1148428 is a reply to message #1131067] Mon, 21 October 2013 09:55 Go to previous messageGo to next message
Birt 4.3.1 was added today on maven repositories. Thanks.
Re: Birt 4.3 in maven repository? [message #1274566 is a reply to message #1148428] Fri, 21 March 2014 12:46 Go to previous messageGo to next message
When will 4.3.2 make it into Maven?
Re: Birt 4.3 in maven repository? [message #1404366 is a reply to message #1068137] Thu, 31 July 2014 11:00 Go to previous message
After adding maven dependencies for Birt in my project I am getting next exception:
<Jul 31, 2014 10:02:06 AM EDT> <Warning> <HTTP> <BEA-101162> <User defined listener org.eclipse.birt.report.listener.ViewerServletContextListener failed: java.lang.NoClassDefFoundError: org/eclipse/birt/core/framework/eclipse/EclipseExtensionRegistry.
at org.eclipse.birt.core.framework.eclipse.EclipsePlatform.getExtensionRegistry(EclipsePlatform.java:56)
at org.eclipse.birt.core.framework.eclipse.EclipsePlatform.createFactoryObject(EclipsePlatform.java:351)
at org.eclipse.birt.core.framework.Platform$1.run(Platform.java:297)
at org.eclipse.birt.core.framework.Platform.createFactoryObject(Platform.java:293)
Truncated. see log file for complete stacktrace
Caused By: org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$TerminatingClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.birt.core (4).
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:121)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:453)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:393)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:469)
Caused By: org.osgi.framework.BundleException: Exception in org.eclipse.birt.core.internal.plugin.CorePlugin.start() of bundle org.eclipse.birt.core.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:806)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:755)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:370)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:284)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:417)
Caused By: java.lang.NoSuchMethodError: org.eclipse.birt.core.framework.Platform.setContextClassLoader(Ljava/lang/ClassLoader;)V
at org.eclipse.birt.core.internal.plugin.CorePlugin.start(CorePlugin.java:44)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:783)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:774)
The dependencies that I added are:
(I tried with different versions and I get the same error). Does someone have a suggestion?
<dependency>
<exclusions>
<exclusion>
<artifactId>org.apache.poi</artifactId>
</exclusion>
</exclusions>
</dependency>
<dependency>
<groupId>org.apache.poi</groupId>
<artifactId>poi</artifactId>
<version>3.9</version>
</dependency>
<dependency>
<artifactId>org.eclipse.emf.ecore</artifactId>
<version>2.9.1.v20130827-0309</version>
</dependency>
<dependency>
<artifactId>viewservlets</artifactId>
</dependency>
Previous Topic:Building of Birt from source code.
Next Topic:Build Birt Report Engine or Runtime
Current Time: Wed Jul 23 12:57:20 EDT 2025
Powered by FUDForum. Page generated in 0.50983 seconds
