Home » Modeling » Epsilon » EOL polishing script setup
EOL polishing script setup [message #1071193] Fri, 19 July 2013 10:28 Go to next message
Hello everyone,
I created an editor with custom Java figures defined in the .emf file and it works pretty well. Now I want to customize the generated GMF graph with custom connection lines, but the polishing script I wrote has zero effect.
The .eol file is located in the model folder right next to the .ecore and .emf files. I right-click either the .emf or the .ecore file and generate the editor or GMF tool, graph and model. Nothing happens.
Then I tried this script from the tutorial and put it at the same location.
var frame = new Native("javax.swing.JFrame");
frame.setBounds(300,300,300,300);
frame.title = "Opened from EOL";
frame.visible = true;
The script is working when I start it from the application launcher but nothing happens during the editor generation.
What am I doing wrong?
Re: EOL polishing script setup [message #1072231 is a reply to message #1071193] Mon, 22 July 2013 06:57 Go to previous message
Hi Erik,
Is the name of your script Ecore2GMF.eol?
Dimitris
Previous Topic:[Emfatic] bidirectional aggregation
Next Topic:[EGL] Abort processing / throw error or something like that
Current Time: Sat Jul 26 05:18:11 EDT 2025
Powered by FUDForum. Page generated in 0.05656 seconds
